[N32G430] 【N32G430C8L7开发板体验】+SPI外设通讯速度测试
3409|5
 楼主| suncat0504 发表于 2024-4-7 13:21 | 显示全部楼层 |阅读模式
根据用户手册,SPI接口的最高速度,在主模式下可以达到28 Mbps(不带CRC),20Mbps(带CRC),从模式可以达到32Mbps。
按照这个说明,启动SPI的通讯例程,选择的是SPI_INT例程,为了能顺利捕捉波形,稍微修改了代码,是SPI的收发处理一直被循环。
Main处理被修改为:
  1. int main(void)
  3.     /* At this stage the microcontroller clock setting is already configured,
  4.        this is done through SystemInit() function which is called from startup
  5.        file (startup_N32G430.s) before to branch to application main.
  6.        To reconfigure the default setting of SystemInit() function, refer to
  7.        system_N32G430.c file
  8.      */
  9.     /* System clocks configuration ---------------------------------------------*/
  10.     RCC_Configuration();
  11.     /* GPIO configuration ------------------------------------------------------*/
  12.     GPIO_Configuration();
  13.
  14.     NVIC_Configuration();
  15.     /* log configuration ------------------------------------------------------*/
  16.     log_init();
  17.     log_info("This is SPI INT demo!\r\n");
  18.     /* SPI_MASTER configuration ------------------------------------------------------*/
  19.     SPI_Initializes_Structure(&SPI_InitStructure);
  20.     SPI_InitStructure.DataDirection = SPI_DIR_SINGLELINE_TX;
  21.     SPI_InitStructure.SpiMode       = SPI_MODE_MASTER;
  22.     SPI_InitStructure.DataLen       = SPI_DATA_SIZE_16BITS;
  23.     SPI_InitStructure.CLKPOL        = SPI_CLKPOL_LOW;
  24.     SPI_InitStructure.CLKPHA        = SPI_CLKPHA_SECOND_EDGE;
  25.     SPI_InitStructure.NSS           = SPI_NSS_HARD;
  26.     /* It is recommended that the SPI master mode of the C version chips should not exceed 18MHz */
  27.     SPI_InitStructure.BaudRatePres  = SPI_BR_PRESCALER_8;
  28.     SPI_InitStructure.FirstBit      = SPI_FB_MSB;
  29.     SPI_InitStructure.CRCPoly       = 7;
  30.     SPI_Initializes(SPI_MASTER, &SPI_InitStructure);
  31.     SPI_SS_Output_Enable(SPI_MASTER);
  32.     /* SPI_SLAVE configuration ------------------------------------------------------*/
  33.     SPI_InitStructure.SpiMode = SPI_MODE_SLAVE;
  34.     SPI_InitStructure.DataDirection = SPI_DIR_SINGLELINE_RX;
  35.     SPI_Initializes(SPI_SLAVE, &SPI_InitStructure);
  36.     /* Enable the master and slave SPI interrupts ----------------------------------*/
  37.     SPI_I2S_Interrupts_Enable(SPI_MASTER, SPI_I2S_INT_TE);
  38.     SPI_I2S_Interrupts_Enable(SPI_SLAVE, SPI_I2S_INT_RNE);
  39.     /* Enable SPI_SLAVE */
  40.     SPI_ON(SPI_SLAVE);
  41.     /* Enable SPI_MASTER */
  42.     SPI_ON(SPI_MASTER);
  43.     /* Transfer procedure */
  44.     while (RxIdx < BufferSize);
  45.
  46.     /* Check the received data with the send ones */
  47.     TransferStatus = Buffercmp(SPI_Slave_Buffer_Rx, SPI_Master_Buffer_Tx, BufferSize);
  48.     if(TransferStatus == PASSED) {
  49.         log_info("Test PASS!\r\n");
  50.     } else {
  51.         log_info("Test ERR!\r\n");
  52.     }
  53.     TxIdx = 0;
  54.     RxIdx = 0;
  55.     SPI_I2S_Data_Transmit(SPI1, SPI_Master_Buffer_Tx[0]);
  56.
  57.     while(1) {
  58.         /* Transfer procedure */
  59.         while (RxIdx < 1);
  60.         // 为了测试发送速度,不断重复发送
  61.         TxIdx = 0;
  62.         RxIdx = 0;
  63.         SPI_I2S_Data_Transmit(SPI1, SPI_Master_Buffer_Tx[0]);
  64.     }
  65. }
中断处理被改为:
  1. /**
  2. *\*\name    SPI1_IRQHandler.
  3. *\*\fun     This function handles SPI1 Handler.
  4. *\*\param   none
  5. *\*\return  none
  6. **/
  7. void SPI1_IRQHandler(void) {
  8.     if(SPI_I2S_Interrupt_Flag_Status_Get(SPI1, SPI_I2S_INT_FLAG_TE) != RESET) {
  9.         /* Send SPI_MASTER data */
  10.         SPI_I2S_Data_Transmit(SPI1, SPI_Master_Buffer_Tx[TxIdx++]);
  11.         if(TxIdx == BufferSize) {
  12.             /* Disable SPI_MATER TXE interrupt */
  13.             //SPI_I2S_Interrupts_Disable(SPI1, SPI_I2S_INT_TE);
  14.         }
  15.     }
  16. }
  17. /**
  18. *\*\name    SPI2_IRQHandler.
  19. *\*\fun     This function handles SPI2 Handler.
  20. *\*\param   none
  21. *\*\return  none
  22. **/
  23. void SPI2_IRQHandler(void) {
  24.     if(SPI_I2S_Interrupt_Flag_Status_Get(SPI2, SPI_I2S_INT_FLAG_RNE) == SET) {
  25.         /* Store SPI_SLAVE received data */
  26.         SPI_Slave_Buffer_Rx[RxIdx++] = SPI_I2S_Data_Get(SPI2);
  27.     }
  28. }
然后测试,捕捉的通讯SCK脉冲波形如下:
波形不是方波,时钟周期是120ns的样子,确实比用GPIO模拟的方式快啊,差别很明显。
weifeng90 发表于 2024-4-7 19:27 来自手机 | 显示全部楼层
这肯定的啊,软件模拟怎么能比硬件快。
 楼主| suncat0504 发表于 2024-4-7 22:26 | 显示全部楼层
这肯定的啊,软件模拟怎么能比硬件快。
确实快,但是时钟波形和预想的方波差太多了。差点以为自己的示波器出了问题。哈哈哈。
chenqianqian 发表于 2024-4-8 07:57 来自手机 | 显示全部楼层
因为SPI是边沿采样捕获数据
戈壁滩中的辉煌 发表于 2024-4-8 11:42 | 显示全部楼层
这要是驱动屏幕效果也是不错的
黑心单片机 发表于 2024-4-10 15:03 | 显示全部楼层
在用这款,巨好用
认证:大连伊飞特信息技术有限公司软件工程师
简介:本人于1993年毕业于大连理工大学。毕业后从事单片机开发工作5年,之后转入软件开发工作至今。
158
