[STM32H7] 以太网传输大数据时触发硬件错误
21|0
lvluoo 发表于 2026-11-22 22:35 | 显示全部楼层 |阅读模式
我的代码在发送大量数据时会遇到硬件错误问题。程序偶尔可以正常运行,但大多数情况下,在发送约 10000 字节之后就会进入硬件错误。
我需要发送的图像数据大约为 40KB。有意思的是,循环发送 “Hello World” 字符串却可以稳定运行,不会触发故障。我也反复试错调大了 LWIP 相关配置的内存参数,但问题依旧存在。
这个问题已经困扰我好多天了,
uint8_t u1_array[7];
int sockfd1, ret, nbytes, nbytes1;
unsigned char connect, disconnect;
char ServerIP[15], DestinationIP[4] = { 192, 168, 0, 0 };
struct sockaddr_in my_addr;
struct sockaddr_in their_addr;
int increment, freq[10], avg_freq;
double input_voltage, Usys_Low;
unsigned char dutycycle;
extern int door_flag;
char *photo_list[500];
int connect_flag = 0;
#define CHUNK_SIZE 1024  // Define the chunk size (1024 bytes)
int photo_count = 1;
int erase_flag = 0;
int rxBuff;
uint32_t id;
uint32_t size_image = 65535;
unsigned char *photo_arr;
uint32_t photo_index;
bool buffer_copy_flag;
bool send_flag;
size_t startIndex = 7;
int sys_flag=0;
//int photo_num = 0;
//int click_flag = 0;
//int count=0;
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
DCMI_HandleTypeDef hdcmi;
DMA_HandleTypeDef hdma_dcmi;
I2C_HandleTypeDef hi2c4;
RTC_HandleTypeDef hrtc;
SPI_HandleTypeDef hspi1;
TIM_HandleTypeDef htim1;
TIM_HandleTypeDef htim2;
UART_HandleTypeDef huart1;
osThreadId defaultTaskHandle;
osThreadId buffer_copyHandle;
osThreadId send_BuffHandle;
/* USER CODE BEGIN PV */
//#define RES160X120
//#define RES320X240
//#define RES640X480
//#define RES800x600
#define RES1024x768
//#define RES1280x960
#ifdef RES160X120
enum imageResolution imgRes=RES_160X120;
uint8_t frameBuffer[RES_160X120] = { 0 };
uint8_t frameBuffer_tx[65535] = { 0 };
#endif
#ifdef RES320X240
enum imageResolution imgRes=RES_320X240;
uint8_t frameBuffer[RES_320X240] = { 0 };
#endif
#ifdef RES640X480
enum imageResolution imgRes=RES_640X480;
uint8_t frameBuffer[20000] = { 0 };
#endif
#ifdef RES800x600
enum imageResolution imgRes=RES_800x600;
uint8_t frameBuffer[RES_800x600] = { 0 };
#endif
#ifdef RES1024x768
enum imageResolution imgRes = RES_1024x768;
uint8_t frameBuffer[65535] = { 0 };
#endif
#ifdef RES1280x960
enum imageResolution imgRes = RES_1280x960;
#endif
unsigned short mutex = 1;
uint16_t bufferPointer = 0;
uint16_t size1 = 0;
unsigned short headerFound = 0;
unsigned char isStreaming = 0; // New flag to control streaming
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MPU_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_SPI1_Init(void);
static void MX_RTC_Init(void);
static void MX_DCMI_Init(void);
static void MX_I2C4_Init(void);
static void MX_TIM1_Init(void);
//static void MX_TIM2_Init(void);
static void MX_USART1_UART_Init(void);
void StartDefaultTask(void const * argument);
void StartTask02(void const * argument);
void StartTask03(void const * argument);
/* USER CODE BEGIN PFP */
void photocapture(void);
void recall_image(void);
void convertAndStore(uint16_t bufferPointer, uint8_t *message,
                size_t startIndex);
//void execute_5sec_operations(void);
//void SysTick_Handler1(void);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* function for sending the images to server after retrieving them from external flash upon  the request from server side*/
void recall_image(void) {
        id = W25Q_ReadId();
        W25Q_ReadBytes(frameBuffer_tx, ((rxBuff - 1) * size_image), size_image);
        if (rxBuff > 0) {
                while (frameBuffer_tx[photo_index] != 0xFF
                                && frameBuffer_tx[photo_index + 1] != 0xD9) {
                        photo_index++;
                photo_index += 2;
                photo_arr = (unsigned char*) malloc(
                                (photo_index) * sizeof(unsigned char));
                for (int i = 0; i <= photo_index; i++) {
                        photo_arr = frameBuffer_tx;
//                sprintf(message, "AACC02#%d#%p#", photo_index, photo_arr);
                lwip_send(sockfd1, message, sizeof(message), 0);
                memset(message, 0, sizeof(message));
                free(photo_arr);
                photo_index = 0;
//                HAL_UART_Transmit(&huart1, frameBuffer_tx, size_image, 2000);
//                HAL_UART_Transmit_IT(&huart1, frameBuffer_tx, size_image);
                rxBuff = 0;
//memset(frameBuffer_tx, 0, sizeof(frameBuffer_tx));
/* function for raising the photo capture flag as per timer 1*/
