[电池电源管理] SH367309中颖单片机专用动力电池保护板开发资料 原理图PCB代码
5191|8
 楼主| tpgf 发表于 2025-3-5 08:50 | 显示全部楼层 |阅读模式
1、简介
中颖BMS5-16 串 前端芯片,用于充电管理+电池保护+电量计量,有规格书,原理图,PCB, DEMO CODE全套开发资料 。
2、原理图和PCB
3、程序
#include "system.h"
#include "Uart.h"
#include "Main.h"
void main(void)
        Initial();                                        //Initialize the system
        while(1)
                RSTSTAT = RSTSTAT;
                  if(bAFE**)
                         bAFE** = 0;
                        AFERdFlag();
                if((ucResetFlag==0x12) && bUartSndAck**)        //Software reset occurs, and ended UART communication
                        if(!bWrFlash**)
                                EA = 0;
                                ResetAFE();                                                //Reset IC
                                ResetInit();                                        //Reset MCU
                if(bWakeup**)                                                //The charger / load, keys can wake up the system
                        bWakeup** = 0;
                        WakeUpProcess();                                //System to be awakened
                if(bBleOnOff**)                                        //按键长按5秒开启/关闭蓝牙
                        bBleOnOff** = 0;
                        BleOnorOff();
                BleDisplay();
                if(bCADC**)
                        bCADC** = 0;
                        CurProcess();                                        //Calculate the current value and determines the state of charge and discharge
                if(bCalibration**)
                        bCalibration** = 0;
                        CaliProcess();                                        //PC calibration
                if((bWrFlash**)&&(ucUpDataLimitTime == 0))
                        bWrFlash** = 0;
                        if(FlashProcess())
                                if(bUartNeedAck**)
                                        UART_SEND_ACK;
                        else
                                if(bUartNeedAck**)
                                        UART_SEND_NACK;
                        bUartNeedAck** = 0;
                if(bLEDOpen)
                        bLEDOpen = 0;
                        bLED** = 1;
                        ucLEDTimeCnt = 0;
                        LEDPowerOn();                                        //By LED displays battery capacity
                if(bEnEEPRomBK && bE2PProcess**)
                        bE2PProcess** = 0;
                        E2PRomBKProcess();
                if(bISP** && bUartSndAck**)
                        bISP** = 0;
                        ISPProcess();
                if(bTimer**)                                                //timer is 1s
                        bTimer** = 0;
                        AFECheck();                            //Check AFE Register
                        LEDPowerOff();                                        //When the LED display 4s, turn off the LED
                        BatteryInfoManage();                        //Get battery voltage and temperature information
                        RamCheckProcess();                    //Detect the xdata block data
                        GaugeManage();                                        //Calculate the battery charge and discharge capacity
                        VolProcess();                                        //Detection of battery charge and discharge cut-off voltage
                        BalProcess();                                        //Process external voltage balance
                        ProtectProcess();                                //Process battery abnormal state
            if(bEnEEPRomBK)
                            E2PRomBKCheck();                        //Detecting whether to backup EEPRom
                        ShutDownProcess();                                //Detecting whether to enter a low-power
                IntoShutDown();
原文链接:https://blog.csdn.net/qq_35654286/article/details/145109727
jf101 发表于 2025-3-24 08:14 | 显示全部楼层
非常不错的开源案例
中国龙芯CDX 发表于 2025-3-24 23:11 | 显示全部楼层
很赞的开源资料
星辰大海不退缩 发表于 2025-3-27 12:57 | 显示全部楼层
非常不错的资源学习一下
小夏天的大西瓜 发表于 2025-4-13 23:15 | 显示全部楼层
LOVEEVER 发表于 2025-5-26 15:34 | 显示全部楼层
非常不错的开源案例
szt1993 发表于 2025-5-27 11:25 | 显示全部楼层
了解学习一下开源资料
神明祷告 发表于 2025-9-4 13:54 | 显示全部楼层
获取 SH367309 专用资料,需先联系中颖电子官方或授权代理商,签订保密协议后,可获取原理图规范、PCB 布局指南及底层驱动代码参考。
破晓战神 发表于 2025-9-10 20:28 | 显示全部楼层
原理图和PCB代码是电池保护板设计的核心,有没有详细的使用说明或者教程呢?
