STM32F103串口调试
3869|5
 楼主| 亚历山大 发表于 2012-7-20 16:09 | 显示全部楼层 |阅读模式
刚接触STM32F103RBT6最近在调试USART,我想发送一个数据给串口助手接收,但是就是没有数据发出,想问一下各位高手这是怎么回事?下面是我的程序
对串口引脚配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitTypeDef USART_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO,ENABLE);
USART_InitStructure.USART_BaudRate = 9600;//256000;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity= USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode= USART_Mode_Rx |USART_Mode_Tx;
USART_InitStructure.USART_Clock = USART_Clock_Enable;
USART_InitStructure.USART_CPOL = USART_CPOL_Low;
USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
USART_Init(USART2, &USART_InitStructure);
USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
USART_Cmd(USART2, ENABLE);
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
FLASH_SetLatency(FLASH_Latency_2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC
| RCC_APB2Periph_AFIO, ENABLE);
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef
VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
/* VECT_TAB_FLASH
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/* 配置中断优先级SPI(UART)>TIM2>TIM3>USB>EXTI*/
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void USART2_IRQHandler(void)
if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET)
USART_ClearITPendingBit (USART2,USART_IT_TXE);
USART_SendData(USART2, 5);
耶稣欠筹了 发表于 2012-8-9 23:34 | 显示全部楼层
我也是刚刚做stm32f103rbt6,你的问题解决了吗?
flyleaf91 发表于 2012-8-14 14:18 | 显示全部楼层
建议楼主参考野火串口例程~
捡漏王子 发表于 2012-8-14 15:10 | 显示全部楼层
                   USART_ClearITPendingBit(USART2,USART_IT_TXE);
你的发送是这个里面吗?
这个?
捡漏王子 发表于 2012-8-14 15:12 | 显示全部楼层
这个函数你怎么进去的呢?
zh5202 发表于 2012-8-14 15:40 | 显示全部楼层
有什么错误提示没有?
还有是不是串口线的问题,你换根线再试试