void photocapture(void) {
//        buffer_copy_flag = false;
                memset(frameBuffer, 0, sizeof(frameBuffer));
                                bufferPointer = 0;
                                size1 = 0;
                                headerFound = 0;
                                OV2640_CaptureSnapshot((uint32_t) frameBuffer, imgRes);
                                while (1) {
                                        if (headerFound == 0 && frameBuffer[bufferPointer] == 0xFF
                                                        && frameBuffer[bufferPointer + 1] == 0xD8) {
                                                headerFound = 1;
        #ifdef DEBUG
                                                //my_printf("Found header of JPEG file \r\n");
        #endif
                                        if (headerFound == 1 && frameBuffer[bufferPointer] == 0xFF
                                                        && frameBuffer[bufferPointer + 1] == 0xD9) {
                                                bufferPointer = bufferPointer + 2;
        #ifdef DEBUG
                                                //my_printf("Found EOF of JPEG file \r\n");
        #endif
                                                headerFound = 0;
                                                size1 = bufferPointer+13;
                                                break;
                                        if (bufferPointer >= 65535) {
                                                break;
                                        bufferPointer++;
                    if (size1 > 0) {
                        // Prepare the header in the process buffer
                        message[0] = 0x41; // 'A'
                        message[1] = 0x41; // 'A'
                        message[2] = 0x43; // 'C'
                        message[3] = 0x43; // 'C'
                        message[4] = 0x30; // '0'
                        message[5] = 0x32; // '2'
                        message[6] = 0x23; // '#'
                        convertAndStore(size1, message, 7); // Add size info
                        message[12] = 0x23; // End marker '#'
                        // Copy the captured data into the process buffer
                        memcpy(&message[13], frameBuffer, size1);
                            buffer_copy_flag = true;
/*function defines server and helps the client to establish the connection with the server*/
void client_init(void) {
        /* TCP Data buffer */
        int keepalive = 1; // Enable keepalive
        int keepidle = 10; // Idle time before sending keepalive probes (in seconds)
        int keepintvl = 5; // Interval between keepalive probes (in seconds)
        int keepcnt = 10; // Number of keepalive probes before declaring the connection dead
        int timeout = 100;
        sockfd1 = socket(AF_INET, SOCK_STREAM, 0);
        if (sockfd1 == -1) {
                lwip_close(sockfd1);
                connect = 0;
                return;
                //HAL_UART_Transmit(&huart4,"socket not created",sizeof("socket not created"),HAL_MAX_DELAY);
        memset((char*) &my_addr, 0, sizeof(my_addr));
        memset((char*) &their_addr, 0, sizeof(their_addr));
        my_addr.sin_family = AF_INET;
        my_addr.sin_port = htons(25001);
        my_addr.sin_addr.s_addr = INADDR_ANY;
        their_addr.sin_family = AF_INET;
        their_addr.sin_port = htons(25001);
        if (inet_pton(AF_INET,"192.168.0.254", &their_addr.sin_addr) <= 0) {
                connect = 0;
                return;
        ret = lwip_connect(sockfd1, (struct sockaddr*) &their_addr,
        if (ret == -1) {
                connect = 0;
        } else {
                connect = 1;
                sprintf(&ServerIP[0], "192.168.0.254");
                DestinationIP[2] = 0;
                DestinationIP[3] = 254;
                lwip_setsockopt(sockfd1, SOL_SOCKET, SO_KEEPALIVE, &keepalive,
                                sizeof(keepalive));
                lwip_setsockopt(sockfd1, IPPROTO_TCP, TCP_KEEPIDLE, &keepidle,
                                sizeof(keepidle));
                lwip_setsockopt(sockfd1, IPPROTO_TCP, TCP_KEEPINTVL, &keepintvl,
                                sizeof(keepintvl));
