大家好!我现在在使用MEGA48芯片,外部晶振是8M,希望串口波特率是9600, 我用ICCAVR软件,生产的设置代码,然后向PC的串口发送数据,实际效果是要1200才能正确收到数据。别人说是熔丝位的问题,也有人说不是。到底是哪里出了问题啊?请高人指点一下。谢谢! //UART0 初始化 void uart0_init(int bps) { int temp; temp=Fosc/bps/8-1;
UCSR0B = 0x00; //disable while setting baud rate UCSR0A = 0x00; UBRR0L =temp; UBRR0H =(temp>>8);
UCSR0C = 0x06; UCSR0A = 0x02; //enable 2倍波特率 UCSR0B = 0x98; } //call this routine to initialize all peripherals void init_devices(void) { //stop errant interrupts until set up CLI(); //disable all interrupts port_init(); uart0_init();
MCUCR = 0x00;
SEI(); //re-enable interrupts //all peripherals are now initialized } |
