GD32E230 串口1 PA2 PA3无法使用
8048|10
 楼主| fanxiaochong 发表于 2024-11-14 15:20 | 显示全部楼层 |阅读模式
GD32E230的datasheet中可以看到PA2和PA3是可以复用到USART1的,然后使用官方的例程,将官方例程默认引进从串口0中的PA9、PA10可以打印。
请教一下有没有人知道PA2、PA3怎么当串口1使用?
以下是官方例程,我将引脚宏定义改成PA2和PA3, 串口0也改为了串口1:
usart.h文件
#define Print_GPIO_RCU                        RCU_GPIOA           //串口对应GPIO端口的时钟
#define Print_USART_RCU                            RCU_USART1           //对应串口号的时钟
#define Print_GPIO                            GPIOA               //串口对应GPIO端口
#define Print_GPIO_AF                      GPIO_AF_1      //串口是GPIO引脚的复用功能1(查询芯片数据手册)
#define Print_TX_PIN                                GPIO_PIN_2     //串口对应的GPIO引脚
#define Print_RX_PIN                        GPIO_PIN_3     //串口对应的GPIO引脚
#define Print_USART                                   USART1         //print所使用的串口1
usart.c文件
//串口打印初始化
void usart_print_init(void)
    usart_print_gpio_init();
    usart_print_config();
    \brief      initilize the com GPIO
    \param[in]  none
    \param[out] none
    \retval     none
void usart_print_gpio_init(void)
    /* enable Print GPIO clock */
    rcu_periph_clock_enable(Print_GPIO_RCU);
    /* connect port to USARTx_Tx */
    gpio_af_set(Print_GPIO, Print_GPIO_AF, Print_TX_PIN);
    /* connect port to USARTx_Rx */
    gpio_af_set(Print_GPIO, Print_GPIO_AF, Print_RX_PIN);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(Print_GPIO, GPIO_MODE_AF, GPIO_PUPD_PULLUP, Print_TX_PIN);
    gpio_mode_set(Print_GPIO, GPIO_MODE_AF, GPIO_PUPD_PULLUP, Print_RX_PIN);
    /* configure USART Rx as alternate function push-pull */
    gpio_output_options_set(Print_GPIO, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, Print_TX_PIN);
    gpio_output_options_set(Print_GPIO, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, Print_RX_PIN);
    \brief      initilize the USART configuration of the com
    \param[in]  none
    \param[out] none
    \retval     none
void usart_print_config(void)
    /* enable USART clock */
    rcu_periph_clock_enable(Print_USART_RCU);
    /* USART configure */
    usart_deinit(Print_USART);
    usart_word_length_set(Print_USART, USART_WL_8BIT);
    usart_stop_bit_set(Print_USART, USART_STB_1BIT);
    usart_parity_config(Print_USART, USART_PM_NONE);
    usart_baudrate_set(Print_USART, 115200U);
    usart_receive_config(Print_USART, USART_RECEIVE_ENABLE);
    usart_transmit_config(Print_USART, USART_TRANSMIT_ENABLE);
    usart_enable(Print_USART);
并且,我将usart.h文件中的宏改为以下,串口0的PA8 PA9就可以正常打印输出了,不知道为什么配置串口1就不行,并且我查看了复用关系都是为1;
#define Print_USART_RCU                        RCU_USART0           //对应串口号的时钟
#define Print_TX_PIN                    GPIO_PIN_9             //串口对应的GPIO引脚
#define Print_RX_PIN             GPIO_PIN_10             //串口对应的GPIO引脚
#define Print_USART                    USART0                 //print所使用的串口1
lingyang1 发表于 2024-11-14 17:59 | 显示全部楼层
lingyang1 发表于 2024-11-14 18:03 | 显示全部楼层
学习一下
lingyang1 发表于 2024-11-14 18:10 | 显示全部楼层
学习一下
probedog 发表于 2024-11-20 11:26 | 显示全部楼层
建议查看GD32E230的数据手册
classroom 发表于 2024-11-20 14:00 | 显示全部楼层
在相关的头文件(如usart.h)中,修改与串口1相关的引脚宏定义,将PA9和PA10(默认用于USART1)更改为PA2和PA3。
laocuo1142 发表于 2024-11-20 15:00 | 显示全部楼层
检查初始化串口配置
flycamelaaa 发表于 2024-11-20 20:00 | 显示全部楼层
晶振出现频偏或不稳定
powerantone 发表于 2024-11-20 23:00 | 显示全部楼层
检查是否有任何短路或断路情况。
ccaichiyu 发表于 2024-12-20 15:57 | 显示全部楼层
我也遇到了这个问题,你解决了吗?
Amazingxixixi 发表于 2024-12-27 15:29 | 显示全部楼层
下载接口都是需要重新设置的。
