[AVR单片机] 望TestCode半夜**叫~~~
105749|54
 楼主| hotpower 发表于 2007-8-21 01:30 | 显示全部楼层
interrupt.h
#include "main.h"
#ifdef  __IAR_SYSTEMS_ICC__
#ifndef _SYSTEM_BUILD
#pragma system_include
#endif
#endif
#ifndef __M16_INTERRUPT_H
#define __M16_INTERRUPT_H
#ifdef __cplusplus
extern "C"
#endif
#ifdef __cplusplus
#endif
#endif//__M16_INTERRUPT_H
 楼主| hotpower 发表于 2007-8-21 01:34 | 显示全部楼层
interrupt.cpp(一部分)
#include "interrupt.h"
#pragma vector=INT0_vect
extern "C" __interrupt void Int0ISR(void)
    System.EInt0ExecFlag = 1;
#pragma vector=INT1_vect
extern "C" __interrupt void Int1ISR(void)
    System.EInt1ExecFlag = 1;
#pragma vector=USART_UDRE_vect
extern "C" __interrupt void UartTxUDREISR(void)
    if (Uart.SendWritePtr != Uart.SendReadPtr) {
        UDR = Uart.SendBuffer[Uart.SendReadPtr ++];
        UCSRB |= (1 << UDRIE);
    else
        UCSRB &= ~(1 << UDRIE);
#pragma vector=USART_TXC_vect
extern "C" __interrupt void UartTxISR(void)
#pragma vector=ADC_vect
extern "C" __interrupt void AdcISR(void)
    Adc.Exec ();
#pragma vector=TWI_vect
extern "C" __interrupt void TwiISR(void)
    Twi.Exec ();
testcode 发表于 2007-8-21 01:39 | 显示全部楼层
上面interrupt还是没有整到CPP的类中~~~
 楼主| hotpower 发表于 2007-8-21 01:42 | 显示全部楼层
拍个照~~~
 楼主| hotpower 发表于 2007-8-21 01:46 | 显示全部楼层
哈哈~~~看得仔细~~~因为全是标准的C中断函数~~~
extern "C" __interrupt void xxxISP(void)
//加入各个倒塌的中断处理
 楼主| hotpower 发表于 2007-8-21 01:49 | 显示全部楼层
timer.h
#include "main.h"
#endif
#endif
#ifndef __IARAVR_TIMER_H
#define __IARAVR_TIMER_H
#ifdef __cplusplus
extern "C"
#endif
class TimerObj;
class TimerObj
private:
public:
    TimerObj(void);
    void Init(void);
    void Timer0Init(void);
    void Timer1Init(void);
    void Timer2Init(void);
public:
    unsigned int Count0;
    unsigned int Count1;
    unsigned int Count2;
#ifdef __cplusplus
#endif
#endif//__IARAVR_TIMER_H
testcode 发表于 2007-8-21 01:50 | 显示全部楼层
 楼主| hotpower 发表于 2007-8-21 01:51 | 显示全部楼层
timer.cpp
#include "timer.h"
TimerObj::TimerObj (void)
    Init ();
//inline
void TimerObj::Init(void)
    Timer0Init ();
    Timer1Init ();
    SFIOR |= (1 << PSR10);//
    Timer2Init ();
//inline
void TimerObj::Timer0Init(void)
    Count0 = 0;
    TCNT0 = (unsigned char)(0 - 78); // T/C0 开始值
    TCCR0 = (1 << CS02) | (1 << CS00); // 预分频 ck/1024 ,计数允许
    TIMSK |= (1 << TOIE0);//开中断
//inline
void TimerObj::Timer1Init(void)
    Count1 = 0;
    TIMSK &= ~(1 << TOIE1);//开中断
//inline
void TimerObj::Timer2Init(void)
    Count2 = 0;
    TCCR2 = (1 << CS22) | (0 << CS21)  | (1 << CS20); //分频比128,0x05,TCNT2=0
    TCNT2 = 0;
    ASSR  = 1 << AS2; //异步时钟
    TIMSK |= (1 << TOIE2);//开中断
 楼主| hotpower 发表于 2007-8-21 01:54 | 显示全部楼层
倒塌了~~~上次不是和John_Lee教授用gcc没搞成功吗???
