[MM32软件] RingBuffer模型
792|0
 楼主| kkzz 发表于 2024-10-31 20:19 | 显示全部楼层 |阅读模式
typedef  unsigned char  BYTE;
template<unsigned int N  /*容量(字节数)*/>
class RingBuffer {
public:
    typedef size_t   size_type;
    typedef GenericLocker<CriticalSection>  _BufferLocker;
    RingBuffer() : m_pushPos(0), m_popPos(0), m_count(0) {
        assert(N > 0);
        m_pRingBuffer = new BYTE[N];
    ~RingBuffer() { delete []m_pRingBuffer; }
    RingBuffer(const RingBuffer<N>& copy) : m_popPos(0) {
        assert(N > 0);
        size_type rearLen = N - copy.m_popPos;
        if (rearLen >= copy.m_count) {
              ::memmove(m_pRingBuffer,
                                  &copy.m_pRingBuffer[copy.m_popPos],
                                  copy.m_count);
        else {
                                  rearLen);
              ::memmove(m_pRingBuffer + rearLen,
                                  copy.m_pRingBuffer,
                                  copy.m_count - rearLen);
        m_pushPos = m_count = copy.m_count;
    RingBuffer& operator=(const RingBuffer<N>& other) {
        if (this != &other) {
              _BufferLocker guard(m_mutex);
              RingBuffer<N> temp(other);        // invoke copy constructor
              _Swap(temp);                      // this->_Swap();
        return (*this);
    bool is_full() const {
        return (m_count == N);
    bool is_empty() const {
        return (m_count == 0);
    size_type size() const {
        return m_count;
    size_type capacity() const { return N; }
    size_type push(const BYTE *data, size_type length) {
        assert(data != NULL);
        if (length == 0 || length > (N - m_count))
            return 0;
        size_type rearLen = N - m_pushPos;    // 尾部剩余空间
        if (length <= rearLen) {
            ::memmove(&m_pRingBuffer[m_pushPos], data, length);
            m_pushPos += length;
            m_pushPos %= N;              // 调整新的push位置
        }else{
            ::memmove(&m_pRingBuffer[m_pushPos], data, rearLen);
            ::memmove(m_pRingBuffer, data + rearLen, length - rearLen);
            m_pushPos = length - rearLen;    // 调整新的push位置
        m_count += length;
        return (length);
    size_type pop(BYTE *buf, size_type length) {
        assert(buf != NULL);
        if (length == 0 || length > m_count)
            return 0;
        size_type rearLen = N - m_popPos;    // 尾部剩余数据
            ::memmove(buf, &m_pRingBuffer[m_popPos], length);
            m_popPos += length;
            m_popPos %= N;             // 调整新的pop位置
        }else {
            ::memmove(buf, &m_pRingBuffer[m_popPos], rearLen);
            ::memmove(buf + rearLen, m_pRingBuffer, length - rearLen);
            m_popPos = length - rearLen;    // 调整新的pop位置
        m_count -= length;
        return (length);
    void clear() {
        m_pushPos = 0, m_popPos = 0, m_count = 0;
private:
    BYTE                *m_pRingBuffer;     // buffer
    size_type           m_pushPos;          // 新的push位置:pushPos=
                                                            // (popPos+count)% N
    size_type           m_popPos;           // 新的pop位置
    size_type           m_count;              // 有效字节数
    CriticalSection  m_mutex;
