STM32 串口中断问题
3594|15
 楼主| yuluyiyi 发表于 2012-7-26 10:16 | 显示全部楼层 |阅读模式
int main(void)
  RCC_Configuration();
  GPIO_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART2, &USART_InitStructure);
  USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  USART_Cmd(USART2, ENABLE);
  while (1)
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable the USARTx Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void USART2_IRQHandler(void)
  if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    RxBuffer[RxCounter++] = (USART_ReceiveData(USART2) & 0x7F);
    if(RxCounter == NbrOfDataToRead)
      /* Disable the EVAL_COM1 Receive interrupt */
      USART_ITConfig(USART2, USART_IT_RXNE, DISABLE);
  if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET)
    /* Write one byte to the transmit data register */
    USART_SendData(USART2, TxBuffer[TxCounter++]);
    if(TxCounter == NbrOfDataToTransfer)
      /* Disable the EVAL_COM1 Transmit interrupt */
      USART_ITConfig(USART2, USART_IT_TXE, DISABLE);
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  RCC_HSEConfig(RCC_HSE_ON);//开启HSE
  HSEStartUpStatus=RCC_WaitForHSEStartUp(); //等待HSE高速晶振稳定
  if(HSEStartUpStatus==SUCCESS)
  { RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置高速总线时钟
    RCC_PCLK2Config(RCC_HCLK_Div1);//设置高速时钟
RCC_PCLK1Config(RCC_HCLK_Div2);  //设置低速时钟
FLASH_SetLatency(FLASH_Latency_2);//延时
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//设置PLL时钟源及倍频数
RCC_ADCCLKConfig(RCC_PCLK2_Div6);
RCC_PLLCmd(ENABLE);//使能PLL锁相环
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//设置系统时钟
while(RCC_GetSYSCLKSource()!=0x08);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
void GPIO_Configuration(void)
   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_2;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
   GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
请大家帮忙看看,这个是官方的例程,USART没有数据输出,不知道是哪里有问题?
haitianhappy 发表于 2012-7-26 11:36 | 显示全部楼层
你的一步一步调试 先仿真一下看看串口是否打开啦
qiujiahongde 发表于 2012-7-26 13:04 | 显示全部楼层
RCC_Configuration函数里面加RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
 楼主| yuluyiyi 发表于 2012-7-27 11:09 | 显示全部楼层
串口开了 2# haitianhappy
 楼主| yuluyiyi 发表于 2012-7-27 11:10 | 显示全部楼层
这个之前是加上的,还是没有数据输出 3# qiujiahongde
qiujiahongde 发表于 2012-7-28 23:18 | 显示全部楼层
你代码里面少了次软件触发中断!!
qiujiahongde 发表于 2012-7-28 23:24 | 显示全部楼层
而且这个列程,似乎是要发送和接收接到一起的;给你传一个能跑的!!
2.USART1_Printf.rar
2.98 MB, 下载次数: 379
 楼主| yuluyiyi 发表于 2012-7-31 09:41 | 显示全部楼层
软件触发中断如何加呢 6# qiujiahongde
beyond696 发表于 2012-7-31 13:22 | 显示全部楼层
http://www.viewtool.com/bbs/foru ... d=79&extra=page%3D1串口中断接收源码下载,调试通过!
电子机器人 发表于 2012-7-31 14:18 | 显示全部楼层
查看一下硬件是否符合
thinkingpadcui 发表于 2012-7-31 14:58 | 显示全部楼层
代码貌似木有什么问题  看一下硬件连接 是否完好
 楼主| yuluyiyi 发表于 2012-7-31 16:22 | 显示全部楼层
用查询方式试过了,收和发都正常,但是中断就是进不去 11# thinkingpadcui
qiaoshb 发表于 2012-7-31 17:30 | 显示全部楼层
查看下启动代码初始化中断向量表的外部变量(相应中断的中断处理函数名)与真实的中断处理函数名是否相同?
 楼主| yuluyiyi 发表于 2012-8-1 08:47 | 显示全部楼层
DCD     USART1_IRQHandler         ; USART1
                DCD     USART2_IRQHandler         ; USART2
                DCD     USART3_IRQHandler         ; USART3
                DCD     EXTI15_10_IRQHandler      ; EXTI Line 15..10
没有UART4对应的中断函数名……如果我想用UART4的中断函数怎么办呢 13# qiaoshb
 楼主| yuluyiyi 发表于 2012-8-2 09:43 | 显示全部楼层
把启动代码更换成大容量的启动文件就可以运行了,已经调试通过,谢谢:)
liubuwai 发表于 2012-8-2 12:20 | 显示全部楼层
引脚不对  我的是9 和 10  你看看你自己的硬件图
