有谁知道RxMessage在哪个文件里定义的?
3399|1
motor666|  楼主 | 2012-5-16 13:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我搜索不到RxMessage这个结构体,谁能告诉我在哪个文件里?
捡漏王子| | 2012-5-23 13:49 | 只看该作者
CanRxMsg RxMessage;
typedef struct
  uint32_t StdId;  /*!< Specifies the standard identifier.
                        This parameter can be a value between 0 to 0x7FF. */
  uint32_t ExtId;  /*!< Specifies the extended identifier.
                        This parameter can be a value between 0 to 0x1FFFFFFF. */
  uint8_t IDE;     /*!< Specifies the type of identifier for the message that will be received.
                        This parameter can be a value of @ref CAN_identifier_type */
  uint8_t RTR;     /*!< Specifies the type of frame for the received message.
                        This parameter can be a value of @ref CAN_remote_transmission_request */
  uint8_t DLC;     /*!< Specifies the length of the frame that will be received.
                        This parameter can be a value between 0 to 8 */
  uint8_t Data[8]; /*!< Contains the data to be received. It ranges from 0 to 0xFF. */
  uint8_t FMI;     /*!< Specifies the index of the filter the message stored in the mailbox passes through.
                        This parameter can be a value between 0 to 0xFF */
} CanRxMsg;