                lwip_setsockopt(sockfd1, IPPROTO_TCP, TCP_KEEPCNT, &keepcnt,
                                sizeof(keepcnt));
                lwip_setsockopt(sockfd1, SOL_SOCKET, SO_RCVTIMEO, &timeout,
                                sizeof(timeout));
/* function responsible to convert bufferPointer value to string */
                size_t startIndex) {
        // Temporary buffer to hold the string representation of the number
        char tempBuffer[6]; // Maximum 5 digits for uint16_t + 1 for null terminator
        // Convert the number to a string
        snprintf(tempBuffer, sizeof(tempBuffer), "%u", bufferPointer);
        // Get the length of the number as a string
        size_t length = strlen(tempBuffer);
        // Store each digit as a separate value in the message array
        for (size_t i = 0; i < length; i++) {
                message[startIndex + i] = tempBuffer;  // Store ASCII representation
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MPU Configuration--------------------------------------------------------*/
  MPU_Config();
  /* Enable the CPU Cache */
  /* Enable I-Cache---------------------------------------------------------*/
  SCB_EnableICache();
  /* Enable D-Cache---------------------------------------------------------*/
  SCB_EnableDCache();
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_SPI1_Init();
  MX_RTC_Init();
  MX_DCMI_Init();
  MX_I2C4_Init();
  MX_TIM1_Init();
//  MX_TIM2_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
        OV2640_Init(&hi2c4, &hdcmi);
        HAL_Delay(10);
        OV2640_ResolutionOptions(imgRes);
        HAL_Delay(2000);
        HAL_TIM_Base_Start_IT(&htim1);
//        HAL_TIM_Base_Start_IT(&htim2);
  /* USER CODE END 2 */
  /* USER CODE BEGIN RTOS_MUTEX */
        /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
        /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
        /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* USER CODE BEGIN RTOS_QUEUES */
        /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Create the thread(s) */
  /* definition and creation of defaultTask */
  osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 512);
  defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
  /* definition and creation of buffer_copy */
  osThreadDef(buffer_copy, StartTask02, osPriorityHigh, 0, 512);
  buffer_copyHandle = osThreadCreate(osThread(buffer_copy), NULL);
  /* definition and creation of send_Buff */
//  osThreadDef(send_Buff, StartTask03, osPriorityIdle, 0, 512);
//  send_BuffHandle = osThreadCreate(osThread(send_Buff), NULL);
  /* USER CODE BEGIN RTOS_THREADS */
        /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* Start scheduler */
  osKernelStart();
  /* We should never get here as control is now taken by the scheduler */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
        while (1) {
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Supply configuration update enable
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 5;
  RCC_OscInitStruct.PLL.PLLN = 64;
  RCC_OscInitStruct.PLL.PLLP = 1;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_1);
  HAL_RCC_MCOConfig(RCC_MCO2, RCC_MCO2SOURCE_HSE, RCC_MCODIV_1);
  * @brief DCMI Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN DCMI_Init 0 */
  /* USER CODE END DCMI_Init 0 */
  /* USER CODE BEGIN DCMI_Init 1 */
  /* USER CODE END DCMI_Init 1 */
  hdcmi.Instance = DCMI;
  hdcmi.Init.SynchroMode = DCMI_SYNCHRO_HARDWARE;
  hdcmi.Init.PCKPolarity = DCMI_PCKPOLARITY_RISING;
  hdcmi.Init.VSPolarity = DCMI_VSPOLARITY_LOW;
  hdcmi.Init.HSPolarity = DCMI_HSPOLARITY_LOW;
  hdcmi.Init.CaptureRate = DCMI_CR_ALL_FRAME;
  hdcmi.Init.ExtendedDataMode = DCMI_EXTEND_DATA_8B;
  hdcmi.Init.JPEGMode = DCMI_JPEG_ENABLE;
  hdcmi.Init.ByteSelectMode = DCMI_BSM_ALL;
  hdcmi.Init.ByteSelectStart = DCMI_OEBS_ODD;
  hdcmi.Init.LineSelectMode = DCMI_LSM_ALL;
  hdcmi.Init.LineSelectStart = DCMI_OELS_ODD;
  if (HAL_DCMI_Init(&hdcmi) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN DCMI_Init 2 */
  /* USER CODE END DCMI_Init 2 */
  * @brief I2C4 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN I2C4_Init 0 */
  /* USER CODE END I2C4_Init 0 */
  /* USER CODE BEGIN I2C4_Init 1 */
  /* USER CODE END I2C4_Init 1 */
  hi2c4.Instance = I2C4;
  hi2c4.Init.Timing = 0x10909CEC;
