看我的,或许可以参考使用:- /*
- * Update the changed direction of y.
- * There are 4 blocks in one byte,each block own 2 bits.
- * @block_index: which jepg block?
- * @delta_y: y changed.
- void update_y_direction(int block_index, int delta_y)
- int i;
- unsigned char level;
- level = whichlevel(delta_y);
- switch (level) {
- case 0:
- /* NO changing. Update all of the table */
- for (i = 0; i < ALARM_SENSITY_LEVEL_MAX; i++) {
- SET_BYTE_BITS(last_y_direction[i][block_index / 4],
- (block_index % 4) << 1, 2, BLK_Y_NO_CHANGE);
- break;
- #ifdef USING_ALARM_LV5
- case ALARM_SENSITY_LV5:
- SET_BYTE_BITS(last_y_direction[ALARM_SENSITY_LV5 - 1][block_index / 4],
- (block_index % 4) << 1, 2, delta_y > 0 ? BLK_Y_INCREASED : BLK_Y_DECREASED);
- #endif
- #ifdef USING_ALARM_LV4
- case ALARM_SENSITY_LV4:
- SET_BYTE_BITS(last_y_direction[ALARM_SENSITY_LV4 - 1][block_index / 4],
- #endif
- #ifdef USING_ALARM_LV3
- case ALARM_SENSITY_LV3:
- SET_BYTE_BITS(last_y_direction[ALARM_SENSITY_LV3 - 1][block_index / 4],
- #endif
- #ifdef USING_ALARM_LV2
- case ALARM_SENSITY_LV2:
- SET_BYTE_BITS(last_y_direction[ALARM_SENSITY_LV2 - 1][block_index / 4],
- #endif
- #ifdef USING_ALARM_LV1
- case ALARM_SENSITY_LV1:
- SET_BYTE_BITS(last_y_direction[ALARM_SENSITY_LV1 - 1][block_index / 4],
- #endif
- break;
- default:
- ; /* WARNING! */
