求坛友给推荐个DCDC芯片 7V升15V
3049|8
 楼主| 电子乌托邦 发表于 2012-6-29 12:59 | 显示全部楼层 |阅读模式
板子需要15V,100mA电流,
我输入准备用手机锂电池,3.7-4.2V的那种,一块升压到15V有些吃力,
所以我两块串联,就是7.4-8.4V,升压到15V。
求坛友推荐个升压芯片。
价格便宜,外围简单,效率高点。
麻烦大家了。。
草根白骨精 发表于 2012-6-29 14:30 | 显示全部楼层
一节锂电没有问题,两节不好管理,6V的先给你,6V以上的我要找一下放哪里了一节锂电没有问题,两节不好管理,6V的先给你,6V以上的我要找一下放哪里了
草根白骨精 发表于 2012-6-29 14:38 | 显示全部楼层
适合你双节电池的
 楼主| 电子乌托邦 发表于 2012-6-29 18:09 | 显示全部楼层
谢谢   草根白骨精 的回复
我准备用两节锂电串联,用8.4V充电器充电。
挺好管理的啊,为啥说不好管理呢?
难道是因为串联充电?
xuhua1598 发表于 2012-6-30 08:29 | 显示全部楼层
3845就行
wgsxsm 发表于 2012-6-30 10:23 | 显示全部楼层
XC9103
MP3217
trevor2011 发表于 2012-11-29 11:23 | 显示全部楼层
trevor2011 发表于 2012-11-29 11:24 | 显示全部楼层
The TPS61170 is a monolithic, high-voltage switching regulator with integrated 1.2-A, 40-V power MOSFET. It can be configured in several standard switching-regulator topologies, including boost and SEPIC. The device has a wide input-voltage range to support applications with input voltage from multi-cell batteries or regulated 5-V, 12-V power rails.
The TPS61170 operates at a 1.2-MHz switching frequency, allowing the use of low-profile inductors and low-value ceramic input and output capacitors. External loop compensation components give the user flexibility to optimize loop compensation and transient response. The device has built-in protection features, such as pulse-by-pulse overcurrent limit, soft start and thermal shutdown.
The reference voltage to which the FB pin regulates is 1.229V. The reference voltage can be lowered using a 1-wire digital interface (Easyscale™ protocol) through the CTRL pin. Alternatively, a pulse width-modulation (PWM) signal can be applied to the CTRL pin. The duty cycle of the signal reduces the feedback reference voltage proportionally.
The TPS61170 is available in a 6-pin 2 mm × 2 mm QFN package, allowing a compact power-supply solution.
另外,静态电流较小,适用于手持式的电池供电的应用中、