  hi2c4.Init.OwnAddress1 = 0;
  hi2c4.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c4.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c4.Init.OwnAddress2 = 0;
  hi2c4.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
  hi2c4.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c4.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c4) != HAL_OK)
    Error_Handler();
  /** Configure Analogue filter
  if (HAL_I2CEx_ConfigAnalogFilter(&hi2c4, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    Error_Handler();
  /** Configure Digital filter
  if (HAL_I2CEx_ConfigDigitalFilter(&hi2c4, 0) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2C4_Init 2 */
  /* USER CODE END I2C4_Init 2 */
  * @brief RTC Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN RTC_Init 0 */
  /* USER CODE END RTC_Init 0 */
  RTC_TimeTypeDef sTime = {0};
  RTC_DateTypeDef sDate = {0};
  RTC_AlarmTypeDef sAlarm = {0};
  /* USER CODE BEGIN RTC_Init 1 */
  /* USER CODE END RTC_Init 1 */
  /** Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN Check_RTC_BKUP */
  /* USER CODE END Check_RTC_BKUP */
  /** Initialize RTC and set the Time and Date
  sTime.Hours = 0;
  sTime.Minutes = 0;
  sTime.Seconds = 0;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN) != HAL_OK)
    Error_Handler();
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 1;
  sDate.Year = 0;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN) != HAL_OK)
    Error_Handler();
  /** Enable the Alarm A
  sAlarm.AlarmTime.Hours = 0;
  sAlarm.AlarmTime.Minutes = 0;
  sAlarm.AlarmTime.Seconds = 0;
  sAlarm.AlarmTime.SubSeconds = 0;
  sAlarm.AlarmTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sAlarm.AlarmTime.StoreOperation = RTC_STOREOPERATION_RESET;
  sAlarm.AlarmMask = RTC_ALARMMASK_NONE;
  sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_ALL;
  sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
  sAlarm.AlarmDateWeekDay = 1;
  sAlarm.Alarm = RTC_ALARM_A;
  if (HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, RTC_FORMAT_BIN) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN RTC_Init 2 */
  /* USER CODE END RTC_Init 2 */
  * @brief SPI1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI1_Init 0 */
  /* USER CODE END SPI1_Init 0 */
  /* USER CODE BEGIN SPI1_Init 1 */
  /* USER CODE END SPI1_Init 1 */
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_MASTER;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_HIGH;
  hspi1.Init.CLKPhase = SPI_PHASE_2EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 0x0;
  hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  hspi1.Init.NSSPolarity = SPI_NSS_POLARITY_LOW;
  hspi1.Init.FifoThreshold = SPI_FIFO_THRESHOLD_01DATA;
  hspi1.Init.TxCRCInitializationPattern = SPI_CRC_INITIALIZATION_ALL_ZERO_PATTERN;
  hspi1.Init.RxCRCInitializationPattern = SPI_CRC_INITIALIZATION_ALL_ZERO_PATTERN;
  hspi1.Init.MasterSSIdleness = SPI_MASTER_SS_IDLENESS_00CYCLE;
  hspi1.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_00CYCLE;
  hspi1.Init.MasterReceiverAutoSusp = SPI_MASTER_RX_AUTOSUSP_DISABLE;
  hspi1.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_DISABLE;
  hspi1.Init.IOSwap = SPI_IO_SWAP_DISABLE;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
  * @brief TIM1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN TIM1_Init 0 */
  /* USER CODE END TIM1_Init 0 */
  TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  /* USER CODE BEGIN TIM1_Init 1 */
  /* USER CODE END TIM1_Init 1 */
  htim1.Instance = TIM1;
  htim1.Init.Prescaler = 15999;
  htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim1.Init.Period = 9999;
  htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim1.Init.RepetitionCounter = 0;
  htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM1_Init 2 */
  /* USER CODE END TIM1_Init 2 */
  * @brief USART1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.Init.ClockPrescaler = UART_PRESCALER_DIV1;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetTxFifoThreshold(&huart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetRxFifoThreshold(&huart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_DisableFifoMode(&huart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART1_Init 2 */
  /* USER CODE END USART1_Init 2 */
  * Enable DMA controller clock
