MSP430溢出求助,const是放在哪里的?
6834|3
楼主新手,使用msp430F5418时遇到一个const溢出的问题,向大牛求助
程序如下:
if(lcd_timeout_lock == 0)
       switch(lcd_layout_index)
         case 0:                /*clear screen*/
         halLcdClear();
         break;
         case 1:                /*先画标题*/                                      echoZHString(LAYOUT_MENU_TITLE_X,LAYOUT_MENU_TITLE_Y,gScreen.title);
         break;
         case 2:
//这里打印输出2个字时,IAR编译可以通过,多于2个字就会出现溢出
          echoZHString(1,2,"确认");   //液晶显示
           break;
           default:
                                        mlib_task_FreeTask(TASK_ID_FLUSH_MSCREEN);
                                        pro_task_mutex_set(TASK_ID_FLUSH_MSCREEN, 0);
             break;
              lcd_layout_index++;
正常情况下编译:
(单个.c文件的程序大小)
   IAR C/C++ Compiler V5.10.1.20144/W32, Evaluation edition for MSP430
   Copyright 1996-2010 IAR Systems AB.
4 374 bytes of CODE  memory
1 375 bytes of CONST memory
   243 bytes of DATA  memory
Errors: none
Warnings: none
总程序大小:
     IAR Universal Linker V4.61T/W32
     Copyright (C) 1987-2010 IAR Systems AB.
37 188 bytes of CODE  memory (+ 342 absolute )
12 501 bytes of DATA  memory (+ 132 absolute )
  4 696 bytes of CONST memory
Errors: none
Warnings: none
Total number of errors: 0
Total number of warnings: 0
编译出错情况下:
单个.C文件
1 376 bytes of CONST memory  //只在这里多了1个byte
Errors: none
Warnings: none
出错记录:
Error[e18]: Range error,
Number out of range. Valid range is -32768 (-0x8000) to 65535 (0xFFFF).
File: C:\Documents and Settings\Moose W. Oler\桌面\TDC_v2.0\V1.0\cstartup.s43, Line: 159
Source:         MOV     #SFB COD
  Where $ = ?cstart_init_copy_ramfunc + 0x6  [0x5D6E]
            in module "?cstart" (C:\Documents and Settings\Moose W. Oler\桌面TDC_v2.0\Debug\Obj\
cstartup.r43),
            offset 0x6 in segment part 12, segment CSTART
  What: 0 + SFB(CODE_ID) [0x100FE]
  Allowed range: 0xFFFF8000 - 0xFFFF
  Operand: #no label found# [0x100fe]
           in module ?cstart (C:\Documents and Settings\Moose W. Oler\桌面TDC_v2.0\Debug\Obj\
cstartup.r43),
           Offset 0x0 in segment part 6, segment CODE_ID
Error while running Linker
Total number of errors: 1
各位不吝赐教,谢谢了!
ayb_ice| | 2012-5-30 16:03 | 只看该作者
下图是IAR EW8051的设置,430应该也有设置见右下角
flyindance8564|  楼主 | 2012-5-30 16:21 | 只看该作者
2# ayb_ice
谢谢了,问题已解决,改个大小就行了!
flyindance8564|  楼主 | 2012-5-30 16:27 | 只看该作者
const和code一起是存放在flash中的,IAR中设置为SMALL时,会限制他们的大小,就会导致溢出
我现在是这样想的
