[DemoCode下载] 最新2023版N76E003的BSP开发包,支持SDCC编译器
868|0
 楼主| wahahaheihei 发表于 2024-7-10 10:12 | 显示全部楼层 |阅读模式
N76E003_BSP.zip (9.18 MB, 下载次数: 10)
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* SPDX-License-Identifier: Apache-2.0        */
  4. /* Copyright(c) 2023 Nuvoton Technology Corp. All rights reserved.                                         */
  5. /*        */
  6. /*---------------------------------------------------------------------------------------------------------*/
  7. #include "numicro_8051.h"
  8. /******************************
  9.   * [url=home.php?mod=space&uid=247401]@brief[/url]     Main loop.
  10.   * @param[in] None.
  11.   * [url=home.php?mod=space&uid=266161]@return[/url]    None.
  12.   * MG51 power down code for test power down current, BOD disabled.
  13. ******************************/
  14. void main (void)
  15. {
  16. /* UART0 settting for printf function */
  17.     MODIFY_HIRC(HIRC_166);
  18.     Enable_UART0_VCOM_printf_166M_115200();
  19.     printf ("\n Test start ...");
  20. /* Quasi mode better for power down power comsuption (necessary) */
  21.     ALL_GPIO_QUASI_MODE;
  22.     P0=0;
  23.     P1=0;
  24.     P2=0;
  25. /* clock only for reference, real chip please don't output clock (necessary)*/
  26.     set_CKCON_CLOEN;
  27. /*MUST Disable BOD to low power (necessary) */
  28.     BOD_DISABLE;              //BOD enable power down current please check datasheet DC charactor.
  29. /* Real into power down mode (necessary) */
  30.     set_PCON_PD;
  31.     while(1);
  32.
  33. }