无奈用:
    Adc.Exec ();
    Twi.Exec ();
testcode 发表于 2007-8-21 01:59 | 显示全部楼层
看到一篇介绍,提到
用到virtual inheritance...
有空时再继续努力...
 楼主| hotpower 发表于 2007-8-21 02:08 | 显示全部楼层
倒塌了~~~给个virtual inheritance的应用~~~
 楼主| hotpower 发表于 2007-8-21 02:17 | 显示全部楼层
_21icbbs 发表于 2007-8-21 08:24 | 显示全部楼层
请教老师,IARAVR中的启动文件在哪里修改?
能不能讲讲这个启动文件?
micline 发表于 2007-8-21 08:48 | 显示全部楼层
8错,应该穿条裤子
双龙 发表于 2007-8-21 09:25 | 显示全部楼层
赴某饭局,饭店规定每桌点特价虾只限半斤,我们开玩笑说
要不每人开一桌,点他半斤虾然后拼在一块儿吃。
这里,幸亏楼主在一张桌上吃饭发帖,如果分开了,得送多少条裤子啊。
 楼主| hotpower 发表于 2007-8-21 18:29 | 显示全部楼层
望TestCode半夜**叫~~~
估计他那里才天亮~~~
 楼主| hotpower 发表于 2007-8-22 02:16 | 显示全部楼层
TestCode上线也不来告诉我如何搞中断???
我未果~~~
testcode 发表于 2007-8-23 01:06 | 显示全部楼层
还是未果~~~
玩个倒塌的c++,不考虑代码大小,使用cout输出...
#include <iostream>
#include "Global.h"
#include "Uart.h"
UartObj uart0;
int MyLowLevelPutchar(int x)
   uart0.Transmit(x);
   return 0;
int MyLowLevelGetchar()
  return (uart0.Receive());
int main (void)
        cout << "Start ";
        while(1);
        return  0;
 楼主| hotpower 发表于 2007-8-23 01:25 | 显示全部楼层
俺感觉永远不可能实现~~~
成员函数应该和中断函数是有很大区别的.
成员函数几乎和普通C函数一样,都不能成为中断函数.
拿我们最熟悉和最简单的51来分析就知道我们不可能造出永动机来~~~
51的函数(子程序)在汇编中用ret返回,而中断用reti返回.
另外,有许多MCU/ARM/DSP都是进入中断关中断允许标志,而在退出时自动打开中断允许标志.
在汇编中我们会常常用调用中断函数来搞些小动作,而在C/C++中是不允许的~~~
即不能直接调用中断函数,当然就不能将类的成员函数声明为中断函数了~~~
故才有了ARM/DSP/PC等软中断的做法~~~
综合以上原因---俺上次当gcc avr菜鸟时就已死心~~~没想到TestCode还念叨着~~~
 楼主| hotpower 发表于 2007-8-23 02:19 | 显示全部楼层
adc.h
#include "main.h"
#endif
#endif
#ifndef __M16_ADC_H
#define __M16_ADC_H
#ifdef __cplusplus
extern "C"
#endif
class AdcObj;
class AdcObj {//系统采集类
public:
    AdcObj(void);
    void Exec(void);
private:
    void Init(void);
    void SetAdcChNum(unsigned char);//设置ADC通道变换号
    unsigned char GetAdcChNum(unsigned char);//取ADC通道变换号
public:
    unsigned char AdcChNum;
    unsigned char AdcCount[4];
    unsigned int AdcVal[4];
    unsigned int AdcAkVal[4];
    unsigned int AdcSum[4];
    unsigned int AdcMax[4], AdcMin[4];
#ifdef __cplusplus
#endif
#endif//__M16_ADC_H
