background:
1: my board is the same with the nRF52832-CIAA Reference Layout 1_0 from nordic docs.
2: the source code is from sample code: blinky_led
3: only change the led0 to led1
#define LED0_NODE DT_ALIAS(led0)
to
#define LED0_NODE DT_ALIAS(led1)
My question is that:
1: seems that the output reg is right (at least the reg value can be change with my control), but the measured voltage is always 3.3V with multimeter.
2: whether below reg value can show all info about gpio P0.18 ?
the reg value is below when control high.
CNF[18] = 0X00000003
OUT = 0X00040060 // Here changed, bit 18 to 1
IN = 0X002001C0
DIR = 0X00040060
LATVCH = 0X0
DETECTMODE = 0X0
the reg value is below when control LOW.
OUT = 0X00000060 // Here changed,bit 18 to 0
IN = 0X002001C0
DIR = 0X00040060
LATVCH = 0X0
DETECTMODE = 0X0 |
