[DemoCode下载]
ADC的简单用法
848|7
xixi2017|  楼主 | 2024-2-25 19:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ar, TE, dc, ADC, AD
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
* $Revision: 2 $
* $Date: 15/02/06 10:22a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Monitor the conversion result of channel 2 by the digital compare function.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M058S.h"
#define PLL_CLOCK       50000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcResultMonitorTest(void);
/* Define global variables and constants        */
volatile uint32_t g_u32AdcCmp0IntFlag;
volatile uint32_t g_u32AdcCmp1IntFlag;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184 MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD | SYS_MFP_P31_TXD;
    /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
    GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
    /* Configure the P1.0 - P1.3 ADC analog input pins */
    SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: AdcResultMonitorTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC result monitor function test.        */
void AdcResultMonitorTest()
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|           ADC compare function (result monitor) sample code          |\n");
    printf("\nIn this test, software will compare the conversion result of channel 2.\n");
    /* Power on ADC module */
    ADC_POWER_ON(ADC);
    /* Set the ADC operation mode as continuous scan, input mode as single-end and enable the analog input channel 2 */
    ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0x1 << 2);
    /* Enable ADC comparator 0. Compare condition: conversion result < 0x800; match Count=5. */
    printf("   Set the compare condition of comparator 0: channel 2 is less than 0x800; match count is 5.\n");
    ADC_ENABLE_CMP0(ADC, 2, ADC_ADCMPR_CMPCOND_LESS_THAN, 0x800, 5);
    /* Enable ADC comparator 1. Compare condition: conversion result >= 0x800; match Count=5. */
    printf("   Set the compare condition of comparator 1: channel 2 is greater than or equal to 0x800; match count is 5.\n");
    ADC_ENABLE_CMP1(ADC, 2, ADC_ADCMPR_CMPCOND_GREATER_OR_EQUAL, 0x800, 5);
    /* clear the ADC comparator 0 interrupt flag for safe */
    ADC_CLR_INT_FLAG(ADC, ADC_CMP0_INT);
    /* enable ADC comparator 0 interrupt */
    ADC_EnableInt(ADC, ADC_CMP0_INT);
    /* clear the ADC comparator 1 interrupt flag for safe */
    ADC_CLR_INT_FLAG(ADC, ADC_CMP1_INT);
    /* enable ADC comparator 1 interrupt */
    ADC_EnableInt(ADC, ADC_CMP1_INT);
    NVIC_EnableIRQ(ADC_IRQn);
    g_u32AdcCmp0IntFlag = 0;
    g_u32AdcCmp1IntFlag = 0;
    /* Clear the ADC interrupt flag */
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
    /* start A/D conversion */
    ADC_START_CONV(ADC);
    /* Wait ADC compare interrupt */
    while((g_u32AdcCmp0IntFlag == 0) && (g_u32AdcCmp1IntFlag == 0));
    /* Stop A/D conversion */
    ADC_STOP_CONV(ADC);
    /* Disable ADC comparator interrupt */
    ADC_DisableInt(ADC, ADC_CMP0_INT);
    ADC_DisableInt(ADC, ADC_CMP1_INT);
    /* Disable compare function */
    ADC_DISABLE_CMP0(ADC);
    ADC_DISABLE_CMP1(ADC);
    if(g_u32AdcCmp0IntFlag == 1)
        printf("Comparator 0 interrupt occurs.\nThe conversion result of channel 2 is less than 0x800\n");
    else
        printf("Comparator 1 interrupt occurs.\nThe conversion result of channel 2 is greater than or equal to 0x800\n");
/* ADC interrupt handler        */
void ADC_IRQHandler(void)
    if(ADC_GET_INT_FLAG(ADC, ADC_CMP0_INT) != 0)
        g_u32AdcCmp0IntFlag = 1;
        ADC_CLR_INT_FLAG(ADC, ADC_CMP0_INT);     /* clear the A/D compare flag 0 */
    if(ADC_GET_INT_FLAG(ADC, ADC_CMP1_INT) != 0)
        g_u32AdcCmp1IntFlag = 1;
        ADC_CLR_INT_FLAG(ADC, ADC_CMP1_INT);     /* clear the A/D compare flag 1 */
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* Result monitor test */
    AdcResultMonitorTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
xixi2017|  楼主 | 2024-2-25 19:03 | 只看该作者
这段单片机代码是用来监视通道2的转换结果,通过数字比较功能来实现。以下是代码的主要功能和结构:
首先是一些头文件包含和宏定义,其中包含了芯片型号相关的头文件和一些宏定义,如时钟频率等。
定义了一些全局变量,用于标志ADC比较中断的发生情况。
SYS_Init() 函数用于初始化系统时钟和相关的模块,包括使能内部和外部时钟,设置时钟源,初始化多功能引脚等。
UART0_Init() 函数用于初始化UART0串口通信模块,设置波特率等。
AdcResultMonitorTest() 函数用于ADC结果监视测试。在这个函数中:
打印测试信息。
启动ADC模块并配置为连续扫描模式,设置通道2为单端输入。
启用ADC比较功能,通过比较条件设置通道2的转换结果与预设值进行比较,并设置匹配计数。
启用ADC比较中断,并等待中断发生。
中断服务函数 ADC_IRQHandler() 用于处理ADC的比较中断,当比较中断发生时,设置相应的标志位。
根据比较中断的标志位确定通道2的转换结果是小于预设值还是大于等于预设值,并输出相应信息。
main() 函数中:
解锁保护寄存器。
初始化系统。
锁定保护寄存器。
初始化UART0。
打印系统时钟频率。
运行ADC结果监视测试。
关闭ADC模块和相应时钟,并禁用ADC比较中断。
死循环。
总体来说,这段代码的功能是通过ADC监视通道2的转换结果,根据预设的比较条件判断结果大小,并通过UART0串口输出相应信息。
wanduzi| | 2024-2-25 19:23 | 只看该作者
最简单的就是初始化,查询读取。
zhuotuzi| | 2024-2-26 22:40 | 只看该作者
单片机的ADC(模数转换器)是一种将模拟信号转换为数字信号的器件。单片机的ADC具有以下特点:
分辨率:ADC的分辨率是指其能够将模拟信号转换为多少个数字量。例如,一个12位ADC可以将模拟信号转换为4096个数字量。
采样率:ADC的采样率是指其每秒钟能够采样多少次模拟信号。例如,一个100kHz的ADC每秒钟可以采样100000次模拟信号。
单片机ADC的简单用法
单片机ADC的简单用法如下:
配置ADC
选择ADC的通道
设置ADC的分辨率
设置ADC的采样率
启动ADC转换
发送ADC转换启动命令
读取ADC转换结果
读取ADC转换结果寄存器
heisexingqisi| | 2024-2-27 21:07 | 只看该作者
测量热敏电阻
xixi2017|  楼主 | 2024-2-28 11:43 | 只看该作者
wanduzi 发表于 2024-2-25 19:23
最简单的就是初始化,查询读取。
最常用的MCU外设之一。
yiy| | 2024-2-28 16:06 | 只看该作者
ADC具备中断功能吗
xinpian101| | 2024-2-28 20:26 | 只看该作者
使能时钟,使能中断。
