[STM32F3] 利用 STM32CubeMX 生成初始化代码
1003|3
 楼主| 和下土 发表于 2024-7-2 08:41 | 显示全部楼层 |阅读模式
cr315 发表于 2024-7-2 15:15 | 显示全部楼层
你想说啥
菜鸟的第一步 发表于 2024-7-10 15:40 | 显示全部楼层
用这个软件生成初始的工程很方便
wang6623 发表于 2024-7-30 20:41 | 显示全部楼层
是要这个代码吗?
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
int main(void)
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  /* Infinite loop */
  while (1)
  * @brief System Clock Configuration
  * @retval None
  // Clock configuration code generated by STM32CubeMX
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_RESET);
  /*Configure GPIO pin : PC13 */
  GPIO_InitStruct.Pin = GPIO_PIN_13;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
