出售维修二手租赁安捷伦86120C多波长计
35|0
szffr123 发表于 2025-11-22 11:05 | 显示全部楼层 |阅读模式
安捷伦86120C多波长计:光谱测量的精密基准
在光通信研发、激光器特性分析及光谱学研究中,对光波长的精确测量是确保系统性能与一致性的关键。安捷伦(Agilent,现为是德科技Keysight)86120C多波长计以其卓越的波长精度、灵活的多通道能力及出色的可靠性,成为光谱测量领域的标志性仪器,广泛服务于激光器制造、光器件测试及前沿科学研究。
为确保此类精密光学仪器持续提供准确可靠的测量数据,专业的校准与维护支持不可或缺。深圳市宝安区沙井方丰瑞仪器设备经营部在光通信测试设备服务领域具备专业能力,可为86120C用户提供全面的技术支持与服务保障。
小    鱼:①⑧⑥~~~②⑥零⑥~~~⑧⑥①⑥(v同)
邓    生:①③⑤~~~①零①⑤~~~②⑧①⑥(v同)
彭经理:①⑤⑧~~~①⑧⑤⑨~~~④零⑧②(v同)
Agilent 86120C Multi-Wavelength Meter: The Precision Benchmark for Optical Spectrum Measurement
In optical communication R&D, laser characterization, and spectroscopic research, precise measurement of optical wavelength is crucial for ensuring system performance and consistency. The Agilent (now Keysight) 86120C Multi-Wavelength Meter, with its exceptional wavelength accuracy, flexible multi-channel capability, and outstanding reliability, has become an iconic instrument in the field of optical spectrum measurement, widely serving laser manufacturing, optical device testing, and cutting-edge scientific research.
To ensure that such precision optical instruments continue to provide accurate and reliable measurement data, professional calibration and maintenance support are indispensable. Shenzhen Bao'an District Shajing Fangfengrui Instrument Equipment Business Department possesses professional capabilities in the field of optical communication test equipment services and can provide comprehensive technical support and service guarantees for 86120C users.
Core Technical Advantages:
  • Ultra-High Precision Measurement
    • Wavelength measurement uncertainty as low as ±0.2 ppm
    • 0.1 pm high resolution for precise analysis of dense wavelength channels
    • Built-in stabilized Helium-Neon laser reference standard
  • Multi-Channel Testing Capability
    • Supports simultaneous measurement of up to 4 input channels (up to 127 wavelengths)
    • Real-time calculation of frequency differences between channels
    • Ideal for DWDM system testing and multi-laser applications
  • Wide Coverage Range
    • Standard wavelength range: 1250-1650 nm
    • Optional extended range: 700-1650 nm
    • Covers O/E/S/C/L bands for fiber communications
  • Excellent Dynamic Performance
    • Power measurement range: +3 dBm to -60 dBm
    • Suitable for both high-power and weak signal testing scenarios
Typical Application Scenarios:
  • DWDM system wavelength monitoring and calibration
  • Tunable laser wavelength characteristic verification
  • Optical filter passband performance testing
  • Optical frequency standard transmission
Professional Service Support:
Shenzhen Bao'an District Shajing Fangfengrui Instrument Equipment Business Department provides:
  • Regular precision calibration services
  • System performance optimization
  • Key component maintenance
  • Application technical support
The Agilent 86120C, with its superior technical performance and stability, provides reliable wavelength measurement solutions for optical communication and laser applications. Through professional technical service support, users can ensure the instrument maintains optimal working condition, providing a solid foundation for research and production.
