- * File Name: cycfg_peripherals.c
- * Description:
- * Peripheral Hardware Block configuration
- * This file was automatically generated and should not be modified.
- * Configurator Backend 3.20.0
- * device-db 4.16.0.6098
- * mtb-pdl-cat1 3.11.0.34443
- * Copyright 2024 Cypress Semiconductor Corporation (an Infineon company) or
- * an affiliate of Cypress Semiconductor Corporation.
- * SPDX-License-Identifier: Apache-2.0
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- #include "cycfg_peripherals.h"
- #define tcpwm_0_group_1_cnt_5_INPUT_DISABLED 0x7U
- const cy_stc_tcpwm_pwm_config_t tcpwm_0_group_1_cnt_5_config =
- .pwmMode = CY_TCPWM_PWM_MODE_PWM,
- .clockPrescaler = CY_TCPWM_PWM_PRESCALER_DIVBY_1,
- .pwmAlignment = CY_TCPWM_PWM_LEFT_ALIGN,
- .deadTimeClocks = 0,
- .runMode = CY_TCPWM_PWM_CONTINUOUS,
- .period0 = 32768,
- .period1 = 32768,
- .enablePeriodSwap = false,
- .compare0 = 16384,
- .compare1 = 16384,
- .enableCompareSwap = false,
- .interruptSources = (CY_TCPWM_INT_ON_TC & 0U) | (CY_TCPWM_INT_ON_CC0 & 0U) | (CY_TCPWM_INT_ON_CC1 & 0U),
- .invertPWMOut = CY_TCPWM_PWM_INVERT_DISABLE,
- .invertPWMOutN = CY_TCPWM_PWM_INVERT_DISABLE,
- .killMode = CY_TCPWM_PWM_STOP_ON_KILL,
- .swapInputMode = tcpwm_0_group_1_cnt_5_INPUT_DISABLED & 0x3U,
- .swapInput = CY_TCPWM_INPUT_0,
- .reloadInputMode = tcpwm_0_group_1_cnt_5_INPUT_DISABLED & 0x3U,
- .reloadInput = CY_TCPWM_INPUT_0,
- .startInputMode = tcpwm_0_group_1_cnt_5_INPUT_DISABLED & 0x3U,
- .startInput = CY_TCPWM_INPUT_0,
- .killInputMode = tcpwm_0_group_1_cnt_5_INPUT_DISABLED & 0x3U,
- .killInput = CY_TCPWM_INPUT_0,
- .countInputMode = tcpwm_0_group_1_cnt_5_INPUT_DISABLED & 0x3U,
- .countInput = CY_TCPWM_INPUT_1,
- .swapOverflowUnderflow = false,
- .immediateKill = false,
- .tapsEnabled = 45,
- .compare2 = 16384,
- .compare3 = 16384,
- .enableCompare1Swap = false,
- .compare0MatchUp = true,
- .compare0MatchDown = false,
- .compare1MatchUp = true,
- .compare1MatchDown = false,
- .kill1InputMode = tcpwm_0_group_1_cnt_5_INPUT_DISABLED & 0x3U,
- .kill1Input = CY_TCPWM_INPUT_0,
- .pwmOnDisable = CY_TCPWM_PWM_OUTPUT_HIGHZ,
- .trigger0Event = CY_TCPWM_CNT_TRIGGER_ON_DISABLED,
- .trigger1Event = CY_TCPWM_CNT_TRIGGER_ON_DISABLED,
- .reloadLineSelect = false,
- .line_out_sel = CY_TCPWM_OUTPUT_PWM_SIGNAL,
- .linecompl_out_sel = CY_TCPWM_OUTPUT_INVERTED_PWM_SIGNAL,
- .line_out_sel_buff = CY_TCPWM_OUTPUT_PWM_SIGNAL,
- .linecompl_out_sel_buff = CY_TCPWM_OUTPUT_INVERTED_PWM_SIGNAL,
- .deadTimeClocks_linecompl_out = 0,
- #if defined (CY_IP_MXS40TCPWM)
- .hrpwm_enable = false,
- .hrpwm_input_freq = CY_TCPWM_HRPWM_FREQ_80MHZ_OR_100MHZ,
- .kill_line_polarity = CY_TCPWM_LINEOUT_AND_LINECMPOUT_IS_LOW,
- .deadTimeClocksBuff = 0,
- .deadTimeClocksBuff_linecompl_out = 0,
- .buffer_swap_enable = false,
- .glitch_filter_enable = false,
- .gf_depth = CY_GLITCH_FILTER_DEPTH_SUPPORT_VALUE_0,
- .dithering_mode = CY_TCPWM_DITHERING_DISABLE,
- .period_dithering_value = 128,
- .duty_dithering_value = 128,
- .limiter = CY_TCPWM_DITHERING_LIMITER_7,
- #endif /* defined (CY_IP_MXS40TCPWM) */
- #if defined (CY_USING_HAL) || defined(CY_USING_HAL_LITE)
- const cyhal_resource_inst_t tcpwm_0_group_1_cnt_5_obj =
- .type = CYHAL_RSC_TCPWM,
- .block_num = 1U,
- .channel_num = 5U,
- #endif /* defined (CY_USING_HAL) || defined(CY_USING_HAL_LITE) */
- #if defined(CY_USING_HAL_LITE) || defined (CY_USING_HAL)
- const cyhal_clock_t tcpwm_0_group_1_cnt_5_clock =
- .block = CYHAL_CLOCK_BLOCK_PERIPHERAL1_16BIT,
- .channel = 0,
- .reserved = false,
- .funcs = NULL,
- #endif /* defined (CY_USING_HAL) */
- #endif /* defined(CY_USING_HAL_LITE) || defined (CY_USING_HAL) */
- const cyhal_pwm_configurator_t tcpwm_0_group_1_cnt_5_hal_config =
- .resource = &tcpwm_0_group_1_cnt_5_obj,
- .config = &tcpwm_0_group_1_cnt_5_config,
- .clock = &tcpwm_0_group_1_cnt_5_clock,
- void init_cycfg_peripherals(void)
- #if defined (CY_DEVICE_CONFIGURATOR_IP_ENABLE_FEATURE)
- Cy_SysClk_PeriGroupSlaveInit(CY_MMIO_TCPWM0_PERI_NR, CY_MMIO_TCPWM0_GROUP_NR, CY_MMIO_TCPWM0_SLAVE_NR, CY_MMIO_TCPWM0_CLK_HF_NR);
- #endif /* defined (CY_DEVICE_CONFIGURATOR_IP_ENABLE_FEATURE) */
- Cy_SysClk_PeriphAssignDivider(PCLK_TCPWM0_CLOCK_COUNTER_EN261, CY_SYSCLK_DIV_16_BIT, 0U);
- void reserve_cycfg_peripherals(void)
- cyhal_hwmgr_reserve(&tcpwm_0_group_1_cnt_5_obj);
四、实物展示
