[技术问答] C语言实现A*算法
1909|2
 楼主| modesty3jonah 发表于 2024-5-22 20:00 | 显示全部楼层 |阅读模式
  1. /*******************************************************************************
  2. * Description: A*寻路算法 测试类
  3. *******************************************************************************/
  4. #include <stdlib.h>
  5. #include <stdio.h>
  6. #include <math.h>
  7. #define FALSE   0
  8. #define TRUE    1
  9. #define NULL    0
  10. typedef int BOOL;
  11.
  12. int map[20][20] =
  13. {
  14.     { 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0 },
  15.     { 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 0 },
  16.     { 1, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0 },
  17.     { 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  18.     { 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  19.     { 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  20.     { 0, 0, 0, 1, 0, 1, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  21.     { 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  22.     { 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  23.     { 0, 0, 0, 1, 0, 1, 0, 1, 1, 1, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  24.     { 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  25.     { 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 0, 0, 0, 0 },
  26.     { 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0 },
  27.     { 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 0, 0, 0 },
  28.     { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0 },
  29.     { 0, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0 },
  30.     { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0 },
  31.     { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0 },
  32.     { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 0 },
  33.     { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }
  34. };
  35.     typedef struct Node
  36.     {//节点结构体
  37.         int f,g,h;
  38.         int row;    //该节点所在行
  39.         int col;    //该节点所在列
  40.         int direction;//parent节点要移动的方向就能到达本节点
  41.         struct Node * parent;
  42.     }Node, *Lnode;
  43.
  44.     typedef struct Stack
  45.     {//OPEN CLOSED 表结构体
  46.         Node * npoint;
  47.         struct Stack * next;
  48.     }Stack, *Lstack;
  49.     int rows = 20;          //地图行数
  50.     int cols = 20;          //地图列数
  51.     int G_OFFSET = 1;       //每个图块G值的增加值
  52.     int destinationRow;     //目标所在行
  53.     int destinationCol;     //目标所在列
  54.     int canMoveIndex = 0;   //可以通行的地图图块索引
  55.     int tileSize = 1;       //图块大小
  56.
  57.     Lstack Open = NULL;
  58.     Lstack Closed = NULL;
  59.     Node * getNodeFromOpen()
  60.     {//选取OPEN表上f值最小的节点,返回该节点地址
  61.         Lstack temp = Open->next,min = Open->next,minp = Open;
  62.         Node * minx;
  63.         if( temp == NULL )
  64.             return NULL;
  65.
  66.         while(temp->next != NULL)
  67.         {
  68.             if( (temp->next ->npoint->f) < (min->npoint->f) )
  69.             {
  70.                 min = temp->next;
  71.                 minp = temp;
  72.             }
  73.             temp = temp->next;
  74.         }
  75.         minx = min->npoint;
  76.         temp = minp->next;
  77.         minp->next = minp->next->next;
  78.         free(temp);
  79.         return minx;
  80.     }
  81.
  82.     BOOL Equal(Node * suc,Node * goal)
  83.     {//判断节点是否相等,相等,不相等
  84.         if ( (suc->row == goal->row) && (suc->col == goal->col)  )
  85.         {
  86.             return TRUE;
  87.         }
  88.         else
  89.         {
  90.             return FALSE;
  91.         }
  92.     }
  93.
  94.     Node * BelongInOpen( Node * suc )
  95.     {//判断节点是否属于OPEN表或CLOSED表,是则返回节点地址,否则返回空地址
  96.         Lstack temp = Open -> next ;
  97.         if(temp == NULL)
  98.             return NULL;
  99.         while( temp != NULL )
  100.         {
  101.             if( Equal(suc,temp->npoint) )
  102.             {
  103.                 return temp -> npoint;
  104.             }
  105.             else
  106.             {
  107.                 temp = temp->next;
  108.             }
  109.         }
  110.         return NULL;
  111.     }
  112.
