[技术问答] 这是一种I2C的自发自收吗
1431|4
 楼主| gejigeji521 发表于 2024-9-9 22:08 | 显示全部楼层 |阅读模式
I2c, AD, ck, se, TE
  1. /******************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Revision: 4 $
  5. * $Date: 18/07/09 7:03p $
  6. * @brief
  7. *           Show how to use I2C Single byte API Read and Write data to Slave.
  8. *           This sample code needs to work with I2C_Slave.
  9. * @note
  10. * SPDX-License-Identifier: Apache-2.0
  11. * Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
  12. *****************************************************************************/
  13. #include <stdio.h>
  14. #include "NuMicro.h"
  15. #define TEST_LENGTH    256
  16. /*---------------------------------------------------------------------------------------------------------*/
  17. /* Global variables        */
  18. /*---------------------------------------------------------------------------------------------------------*/
  19. volatile uint8_t g_u8DeviceAddr;
  20. void SYS_Init(void)
  21. {
  22.     /*---------------------------------------------------------------------------------------------------------*/
  23.     /* Init System Clock        */
  24.     /*---------------------------------------------------------------------------------------------------------*/
  25.     /* Unlock protected registers */
  26.     SYS_UnlockReg();
  27.     /* Enable HIRC clock (Internal RC 48MHz) */
  28.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  29.     /* Wait for HIRC clock ready */
  30.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  31.     /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
  32.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  33.     /* Enable UART0 clock */
  34.     CLK_EnableModuleClock(UART0_MODULE);
  35.     /* Switch UART0 clock source to HIRC */
  36.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
  37.     /* Enable I2C0 clock */
  38.     CLK_EnableModuleClock(I2C0_MODULE);
  39.     /* Update System Core Clock */
  40.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and cyclesPerUs automatically. */
  41.     SystemCoreClockUpdate();
  42.     /*---------------------------------------------------------------------------------------------------------*/
  43.     /* Init I/O Multi-function        */
  44.     /*---------------------------------------------------------------------------------------------------------*/
  45.     /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
  46.     SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
  47.                     (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
  48.     /* Set I2C0 multi-function pins */
  49.     SYS->GPB_MFPL = (SYS->GPB_MFPL & ~(SYS_GPB_MFPL_PB4MFP_Msk | SYS_GPB_MFPL_PB5MFP_Msk)) |
  50.                     (SYS_GPB_MFPL_PB4MFP_I2C0_SDA | SYS_GPB_MFPL_PB5MFP_I2C0_SCL);
  51.     /* Lock protected registers */
  52.     SYS_LockReg();
  53. }
  54. void I2C0_Init(void)
  55. {
  56.     /* Open I2C module and set bus clock */
  57.     I2C_Open(I2C0, 100000);
  58.     /* Get I2C0 Bus Clock */
  59.     printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
  60.     /* Set I2C 4 Slave Addresses */
  61.     I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
  62.     I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
  63.     I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
  64.     I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
  65. }
  66. void I2C0_Close(void)
  67. {
  68.     /* Disable I2C0 interrupt and clear corresponding NVIC bit */
  69.     I2C_DisableInt(I2C0);
  70.     NVIC_DisableIRQ(I2C0_IRQn);
  71.     /* Disable I2C0 and close I2C0 clock */
  72.     I2C_Close(I2C0);
  73.     CLK_DisableModuleClock(I2C0_MODULE);
  74. }
  75. int main()
  76. {
  77.     uint32_t i;
  78.     uint8_t u8data, u8tmp, err;
  79.     SYS_Init();
  80.     /* Init UART0 to 115200-8n1 for print message */
  81.     UART_Open(UART0, 115200);
  82.     /*
  83.         This sample code sets I2C bus clock to 100kHz. Then, Master accesses Slave with Byte Write
  84.         and Byte Read operations, and check if the read data is equal to the programmed data.
  85.     */
  86.     printf("+--------------------------------------------------------+\n");
  87.     printf("| I2C Driver Sample Code for Single Byte Read/Write Test |\n");
  88.     printf("| Needs to work with I2C_Slave sample code               |\n");
  89.     printf("|                                                        |\n");
  90.     printf("| I2C Master (I2C0) <---> I2C Slave(I2C0)                |\n");
  91.     printf("| !! This sample code requires two borads to test !!     |\n");
  92.     printf("+--------------------------------------------------------+\n");
  93.     printf("\n");
  94.     printf("Configure I2C0 as Master\n");
  95.     printf("The I/O connection to I2C0\n");
  96.     printf("I2C0_SDA(PB.4), I2C0_SCL(PB.5)\n\n");
  97.     /* Init I2C0 */
  98.     I2C0_Init();
  99.     /* Slave Address */
  100.     g_u8DeviceAddr = 0x15;
  101.     err = 0;
  102.     for(i = 0; i < TEST_LENGTH; i++)
  103.     {
  104.         u8tmp = (uint8_t)i + 3;
  105.         /* Single Byte Write (Two Registers) */
  106.         while(I2C_WriteByteTwoRegs(I2C0, g_u8DeviceAddr, i, u8tmp));
  107.         /* Single Byte Read (Two Registers) */
  108.         u8data = I2C_ReadByteTwoRegs(I2C0, g_u8DeviceAddr, i);
  109.         if(u8data != u8tmp)
  110.         {
  111.             err = 1;
  112.             printf("%03d: Single byte write data fail,  W(0x%X)/R(0x%X) \n", i, u8tmp, u8data);
  113.         }
  114.     }
  115.     printf("\n");
  116.     if(err)
  117.         printf("Single byte Read/Write access Fail.....\n");
  118.     else
  119.         printf("Single byte Read/Write access Pass.....\n");
  120.     while(1);
  121. }
  122. /*** (C) COPYRIGHT 2018 Nuvoton Technology Corp. ***/
 楼主| gejigeji521 发表于 2024-9-9 22:09 | 显示全部楼层
看到的示例,有设置四个从机的地址,然后又发送,又使用刚才设置的从机地址接收。。。
 楼主| gejigeji521 发表于 2024-9-9 22:11 | 显示全部楼层
循环里面还对写入和读取的数据进行比对,不同就报错。那么这个示例是自己发自己收吗,一个芯片就能实现?那么总线上只有这一个设备?
AloneKaven 发表于 2024-9-11 21:29 | 显示全部楼层
这个是演示demo吗
花开了相爱吧 发表于 2025-8-30 13:38 | 显示全部楼层
I2C 自发自收指同一设备既作主机发送数据,又作从机接收自身发出的数据,用于测试 I2C 通信链路是否正常,验证硬件和协议正确性。
