[STM32H7] 使用HAL 函数,HAL_UART_Receive_IT () 无法接收超过 256 字节数据
20|0
SocialButterfly 发表于 2026-11-21 22:51 | 显示全部楼层 |阅读模式
使用开发板:NUCLEO-H743ZI2,想搞清楚如何利用标准 UART HAL 函数接收 256 字节及以上的数据。
测试函数为 uart_ISR_test (),该函数会持续向`./stm32_impulse_test.py`请求指定长度的数据。
# Load and run test on micro
make swd
# Turn on swo viewer
./swo_parser.py
# Send test data to device
./stm32_impulse_test.py /dev/tty.usbmodem14403
我发现当同时修改 Python 脚本与固件的接收缓冲区大小时,小于 256 字节的数据可以正常接收,但接收 256 字节及以上长度数据时就会出现问题。
## HAL UART 接收缓冲区设为 256-12 字节
I: ************************* Rx *********************************
E: Rx Received (HAL_OK)
I: Got 244 valid bytes
I: Rx :
  0 | 01 02 03 04 05 06 07 08 09 01 02 03 04 05 06 07
16 | 08 09 01 02 03 04 05 06 07 08 09 01 02 03 04 05
32 | 06 07 08 09 01 02 03 04 05 06 07 08 09 01 02 03
48 | 04 05 06 07 08 09 01 02 03 04 05 06 07 08 09 01
64 | 02 03 04 05 06 07 08 09 01 02 03 04 05 06 07 08
80 | 09 01 02 03 04 05 06 07 08 09 01 02 03 04 05 06
96 | 07 08 09 01 02 03 04 05 06 07 08 09 01 02 03 04
112 | 05 06 07 08 09 01 02 03 04 05 06 07 08 09 01 02
128 | 03 04 05 06 07 08 09 01 02 03 04 05 06 07 08 09
144 | 01 02 03 04 05 06 07 08 09 01 02 03 04 05 06 07
160 | 08 09 01 02 03 04 05 06 07 08 09 01 02 03 04 05
176 | 06 07 08 09 01 02 03 04 05 06 07 08 09 01 02 03
192 | 04 05 06 07 08 09 01 02 03 04 05 06 07 08 09 01
208 | 02 03 04 05 06 07 08 09 01 02 03 04 05 06 07 08
224 | 09 01 02 03 04 05 06 07 08 09 01 02 03 04 05 06
240 | 07 08 09 01
## HAL UART 接收缓冲区设为 256+12 字节
E: Rx Timeout (HAL_OK)
E: Got only 12 valid bytes out of 268
I: Rx :
  0 | 01 02 03 04 05 06 07 08 09 01 02 03 01 02 03 04
16 | 05 06 07 08 09 01 02 03 00 00 00 00 00 00 00 00
32 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
48 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
64 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
96 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
112 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
128 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
144 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
176 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
192 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
208 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
224 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
240 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
256 | 00 00 00 00 00 00 00 00 00 00 00 00
## HAL UART 接收缓冲区设为 256 字节
E: Got only 0 valid bytes out of 256
I: Rx :
0 | All 00 (256 Bytes)
顺带,缓冲区大小设为 (256-12) 时,寄存器初始状态如下
I: Uart Test Start
I:  0:        ghwuart_ptr->Instance->CR1 = 0000000D : USART Control register 1
I:  0:        ghwuart_ptr->Instance->CR2 = 00000000 : USART Control register 2
I:  0:        ghwuart_ptr->Instance->CR3 = 00001000 : USART Control register 3
I:  0:        ghwuart_ptr->Instance->BRR = 00000364 : USART Baud rate register
I:  0:       ghwuart_ptr->Instance->GTPR = 00000000 : USART Guard time and prescaler register
I:  0:       ghwuart_ptr->Instance->RTOR = 00000000 : USART Receiver Time Out register
I:  0:        ghwuart_ptr->Instance->RQR = 00000000 : USART Request register
I:  0:        ghwuart_ptr->Instance->ISR = 006000D0 : USART Interrupt and status register
I:  0:       ghwuart_ptr->Instance->PRESC = 00000000 : USART clock Prescaler register
I: (0) USART_CR1_UE bit set : USART Enable
I: (0) USART_CR1_RE bit set : Receiver Enable
I: (0) USART_CR1_TE bit set : Transmitter Enable
I: (0) USART_CR3_OVRDIS bit set : Overrun Disable
然后:
I:  1:        ghwuart_ptr->Instance->ISR = (006000D0 --> 006010D0) : USART Interrupt and status register
I: (1) USART_ISR_EOBF bit set : End Of Block Flag
接收 256 字节时
I: Uart Test Start
I: Rx :
... next rx cycle
I:  1:        ghwuart_ptr->Instance->CR1 = (0000000D --> 0000012D) : USART Control register 1
I:  1:        ghwuart_ptr->Instance->CR3 = (00001000 --> 00001001) : USART Control register 3
I: Rx :
请教大家一般如何处理 UART 接收。是仅仅使用 HAL_UART_Receive_IT (),再把收到的数据送入软件 FIFO 缓冲区吗?