  113.     Node * BelongInClosed( Node * suc )
  114.     {//判断节点是否属于OPEN表或CLOSED表,是则返回节点地址,否则返回空地址
  115.         Lstack temp = Closed -> next ;
  116.         if(temp == NULL)
  117.             return NULL;
  118.         while(temp != NULL)
  119.         {
  120.             if( Equal(suc,temp->npoint) )
  121.             {
  122.                 return temp -> npoint;
  123.             }
  124.             else
  125.             {
  126.                 temp = temp->next;
  127.             }
  128.         }
  129.         return NULL;
  130.     }
  131.
  132.     void PutintoOpen(Node * suc )
  133.     {//把节点放入OPEN 或CLOSED 表中
  134.         Stack * temp;
  135.         temp =(Stack *) malloc(sizeof(Stack));
  136.         temp->npoint = suc;
  137.
  138.         temp->next = Open->next;
  139.         Open->next = temp;
  140.     }
  141.     void PutintoClosed(Node * suc )
  142.     {//把节点放入OPEN 或CLOSED 表中
  143.         Stack * temp;
  144.         temp =(Stack *) malloc(sizeof(Stack));
  145.         temp->npoint = suc;
  146.         temp->next = Closed->next;
  147.         Closed->next = temp;
  148.     }
  149.
  150.     //得到该图块的H值
  151.     int getH(int row, int col)
  152.     {
  153.         return (abs(destinationRow - row) + abs(destinationCol - col));
  154.     }
  155.
  156.     //得到该位置所在地图行
  157.     int getRowPosition(int y)
  158.     {
  159.         return (y / tileSize);
  160.     }
  161.
  162.     //得到该位置所在地图列
  163.     int getColPosition(int x)
  164.     {
  165.         return (x / tileSize);
  166.     }
  167.     //检测该图块是否可通行
  168.     BOOL isCanMove(int col, int row)
  169.     {
  170.         if(col < 0 || col >= cols)
  171.             return FALSE;
  172.         if(row < 0 || row >= rows)
  173.             return FALSE;
  174.         return map[col][row] == canMoveIndex;
  175.     }
  176.
  177.     Node* checkOpen(int row, int col)
  178.     {
  179.         Lstack temp = Open -> next;
  180.         if ( temp == NULL )
  181.             return NULL;
  182.         while (temp != NULL)
  183.         {
  184.             if ( (temp->npoint->row==row) && (temp->npoint->col == col)  )
  185.             {
  186.                 return temp -> npoint;
  187.             }
  188.             else
  189.             {
  190.                 temp = temp->next;
  191.             }
  192.         }
  193.         return NULL;
  194.     }
  195.
  196.     BOOL isInClose(int row, int col)
  197.     {
  198.         Lstack temp = Closed -> next;
  199.         if ( temp == NULL )
  200.             return FALSE;
  201.         while (temp != NULL)
  202.         {
  203.             if ( (temp->npoint->row==row) && (temp->npoint->col == col)  )
  204.             {
  205.                 return TRUE;
  206.             }
  207.             else
  208.             {
  209.                 temp = temp->next;
  210.             }
  211.         }
  212.         return FALSE;
  213.     }
  214.     int directionIndex =0;
  215.     int direction[256];
  216.     void creatSeccessionNode(Node *bestNode, int row, int col)
  217.     {
  218.         int g = bestNode->g + G_OFFSET;
  219.         if(!isInClose(row, col))
  220.         {
  221.             Node *oldNode = NULL;
  222.             if((oldNode = checkOpen(row, col)) != NULL)
  223.             {
  224.                 if(oldNode->g < g)
  225.                 {
  226.                     oldNode->parent = bestNode;
  227.                     oldNode->g = g;
  228.                     oldNode->f = g + oldNode->h;
  229.                 }
  230.             }
  231.             else
  232.             {
  233.                 Node *node = (Node *) malloc(sizeof(Node));
  234.                 node->parent = bestNode;
  235.                 node->g = g;
  236.                 node->h = getH(row, col);
  237.                 node->f = node->g + node->h;
  238.                 node->row = row;
  239.                 node->col = col;
  240.                 directionIndex++;
  241.                 node->direction = directionIndex;
  242. //              openNode.addElement(node);
  243.                 PutintoOpen( node );
  244.             }
  245.         }
  246.     }
  247.
