[STM32F1]
stm32的虚拟usb读FIFO和写FIFO
556|0
febgxu|  楼主 | 2024-9-19 17:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Includes ------------------------------------------------------------------*/
#include "usb_lib.h"
#include "usb_prop.h"
#include "usb_desc.h"
#include "hw_config.h"
#include "usb_pwr.h"
#include "Queue.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
USART_InitTypeDef USART_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
#define USB_COM_RX_BUF_SIZE         (1024 + 256)
#define USB_COM_TX_BUF_SIZE         (1024 + 256)
static QUEUE8_t m_QueueUsbComRx         = {0};
static QUEUE8_t m_QueueUsbComTx         = {0};
static uint8_t  m_UsbComRxBuf[USB_COM_RX_BUF_SIZE]      = {0};
static uint8_t  m_UsbComTxBuf[USB_COM_TX_BUF_SIZE]      = {0};
static void IntToUnicode (uint32_t value , uint8_t *pbuf , uint8_t len);
/* Extern variables ----------------------------------------------------------*/
extern LINE_CODING linecoding;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : Set_System
* Description    : Configures Main system clocks & power
* Input          : None.
* Return         : None.
void Set_System(void)
  QUEUE_PacketCreate(&m_QueueUsbComRx, m_UsbComRxBuf, sizeof(m_UsbComRxBuf));
  QUEUE_PacketCreate(&m_QueueUsbComTx, m_UsbComTxBuf, sizeof(m_UsbComTxBuf));
  /* Enable USB_DISCONNECT GPIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIO_DISCONNECT, ENABLE);
  /* Configure USB pull-up pin */
  GPIO_InitStructure.GPIO_Pin = USB_DISCONNECT_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(USB_DISCONNECT, &GPIO_InitStructure);
  /* Configure the EXTI line 18 connected internally to the USB IP */
  EXTI_ClearITPendingBit(EXTI_Line18);
  EXTI_InitStructure.EXTI_Line = EXTI_Line18;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
* Function Name  : Set_USBClock
* Description    : Configures USB Clock input (48MHz)
* Input          : None.
* Return         : None.
void Set_USBClock(void)
  /* Select USBCLK source */
  RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
  /* Enable the USB clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB, ENABLE);
* Function Name  : Enter_LowPowerMode
* Description    : Power-off system clocks and power while entering suspend mode
* Input          : None.
* Return         : None.
void Enter_LowPowerMode(void)
  /* Set the device state to suspend */
  bDeviceState = SUSPENDED;
* Function Name  : Leave_LowPowerMode
* Description    : Restores system clocks and power while exiting suspend mode
* Input          : None.
* Return         : None.
void Leave_LowPowerMode(void)
  DEVICE_INFO *pInfo = &Device_Info;
  /* Set the device state to the correct state */
  if (pInfo->Current_Configuration != 0)
    /* Device configured */
    bDeviceState = CONFIGURED;
  else
    bDeviceState = ATTACHED;
  /*Enable SystemCoreClock*/
//  SystemInit();
* Function Name  : USB_Interrupts_Config
* Description    : Configures the USB interrupts
* Input          : None.
* Return         : None.
void USB_Interrupts_Config(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
    /* Enable the USB Wake-up interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USBWakeUp_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
* Function Name  : USB_Cable_Config
* Description    : Software Connection/Disconnection of USB Cable
* Input          : None.
* Return         : Status
void USB_Cable_Config (FunctionalState NewState)
  if (NewState == DISABLE)
    GPIO_ResetBits(USB_DISCONNECT, USB_DISCONNECT_PIN);
  else
    GPIO_SetBits(USB_DISCONNECT, USB_DISCONNECT_PIN);
* Function Name : void USB_Config(void)
* Description   : USB系统初始化
* Input         :
* Output        :
* Other         :
* Date          : 2014.11.28
    Set_System();
    Set_USBClock();
    USB_Interrupts_Config();
    USB_Init();
* Function Name : uint32_t USB_RxRead(uint8_t *buffter, uint32_t buffterSize)
* Description   : 从USB接收缓存中读数据
* Input         :
* Output        :
* Other         :
* Date          : 2014.11.28
    return QUEUE_PacketOut(&m_QueueUsbComRx, buffter, buffterSize);
* Function Name : uint32_t USB_RxWrite(uint8_t *buffter, uint32_t writeLen)
* Description   : 写数据到USB接收缓存中
* Input         :
* Output        :
* Other         :
* Date          : 2014.11.28
    return QUEUE_PacketIn(&m_QueueUsbComRx, buffter, writeLen);
* Function Name : uint32_t USB_TxRead(uint8_t *buffter, uint32_t buffterSize)
* Description   : 从USB发送缓存中读数据
* Input         :
* Output        :
* Other         :
* Date          : 2014.11.28
    return QUEUE_PacketOut(&m_QueueUsbComTx, buffter, buffterSize);;
* Function Name : uint32_t USB_TxWrite(uint8_t *buffter, uint32_t writeLen)
* Description   : 写数据到USB发送缓存中
* Input         :
* Output        :
* Other         :
* Date          : 2014.11.28
    return QUEUE_PacketIn(&m_QueueUsbComTx, buffter, writeLen);
* Function Name  : Get_SerialNum.
* Description    : Create the serial number string descriptor.
* Input          : None.
* Output         : None.
* Return         : None.
void Get_SerialNum(void)
  uint32_t Device_Serial0, Device_Serial1, Device_Serial2;
  Device_Serial0 = *(uint32_t*)ID1;
  Device_Serial1 = *(uint32_t*)ID2;
  Device_Serial2 = *(uint32_t*)ID3;
  Device_Serial0 += Device_Serial2;
  if (Device_Serial0 != 0)
    IntToUnicode (Device_Serial0, &Virtual_Com_Port_StringSerial[2] , 8);
    IntToUnicode (Device_Serial1, &Virtual_Com_Port_StringSerial[18], 4);
* Function Name  : HexToChar.
* Description    : Convert Hex 32Bits value into char.
* Input          : None.
* Output         : None.
* Return         : None.
  uint8_t idx = 0;
  for( idx = 0 ; idx < len ; idx ++)
    if( ((value >> 28)) < 0xA )
      pbuf[ 2* idx] = (value >> 28) + '0';
    else
      pbuf[2* idx] = (value >> 28) + 'A' - 10;
    value = value << 4;
    pbuf[ 2* idx + 1] = 0;
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
