[AVR单片机] IAR中断写法:SIGNAL(),INTERRUPT()
5644|6
 楼主| ATmega32L 发表于 2008-4-2 09:28 | 显示全部楼层 |阅读模式
#ifndef __IAR_SIGNAL_H__
#define __IAR_SIGNAL_H__
#include <intrinsics.h>
#define sei() __enable_interrupt()
#define cli() __disable_interrupt()
#define _PRAGMA_STR(A) _Pragma(#A)
#define PRAGMA_STR(A) _PRAGMA_STR(A)
#define __VECTOR__(A) vector=A
#define SIGNAL(A)
PRAGMA_STR(__VECTOR__(A))
__interrupt void SIGNAL##_##A(void)
#define INTERRUPT(A)
__nested __interrupt void SIGNAL##_##A(void)
#define SIGNAL_NAKED(A)
__raw __interrupt void SIGNAL##_##A(void)
#define INTERRUPT_NAKED(A)
__raw __nested __interrupt void SIGNAL##_##A(void)
#define SIG_INTERRUPT0            INT0_vect
#define SIG_INTERRUPT1        INT1_vect
#define SIG_OUTPUT_COMPARE2    TIMER2_COMP_vect
#define SIG_OVERFLOW2            TIMER2_OVF_vect
#define SIG_INPUT_CAPTURE1    TIMER1_CAPT_vect
#define SIG_OUTPUT_COMPARE1A    TIMER1_COMPA_vect
#define SIG_OUTPUT_COMPARE1B    TIMER1_COMPB_vect
#define SIG_OVERFLOW1        TIMER1_OVF_vect
#define SIG_OVERFLOW0        TIMER0_OVF_vect
#define SIG_SPI            SPI_STC_vect
#define SIG_USART_RECV        USART_RXC_vect
#define SIG_UART_RECV        USART_RXC_vect
#define SIG_USART_DATA        USART_UDRE_vect
#define SIG_UART_DATA        USART_UDRE_vect
#define SIG_USART_TRANS        USART_TXC_vect
#define SIG_UART_TRANS        USART_TXC_vect
#define SIG_ADC            ADC_vect
#define SIG_EEPROM_READY    EE_RDY_vect
#define SIG_COMPARATOR        ANA_COMP_vect
#define SIG_2WIRE_SERIAL    TWI_vect
#define SIG_INTERRUPT2        INT2_vect
#define SIG_OUTPUT_COMPARE0    TIMER0_COMP_vect
#define SIG_SPM_READY        SPM_RDY_vect
#endif
如定时器0溢出中断写法:
如定时器0溢出中断写法:
SIGNAL(SIG_OVERFLOW0)   //定时器0溢出中断
INTERRUPT(SIG_OVERFLOW0)  //定时器0溢出中断,快速开中断
SIGNAL_NAKED(SIG_OVERFLOW0)   //定时器0溢出中断,裸中断,不进行断点现场保护
INTERRUPT_NAKED(SIG_OVERFLOW0)   //定时器0溢出中断,裸中断,快速开中断且不进行断点现场保护
qjy_dali 发表于 2008-4-4 17:25 | 显示全部楼层
IAR的没用过,怎么看着像GCC,呵呵
hxh_8555 发表于 2008-4-9 08:39 | 显示全部楼层
iar
#pragma vector = TIMER0_OVF_vect
__interrupt void timer0_ovf_isr(void)
   //中断程序
Lxueqiang 发表于 2008-4-23 17:04 | 显示全部楼层
还是使用楼上的多些
hxh_8555 提到的!
 楼主| ATmega32L 发表于 2008-4-27 17:46 | 显示全部楼层
更喜欢用SIGNAL
   //中断程序
换成
SIGNAL(TIMER0_OVF_vect)
   //中断程序
hotpower 发表于 2008-5-2 22:03 | 显示全部楼层
晕~~~用着IAR想着GCC~~~而且用着M3也想着GCC~~~