  248.     /**
  249.      * 根据传入的节点生成子节点
  250.      * @param bestNode
  251.      * @param destinationRow
  252.      * @param destinationCol
  253.      */
  254.     void seachSeccessionNode(Node *bestNode)
  255.     {
  256.         int row, col;
  257. //      Node *bestNodeInOpen = NULL;
  258.         //上部节点
  259.         if(isCanMove(row = bestNode->row - 1, col = bestNode->col))
  260.         {
  261.             creatSeccessionNode(bestNode, row, col);
  262.         }
  263.         //下部节点
  264.         if(isCanMove(row = bestNode->row + 1, col = bestNode->col))
  265.         {
  266.             creatSeccessionNode(bestNode, row, col);
  267.         }
  268.         //左部节点
  269.         if(isCanMove(row = bestNode->row, col = bestNode->col - 1))
  270.         {
  271.             creatSeccessionNode(bestNode, row, col);
  272.         }
  273.         //右部节点
  274.         if(isCanMove(row = bestNode->row, col = bestNode->col + 1))
  275.         {
  276.             creatSeccessionNode(bestNode, row, col);
  277.         }
  278.         PutintoClosed( bestNode );
  279.     }
  280.     //正序遍历链表
  281.     void printfOpenData()
  282.     {//判断节点是否属于OPEN表或CLOSED表,是则返回节点地址,否则返回空地址
  283.         Lstack temp = Open -> next;
  284.         Node *p_node;
  285.         if(temp == NULL)
  286.             return;
  287.         while(temp != NULL)
  288.         {
  289.             Lstack head = temp;
  290.             temp = temp->next;
  291.             p_node = head->npoint;
  292.             printf("Open库数据![%d,%d]\n", p_node->col, p_node->row );
  293.             free(p_node);
  294.             free( head );
  295.             Open->next = temp;
  296.         }
  297.         printf("\n Open库数据 数据全部清楚 \n");
  298.         return;
  299.     }
  300.     void printfClosedData()
  301.     {//判断节点是否属于OPEN表或CLOSED表,是则返回节点地址,否则返回空地址
  302.         Lstack temp = Closed -> next ;
  303.         Node *p_node;
  304.         if(temp == NULL)
  305.             return;
  306.         while(temp != NULL)
  307.         {
  308.             Lstack head = temp;
  309.             temp = temp->next;
  310.             p_node = head->npoint;
  311.             printf("Closed库数据![%d,%d]\n", p_node->col, p_node->row );
  312.             free(p_node);
  313.             free( head );
  314.             Closed -> next = temp;
  315.         }
  316.         printf("\n Closed库数据 数据全部清楚 \n");
  317.         /*
  318.         temp = Closed -> next;
  319.         while(temp != NULL)
  320.         {
  321.             printf("Closed库数据!节点");
  322.             temp = temp->next;
  323.         }*/
  324.         return;
  325.     }
  326. void getPath(int startX, int StartY, int destinationX, int destinationY)
  327. {
  328.     Node *startNode = (Node *) malloc(sizeof(Node));
  329.     Node *bestNode  = NULL;
  330.     int index = 0;
  331.     destinationRow = getRowPosition(destinationY);
  332.     destinationCol = getColPosition(destinationX);
  333.
  334.     startNode->parent= NULL;
  335.     startNode->row = getRowPosition(StartY);
  336.     startNode->col = getColPosition(startX);
  337.     startNode->g = 0;
  338.     startNode->h = getH( startNode->row, startNode->col );
  339.     startNode->f = startNode->g + startNode->h;
  340.     startNode->direction = 0;
  341.     PutintoOpen( startNode );// openNode.add(startNode);
  342.
