stm8s eeprom 问题请教
2363|0
 楼主| lattice1 发表于 2012-7-26 10:48 | 显示全部楼层 |阅读模式
初始化部分,这个部分可以成功的写入,和读出来
void EEPROM_Init(void)
  //unlock EEPROM
  FLASH->DUKR = 0xAE;
  FLASH->DUKR = 0x56;
  EEP_Wait_Finished();
  if ((eeprom_variable[0]=='T') && (eeprom_variable[1]=='G') && (eeprom_variable[2]==8) && (eeprom_variable[3]==0x00))
    Remote_ID[0] = E2_ReadMem(0);
    Remote_ID[1] = E2_ReadMem(1);
    Remote_ID[2] = E2_ReadMem(2);
    Remote_ID[3] = E2_ReadMem(3);
  else
    Remote_ID[0] = 0xaa; //第一次
    Remote_ID[1] = 0xaa;
    Remote_ID[2] = 0xaa;
    Remote_ID[3] = 0xaa;
    E2_WriteBurst(0, 4, Remote_ID);
    E2_ResetEEPROM();
void E2_ResetEEPROM(void)
  eeprom_variable[0] = 'T';   //"TG80" is written  in the EEPROM
  eeprom_variable[1] = 'G';   //This allows to check later that the EEPROM content is valid.
  eeprom_variable[2] = 8;
  eeprom_variable[3] = 0x00;
在这个部分,写入ID时就是写不进去。奇怪?
if(Save_ID_标志寄存器 == 1 && RX_buf[4] == 15) //学习模式,保存ID
          Save_ID_标志寄存器 = 0;
          Remote_ID[0] = RX_buf[0]; // ID
          Remote_ID[1] = RX_buf[1];
          Remote_ID[2] = RX_buf[2];
          Remote_ID[3] = RX_buf[3];
          //E2_WriteBurst(0, 4, Remote_ID);
          eeprom_variable[4] = Remote_ID[0];   //"TG80" is written  in the EEPROM
  eeprom_variable[5] = Remote_ID[1];   //This allows to check later that the EEPROM content is valid.
  eeprom_variable[6] = Remote_ID[2];
  eeprom_variable[7] = Remote_ID[3];
