极海32F030芯片读写保护时,没找到xx32F0xx Flash_OPT.FLM文件
3745|0
 楼主| ababABCD 发表于 2025-1-24 09:53 | 显示全部楼层 |阅读模式
#define OB_BASE               ((uint32_t)0x1FFFF800)        /*!< FLASH Option Bytes base address */#define OB                  ((OB_TypeDef *) OB_BASE)
FLASH_Status FLASH_OB_Erase(void)
  uint16_t rdptmp = OB_RDP_Level_0;
  FLASH_Status status = FLASH_COMPLETE;
  /* Get the actual read protection Option Byte value */
  if(FLASH_OB_GetRDP() != RESET)
    rdptmp = 0x00;
  /* Wait for last operation to be completed */
  status = FLASH_WaitForLastOperation(FLASH_ER_PRG_TIMEOUT);
  if(status == FLASH_COMPLETE)
    /* If the previous operation is completed, proceed to erase the option bytes */
    FLASH->CR |= FLASH_CR_OPTER;
    FLASH->CR |= FLASH_CR_STRT;
      /* If the erase operation is completed, disable the OPTER Bit */
      FLASH->CR &= ~FLASH_CR_OPTER;
      /* Enable the Option Bytes Programming operation */
      FLASH->CR |= FLASH_CR_OPTPG;
      /* Restore the last read protection Option Byte value */
      OB->RDP = (uint16_t)rdptmp;
      if(status != FLASH_TIMEOUT)
        /* if the program operation is completed, disable the OPTPG Bit */
        FLASH->CR &= ~FLASH_CR_OPTPG;
    else
      if (status != FLASH_TIMEOUT)
        /* Disable the OPTPG Bit */
  /* Return the erase status */
  return status;
请问有用过极海的读保护的吗,这个OPT.FLM文件去哪找