  /* DMA controller clock enable */
  __HAL_RCC_DMA1_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA1_Stream1_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Stream1_IRQn, 5, 0);
  HAL_NVIC_EnableIRQ(DMA1_Stream1_IRQn);
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOE, CAMERA_RESET_Pin|GPIO_PIN_10, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(LD_GPIO_Port, LD_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : CAMERA_RESET_Pin PE10 */
  GPIO_InitStruct.Pin = CAMERA_RESET_Pin|GPIO_PIN_10;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pin : LD_Pin */
  GPIO_InitStruct.Pin = LD_Pin;
  HAL_GPIO_Init(LD_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : LED_LINK_Pin */
  GPIO_InitStruct.Pin = LED_LINK_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(LED_LINK_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PC9 */
  GPIO_InitStruct.Pin = GPIO_PIN_9;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF0_MCO;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pin : ETH_RCC_MCO_1_Pin */
  GPIO_InitStruct.Pin = ETH_RCC_MCO_1_Pin;
  HAL_GPIO_Init(ETH_RCC_MCO_1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : Door_Switch_Pin */
  GPIO_InitStruct.Pin = Door_Switch_Pin;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  HAL_GPIO_Init(Door_Switch_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : CS_Pin */
  GPIO_InitStruct.Pin = CS_Pin;
  HAL_GPIO_Init(CS_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
/* USER CODE BEGIN Header_StartDefaultTask */
  * @brief  Function implementing the defaultTask thread.
  * @param  argument: Not used
  * @retval None
/* USER CODE END Header_StartDefaultTask */
  /* init code for LWIP */
  MX_LWIP_Init();
  /* USER CODE BEGIN 5 */
//  buffer_copy_flag=true;
        /* Infinite loop */
        for (;;) {
                if (connect == 0)
                        client_init();
                else {
                        if (connect_flag == 1) {
                                connect_flag = 0;
                        if (disconnect == 1) {
                                connect_flag = 1;
                                disconnect = 0;
                                lwip_shutdown(sockfd1, SHUT_RDWR);
                                connect = 0;
                osDelay(1);
  /* USER CODE END 5 */
/* USER CODE BEGIN Header_StartTask02 */
* @brief Function implementing the buffer_copy thread.
* @retval None
/* USER CODE END Header_StartTask02 */
  /* USER CODE BEGIN StartTask02 */
//  /* Infinite loop */
  for(;;)
                if (buffer_copy_flag) {
                        photo_index= sizeof(message);
                                                  const int chunkSize = 1024;
        int offset = 0;
        int bytesRemaining = size1;
//        lwip_send(sockfd1, (char*) &array[offset], photo_index, 0);
        while (bytesRemaining > 0) {
        int bytesToSend = (bytesRemaining > chunkSize) ? chunkSize : bytesRemaining;
                                                        //                                        memcpy(tempBuffer, &frameBuffer[offset], bytesToSend);
        // Send the chunk
        int result = lwip_send(sockfd1, (char*) &message[offset], bytesToSend, 0);
        // Handle send failure (optional)
        if (result <= 0) {
        break;
        // Update counters
        offset += result;
        bytesRemaining -= result;
        buffer_copy_flag=false;
//                        //        HAL_GPIO_WritePin(LD3_GPIO_Port, LD3_Pin, GPIO_PIN_SET);
//                        //                        HAL_Delay(100);
//                        //                        HAL_GPIO_WritePin(LD3_GPIO_Port, LD3_Pin, GPIO_PIN_RESET);
//                        //                        if (HAL_GPIO_ReadPin(Door_Switch_GPIO_Port, Door_Switch_Pin) == 1) { // Button pressed
//                        //                                if (mutex == 1) {
//#ifdef DEBUG
//                        //my_printf("Image size: %d bytes \r\n",bufferPointer);
//#endif
//                        //                                          photo_count++;
//                        //                                        HAL_UART_Transmit_DMA(&huart1, frameBuffer, bufferPointer); //Use of DMA may be necessary for larger data streams.
