我使用以下代码进行内存位置跳转:
JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4);
Jump_To_Application = (pFunction) JumpAddress;
__set_MSP(*(__IO uint32_t*) (APPLICATION_ADDRESS));
Jump_To_Application();
我成功实现了仅使用一个GPIO时的跳转功能,但在引导程序中添加外设后,跳转就不再有效。
参考了某个UART的参考实现(stm32f4xx_hal_uart.c):
HAL_StatusTypeDef HAL_UART_DeInit(UART_HandleTypeDef *huart)
  /* Check the UART handle allocation */
  if (huart == NULL)
    return HAL_ERROR;
  /* Check the parameters */
  assert_param(IS_UART_INSTANCE(huart->Instance));
  huart->gState = HAL_UART_STATE_BUSY;
  /* Disable the Peripheral */
  __HAL_UART_DISABLE(huart);
#if (USE_HAL_UART_REGISTER_CALLBACKS == 1)
  if (huart->MspDeInitCallback == NULL)
    huart->MspDeInitCallback = HAL_UART_MspDeInit;
  /* DeInit the low level hardware */
  huart->MspDeInitCallback(huart);
#else
  HAL_UART_MspDeInit(huart);
#endif /* (USE_HAL_UART_REGISTER_CALLBACKS) */
  huart->ErrorCode = HAL_UART_ERROR_NONE;
  huart->gState = HAL_UART_STATE_RESET;
  huart->RxState = HAL_UART_STATE_RESET;
  huart->ReceptionType = HAL_UART_RECEPTION_STANDARD;
  /* Process Unlock */
  __HAL_UNLOCK(huart);
  return HAL_OK;
我查找HAL_UART_MspDeInit的参考时,出现了以下内容(stm32f4xx_hal_uart.c):
__weak void HAL_UART_MspDeInit(UART_HandleTypeDef *huart)
  /* Prevent unused argument(s) compilation warning */
  UNUSED(huart);
  /* NOTE: This function should not be modified, when the callback is needed,
           the HAL_UART_MspDeInit could be implemented in the user file
还有另一个已实现的参考文件(stm32f4xx_hal_msp.c):
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
  if(huart->Instance==USART1)
  /* USER CODE BEGIN USART1_MspDeInit 0 */
  /* USER CODE END USART1_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_USART1_CLK_DISABLE();
    /**USART1 GPIO Configuration
    PA9     ------> USART1_TX
    PA10     ------> USART1_RX
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9|GPIO_PIN_10);
  /* USER CODE BEGIN USART1_MspDeInit 1 */
  /* USER CODE END USART1_MspDeInit 1 */
