INTEL 8253,读数据问题
2140|2
 楼主| max0147 发表于 2012-5-29 12:36 | 显示全部楼层 |阅读模式
INTEL 8253,可以正常写入控制字,并输出正确波形;想要读出计数值,但一写入锁存命令,即RL0,RL1都=0时,正常波形也没有了,读出数值始终为0;
调整时序;在读之前加入控制判断GATE都无效,遂请教,多谢。
#include <reg52.h>     //包括一个52标准内核的头文件
#include <intrins.h>
#include <stdio.h>
sbit A0 = P0^0;
sbit A1 = P0^1;
sbit nWR = P0^2;
sbit nRD = P0^3;
sbit nCS = P0^4;
sbit gate = P2^4;
void init_82c54(void)
        A0 = 1;
        A1 = 1;
        nWR = 1;
        nRD = 1;
        nCS = 1;
        gate = 1;
void write_cntl_82c54(unsigned char cnt_no,unsigned char mode)
        unsigned char cntl_byte;
        cntl_byte = 0;
        A0 = 1;
        A1 = 1;
        //SC位
        if(cnt_no==0) {cntl_byte &= 0x3f;}
        else if(cnt_no==1) {cntl_byte &= 0x3f; cntl_byte |= 0x40;}
        else if(cnt_no==2) {cntl_byte &= 0x3f; cntl_byte |= 0x80;}
        //RW位
        cntl_byte &= 0xcf;
        cntl_byte |= 0x10;
        //MODE位
        if(mode==2) {cntl_byte &= 0xf9; cntl_byte |= 0x04;}
        else if(mode==3) {cntl_byte &= 0xf9; cntl_byte |= 0x06;}
        //BCD位
        cntl_byte &= 0xfe;
        //写入
        P1 = cntl_byte;
        nCS = 0;
        nWR = 0;
        _nop_();
        nWR = 1;
        nCS = 1;
void write_data_82c54(unsigned char cnt_no,unsigned char indata)
    //选择counter
        if(cnt_no==0) {A0 = 0; A1 = 0;}
        else if(cnt_no==1) {A0 = 1; A1 = 0;}
        else if(cnt_no==2) {A0 = 0; A1 = 1;}
        //写入
        P1 = indata;
        nCS = 0;
        nWR = 0;
        _nop_();
        nWR = 1;
        nCS = 1;
        A0 = 1;
        A1 = 1;
unsigned char read_data_82c54(unsigned char cnt_no)
        unsigned char read_byte;
        cntl_byte = 0;
        A0 = 1;
        A1 = 1;
    //gate = 0;
//counter latch模式
        //SC位
        //D5,D4位
        cntl_byte &= 0xcf;
        //写入
        P1 = cntl_byte;
        nCS = 0;
        nWR = 0;
        _nop_();
        nWR = 1;
        nCS = 1;
此处写锁在命令,一执行后,正常输出波形就没有了。
        //while(1);
//读总线
        _nop_();
        _nop_();
    //选择counter
        nCS = 0;
        nRD = 0;
        _nop_();
        _nop_();
        //读出
        read_byte = P1;
        _nop_();
        nRD = 1;
        nCS = 1;
        return read_byte;
void main(void)        // 主程序
        uchar c1,c2;
    //system_init(); //系统初始化
        init_82c54();
        write_cntl_82c54(0,3);
        write_data_82c54(0,0x55);
                //write_cntl_82c54(0,3);
                //write_data_82c54(0,0x55);
        Delay400Ms();
        P3 = read_data_82c54(0);
 楼主| max0147 发表于 2012-5-30 00:20 | 显示全部楼层
欢迎探讨
 楼主| max0147 发表于 2012-5-30 12:37 | 显示全部楼层
up..................
