我采用轮询方式处理以太网接收。当前 10ms 的轮询周期把数据速率限制在 250KB/s,这个速率对本应用来说足够,但会带来最高 10ms 的延迟。
我想实现当存在新的接收数据时,直接跳过 10ms 等待。这样效果基本等同于中断,该线程运行在高 RTOS 优先级。
但`low_level_input`函数代码很长,会调用`HAL_ETH_GetReceivedFrame`,需要执行大量代码,最后才发现没有任何数据需要处理,白白消耗开销。
是否存在某个 ETH 寄存器位,可以用来快速判断是否收到新数据?
下面就是HAL_ETH_GetReceivedFrame函数;只有在函数末尾,才会判断并返回 “无接收数据”。
HAL_StatusTypeDef HAL_ETH_GetReceivedFrame(ETH_HandleTypeDef *heth)
uint32_t framelength = 0U;
/* Check if segment is not owned by DMA */
__DMB();
if(((heth->RxDesc->Status & ETH_DMARXDESC_OWN) == (uint32_t)RESET))
/* Check if last segment */
if(((heth->RxDesc->Status & ETH_DMARXDESC_LS) != (uint32_t)RESET))
/* increment segment count */
(heth->RxFrameInfos).SegCount++;
/* Check if last segment is first segment: one segment contains the frame */
if ((heth->RxFrameInfos).SegCount == 1U)
(heth->RxFrameInfos).FSRxDesc =heth->RxDesc;
heth->RxFrameInfos.LSRxDesc = heth->RxDesc;
/* Get the Frame Length of the received packet: substruct 4 bytes of the CRC */
framelength = (((heth->RxDesc)->Status & ETH_DMARXDESC_FL) >> ETH_DMARXDESC_FRAMELENGTHSHIFT) - 4U;
heth->RxFrameInfos.length = framelength;
/* Get the address of the buffer start address */
heth->RxFrameInfos.buffer = ((heth->RxFrameInfos).FSRxDesc)->Buffer1Addr;
/* point to next descriptor */
heth->RxDesc = (ETH_DMADescTypeDef*) ((heth->RxDesc)->Buffer2NextDescAddr);
/* Return function status */
return HAL_OK;
/* Check if first segment */
else if((heth->RxDesc->Status & ETH_DMARXDESC_FS) != (uint32_t)RESET)
(heth->RxFrameInfos).FSRxDesc = heth->RxDesc;
(heth->RxFrameInfos).LSRxDesc = NULL;
(heth->RxFrameInfos).SegCount = 1U;
/* Point to next descriptor */
heth->RxDesc = (ETH_DMADescTypeDef*) (heth->RxDesc->Buffer2NextDescAddr);
/* Check if intermediate segment */
else
return HAL_ERROR;