  343.     while(TRUE)
  344.     {
  345.         bestNode = getNodeFromOpen(); //从OPEN表中取出f值最小的节点
  346.         if(bestNode == NULL)//未找到路径
  347.         {
  348.             printf("未找到路径\n");
  349.             return;
  350.         }
  351.         else if(bestNode->row == destinationRow
  352.                 && bestNode->col == destinationCol )
  353.         {
  354.             Node *_Node = bestNode;
  355.             int nodeSum = 0;
  356.             int nodeIndex =0;
  357.             printf("程序运行次数=%d\n",index);
  358.             while( _Node->parent != NULL )
  359.             {
  360.                 printf("x:%d  y:%d  direction = %d \n", _Node->col, _Node->row, _Node->direction );
  361.                 _Node = _Node->parent;
  362.                 nodeSum += 1;
  363.             }
  364.             printf("节点数量=%d\n",nodeSum);
  365.             _Node = bestNode;
  366.             nodeIndex = nodeSum-1;
  367.             while( _Node->parent != NULL && nodeIndex>=0)
  368.             {
  369.                 Node *_NodeParent = _Node->parent;
  370.                 printf("x:%d  y:%d  direction = %d \n", _Node->col, _Node->row, _Node->direction );
  371.                 if( _NodeParent->col - _Node->col == 0 && _NodeParent->row - _Node->row == +1 )
  372.                 {//从父节点到本节点的操作是  上
  373.                     direction[nodeIndex] = 1;
  374.                 }
  375.                 else if( _NodeParent->col - _Node->col == 0 && _NodeParent->row - _Node->row == -1 )
  376.                 {//从父节点到本节点的操作是  下
  377.                     direction[nodeIndex] = 2;
  378.                 }
  379.                 else if( _NodeParent->col - _Node->col == +1 && _NodeParent->row - _Node->row == 0 )
  380.                 {//从父节点到本节点的操作是  左
  381.                     direction[nodeIndex] = 3;
  382.                 }
  383.                 else if( _NodeParent->col - _Node->col == -1 && _NodeParent->row - _Node->row == 0 )
  384.                 {//从父节点到本节点的操作是  右
  385.                     direction[nodeIndex] = 4;
  386.                 }
  387.                 else
  388.                 {
  389.                     direction[nodeIndex] = 0;
  390.                 }
  391.                 nodeIndex -= 1;
  392.                 _Node = _Node->parent;
  393.             }
  394.             for( nodeIndex=0; nodeIndex<nodeSum; nodeIndex++ )
  395.             {
  396.                 printf("direction[%d]=%d\n",nodeIndex,direction[nodeIndex]);
  397.             }
  398.             return ;
  399.         }
  400.         index++;
  401.         seachSeccessionNode(bestNode);
  402.     }
  403. }
  404. void main()
  405. {//主函数
  406.     //初始操作,建立open和closed表
  407.     Open = (Stack *) malloc(sizeof(Stack));
  408.     Open->next = NULL;
  409.     Closed = (Stack *) malloc(sizeof(Stack));
  410.     Closed->next = NULL;
  411. //-----------------------------------
  412.     getPath( 0, 0, 19, 19 );
  413.     printf("程序认定该起始状态无法道达目标状态!\n");
  414.
  415.     printfOpenData();
  416.     printfClosedData();
  417.     free(Open);
  418.     free(Closed);
  419. //--------------------------------------
  420. }
勇敢的大白菜 发表于 2024-5-23 10:16 | 显示全部楼层
寻路算法应该使用在扫地机器人上比较多吧
自己造声卡 发表于 2024-5-24 10:11 | 显示全部楼层
自动寻路功能,应该是扫地机器人上使用的多一些