//                        //                                         int headerLength = snprintf(message, sizeof(message), "AACC02#%u#", sizeof(frameBuffer));
//                        //                                                  message[7]=bufferPointer;
//                        // Store the least significant byte (LSB)
//                        //                                                  message[7] = bufferPointer & 0xFF;        // Extract lower 8 bits
//                        //                                                  // Store the most significant byte (MSB)
//                        //                                                  message[8] = (bufferPointer >> 8) & 0xFF; // Extract upper 8 bits
////                          if (size1 > 0 && size1 < 55000){  // Ensure size is valid
////                        // Send the JPEG size header
////                                convertAndStore(bufferPointer, message, startIndex);
//////                                                // Send the JPEG header information
////                                snprintf((char*) message, sizeof(message), "AACC02#%u#", size1);
////                                message[12] = 0x23;  // Add end marker (#)
////                                for (int i =0)
//                         W25Q_EraseBlock(0);        //BLOCK-0 IS FOR STORING THE LIST
//        W25Q_WriteBytes((unsigned char*)frameBuffer, 0, bufferPointer);
////                                lwip_send(sockfd1, (char*) message, 13, 0);  // Send header
////                                // Send the JPEG data in chunks
////              const int chunkSize = 1024;
////              int offset = 0;
////              int bytesRemaining = size1;
////                                while (bytesRemaining > 0) {
////                                         int bytesToSend = (bytesRemaining > chunkSize) ? chunkSize : bytesRemaining;
//////                                        memcpy(tempBuffer, &frameBuffer[offset], bytesToSend);
////                                         // Send the chunk
////                                        int result = lwip_send(sockfd1, (char*) &frameBuffer[offset], bytesToSend, 0);
////                                        // Handle send failure (optional)
////                                        if (result <= 0) {
////                                                break;
////                                        // Update counters
////                                        offset += result;
////                                        bytesRemaining -= result;
////                        bufferPointer = 0;
//                        send_flag=true;
    osDelay(1);
  /* USER CODE END StartTask02 */
/* USER CODE BEGIN Header_StartTask03 */
* @brief Function implementing the send_Buff thread.
* @retval None
/* USER CODE END Header_StartTask03 */
  /* USER CODE BEGIN StartTask03 */
  /* Infinite loop */
  for(;;)
    osDelay(1);
  /* USER CODE END StartTask03 */
/* MPU Configuration */
  MPU_Region_InitTypeDef MPU_InitStruct = {0};
  /* Disables the MPU */
  HAL_MPU_Disable();
  /** Initializes and configures the Region and the memory to be protected
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.BaseAddress = 0x0;
  MPU_InitStruct.Size = MPU_REGION_SIZE_4GB;
  MPU_InitStruct.SubRegionDisable = 0x87;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  MPU_InitStruct.BaseAddress = 0x30000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_2KB;
  MPU_InitStruct.SubRegionDisable = 0x0;
  MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER2;
  MPU_InitStruct.BaseAddress = 0x30004000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
  MPU_InitStruct.Number = MPU_REGION_NUMBER3;
  MPU_InitStruct.BaseAddress = 0x240106a4;
  MPU_InitStruct.Size = MPU_REGION_SIZE_64KB;
  /* Enables the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
  * @brief  Period elapsed callback in non blocking mode
  * @note   This function is called  when TIM6 interrupt took place, inside
  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  * a global variable "uwTick" used as application time base.
  * @param  htim : TIM handle
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  /* USER CODE BEGIN Callback 0 */
  /* USER CODE END Callback 0 */
  if (htim->Instance == TIM6) {
    HAL_IncTick();
  /* USER CODE BEGIN Callback 1 */
  /* USER CODE END Callback 1 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
        /* User can add his own implementation to report the HAL error return state */
        __disable_irq();
        while (1) {
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
