AC78406 多个串口中断失效
2691|0
 楼主| newphj 发表于 2024-3-23 13:54 | 显示全部楼层 |阅读模式
各位前辈好。第一次用AC78406芯片。使用uart0 uart1中断接受不定长数据。单个串口可以接收了。两个串口同时使用只有先初始化的那个串口可以进入中断。请问哪里配置有问题吗?代码是用AutoGen Studio生成的。#include "string.h"
#include "ckgen_drv.h"
#include "gpio_drv.h"
#include "gpio_hw.h"
#include "uart_drv.h"
#include "uart_hw.h"
#include "uart_irq.h"
#include "dma_drv.h"
#include "gpio.h"
#include "drv_comm.h"
#include "FreeRTOS.h"
#include "event_groups.h"
#include "ac7840x_irq_cb.h"
#define RECELENGTHMAX 1024
static uart_state_t s_uart0State = {NULL}; /*UART运行变量状态*/
static uart_state_t s_uart1State = {NULL}; /*UART运行变量状态*/
static uart_user_config_t uart0Config;
static uart_user_config_t uart1Config;
static unsigned char g_receive0Data = 0;
static unsigned short int g_receive0Data_count = 0;
static unsigned char receive0Data_group[RECELENGTHMAX = {0};
static unsigned char g_receive1Data = 0;
static unsigned short int g_receive1Data_count = 0;
static unsigned char receive1Data_group[RECELENGTHMAX = {0};
EventGroupHandle_t EventGroupHandle_uart = NULL;
* @brief This function handle UART0 rx interrupt.
* @param[in] driverState: callback parameter
* @param[in] event: callback parameter
* @param[in] userData: callback parameter
* @return none
void UART0_RX_IRQHandler_Callback(void *driverState, uint32_t event, void *userData)
    /* USER CODE BEGIN UART0_RX_IRQHandler_Callback */
    if (event == UART_EVENT_RX_FULL)
        // xEventGroupSetBits(EventGroupHandle_uart1, EVENT_UART1_RX);
        receive0Data_group[g_receive0Data_count = g_receive0Data;
        g_receive0Data_count++;
        if (g_receive0Data_count >= RECELENGTHMAX)
    UART_DRV_ReceiveData(0, &g_receive0Data, 1);
    /* USER CODE END UART0_RX_IRQHandler_Callback */
* @brief This function handle UART1 rx interrupt.
* @return none
void UART1_RX_IRQHandler_Callback(void *driverState, uint32_t event, void *userData)
    /* USER CODE BEGIN UART1_RX_IRQHandler_Callback */
        receive1Data_group[g_receive1Data_count = g_receive1Data;
        g_receive1Data_count++;
        if (g_receive1Data_count >= RECELENGTHMAX)
    UART_DRV_ReceiveData(1, &g_receive1Data, 1);
    /* USER CODE END UART1_RX_IRQHandler_Callback */
/* UART0 init function */
static void ATC_UART0_Init(void)
    memset(&uart0Config, 0, sizeof(uart0Config));
        GPIO Configuration for UART0
        PB1         --> UART0_TX
        PB0         --> UART0_RX
    GPIO_DRV_SetMuxModeSel(PORTB, 1, PORT_MUX_ALT2);
    GPIO_DRV_SetMuxModeSel(PORTB, 0, PORT_MUX_ALT2);
    /* UART0 interrupt1 Init */
    NVIC_SetPriority(UART0_IRQn, 0);
    NVIC_EnableIRQ(UART0_IRQn);
    uart0Config.baudRate = 38400;
    uart0Config.parityMode = UART_PARITY_DISABLED;
    uart0Config.stopBitCount = UART_ONE_STOP_BIT;
    uart0Config.bitCountPerChar = UART_8_BITS_PER_CHAR;
    uart0Config.transferType = UART_USING_INTERRUPTS;
    uart0Config.rxCallback = UART0_RX_IRQHandler_Callback;
    UART_DRV_Init(0, &s_uart0State, &uart0Config);
    /* USER CODE BEGIN UART0_Init 2 */
    /* USER CODE END UART0_Init 2 */
/* UART1 init function */
static void ATC_UART1_Init(void)
    memset(&uart1Config, 0, sizeof(uart1Config));
         GPIO Configuration for UART1
         PC9         --> UART1_TX
         PC8         --> UART1_RX
    GPIO_DRV_SetMuxModeSel(PORTC, 9, PORT_MUX_ALT2);
    GPIO_DRV_SetMuxModeSel(PORTC, 8, PORT_MUX_ALT2);
    /* UART1 interrupt1 Init */
    NVIC_SetPriority(UART1_IRQn, 1);
    NVIC_EnableIRQ(UART1_IRQn);
    uart1Config.baudRate = 38400;
    uart1Config.parityMode = UART_PARITY_DISABLED;
    uart1Config.stopBitCount = UART_ONE_STOP_BIT;
    uart1Config.bitCountPerChar = UART_8_BITS_PER_CHAR;
    uart1Config.transferType = UART_USING_INTERRUPTS;
    uart1Config.rxCallback = UART1_RX_IRQHandler_Callback;
    UART_DRV_Init(1, &s_uart1State, &uart1Config);
    /* USER CODE BEGIN UART1_Init 2 */
    /* USER CODE END UART1_Init 2 */
void drv_comm_init(void)
    memset(receive0Data_group, 0, sizeof(receive0Data_group));
    memset(receive1Data_group, 0, sizeof(receive1Data_group));
    EventGroupHandle_uart = xEventGroupCreate();
    ATC_UART0_Init();
    ATC_UART1_Init();
void drv_comm_write(unsigned char *p_data, unsigned char length)
void drv_comm_read(void)
