6# IJK
Map of Debug\stvd_project.sm8 from link file Debug\stvd_project.lkf - Wed Aug 01 13:56:42 2012
Segments
start 00008080 end 00008080 length 0 segment .const
start 00008083 end 000081ad length 298 segment .text
start 00004000 end 00004000 length 0 segment .eeprom
start 00000000 end 00000000 length 0 segment .bsct
start 00000000 end 00000006 length 6 segment .ubsct
start 00000006 end 00000006 length 0 segment .bit
start 00000006 end 00000006 length 0 segment .share
start 00000100 end 00000100 length 0 segment .data
start 00000100 end 00000100 length 0 segment .bss
start 00000000 end 000012f6 length 4854 segment .debug
start 00008000 end 00008080 length 128 segment .const
start 00008080 end 00008083 length 3 segment .init
Modules
D:\Program Files\CXSTM8\Lib\crtsi0.sm8:
start 00008083 end 000080ce length 75 section .text
start 00000100 end 00000100 length 0 section .bss
start 00000000 end 00000000 length 0 section .ubsct
Debug\main.o:
start 000080ce end 000080f9 length 43 section .text
start 00000000 end 00000100 length 256 section .debug
Debug\stm8s_it.o:
start 000080f9 end 00008110 length 23 section .text
start 00000100 end 000007c6 length 1734 section .debug
Debug\stm8s_gpio.o:
start 00008110 end 000081ad length 157 section .text
start 000007c6 end 000011d0 length 2570 section .debug
(D:\Program Files\CXSTM8\Lib\libm0.sm8)xreg.o:
start 00000000 end 00000003 length 3 section .ubsct
(D:\Program Files\CXSTM8\Lib\libm0.sm8)yreg.o:
start 00000003 end 00000006 length 3 section .ubsct
Debug\stm8_interrupt_vector.o:
start 000011d0 end 000012f6 length 294 section .debug
start 00008000 end 00008080 length 128 section .const
Stack usage
Debug\main.o:
_Delay 4 (4)
_main > 8 (2)
Debug\stm8s_gpio.o:
_GPIO_DeInit > 2 (2)
_GPIO_ExternalPullUpConfig > 6 (6)
_GPIO_Init 6 (6)
_GPIO_ReadInputData > 2 (2)
_GPIO_ReadInputPin > 5 (5)
_GPIO_ReadOutputData > 2 (2)
_GPIO_Write > 5 (5)
_GPIO_WriteHigh > 5 (5)
_GPIO_WriteLow > 5 (5)
_GPIO_WriteReverse > 5 (5)
Debug\stm8s_it.o:
f_ADC1_IRQHandler > 5 (5)
f_AWU_IRQHandler > 5 (5)
f_CLK_IRQHandler > 5 (5)
f_EEPROM_EEC_IRQHandler > 5 (5)
f_EXTI_PORTA_IRQHandler > 5 (5)
f_EXTI_PORTB_IRQHandler > 5 (5)
f_EXTI_PORTC_IRQHandler > 5 (5)
f_EXTI_PORTD_IRQHandler > 5 (5)
f_EXTI_PORTE_IRQHandler > 5 (5)
f_I2C_IRQHandler > 5 (5)
f_NonHandledInterrupt > 5 (5)
f_SPI_IRQHandler > 5 (5)
f_TIM1_CAP_COM_IRQHandler > 5 (5)
f_TIM1_UPD_OVF_TRG_BRK_IRQHandler > 5 (5)
f_TIM2_CAP_COM_IRQHandler > 5 (5)
f_TIM2_UPD_OVF_BRK_IRQHandler > 5 (5)
f_TIM3_CAP_COM_IRQHandler > 5 (5)
f_TIM3_UPD_OVF_BRK_IRQHandler > 5 (5)
f_TIM4_UPD_OVF_IRQHandler > 5 (5)
f_TLI_IRQHandler > 5 (5)
f_TRAP_IRQHandler > 5 (5)
f_UART2_RX_IRQHandler > 5 (5)
f_UART2_TX_IRQHandler > 5 (5)
Stack size: 13
Call tree
1 > _GPIO_DeInit: (2)
2 > _GPIO_ExternalPullUpConfig: (6)
3 > _GPIO_ReadInputData: (2)
4 > _GPIO_ReadInputPin: (5)
5 > _GPIO_ReadOutputData: (2)
6 > _GPIO_Write: (5)
7 > _GPIO_WriteHigh: (5)
8 > _GPIO_WriteLow: (5)
9 > _GPIO_WriteReverse: (5)
10 > __stext: (0)
11 > _main: (2)
12 + _Delay: (4)
13 + _GPIO_Init: (6)
14 > f_ADC1_IRQHandler: (5)
15 > f_AWU_IRQHandler: (5)
16 > f_CLK_IRQHandler: (5)
17 > f_EEPROM_EEC_IRQHandler: (5)
18 > f_EXTI_PORTA_IRQHandler: (5)
19 > f_EXTI_PORTB_IRQHandler: (5)
20 > f_EXTI_PORTC_IRQHandler: (5)
21 > f_EXTI_PORTD_IRQHandler: (5)
22 > f_EXTI_PORTE_IRQHandler: (5)
23 > f_I2C_IRQHandler: (5)
24 > f_NonHandledInterrupt: (5)
25 > f_SPI_IRQHandler: (5)
26 > f_TIM1_CAP_COM_IRQHandler: (5)
27 > f_TIM1_UPD_OVF_TRG_BRK_IRQHandler: (5)
28 > f_TIM2_CAP_COM_IRQHandler: (5)
29 > f_TIM2_UPD_OVF_BRK_IRQHandler: (5)
30 > f_TIM3_CAP_COM_IRQHandler: (5)
31 > f_TIM3_UPD_OVF_BRK_IRQHandler: (5)
32 > f_TIM4_UPD_OVF_IRQHandler: (5)
33 > f_TLI_IRQHandler: (5)
34 > f_TRAP_IRQHandler: (5)
35 > f_UART2_RX_IRQHandler: (5)
36 > f_UART2_TX_IRQHandler: (5)
37 _Delay --> 12
38 _GPIO_Init --> 13
Symbols
_Delay 000080ce defined in Debug\main.o section .text
_GPIO_DeInit 00008110 defined in Debug\stm8s_gpio.o section .text
_GPIO_ExternalPullUpConfig 00008197 defined in Debug\stm8s_gpio.o section .text
_GPIO_Init 00008118 defined in Debug\stm8s_gpio.o section .text
used in Debug\main.o
_GPIO_ReadInputData 0000818d defined in Debug\stm8s_gpio.o section .text
_GPIO_ReadInputPin 00008190 defined in Debug\stm8s_gpio.o section .text
_GPIO_ReadOutputData 0000818b defined in Debug\stm8s_gpio.o section .text
_GPIO_Write 0000816d defined in Debug\stm8s_gpio.o section .text
_GPIO_WriteHigh 00008175 defined in Debug\stm8s_gpio.o section .text
_GPIO_WriteLow 0000817c defined in Debug\stm8s_gpio.o section .text
_GPIO_WriteReverse 00008184 defined in Debug\stm8s_gpio.o section .text
__endmem 000005ff defined in command file
*** not used ***
__endzp 00000006 defined in command file section .ubsct
used in D:\Program Files\CXSTM8\Lib\crtsi0.sm8
__idesc__ 00008080 defined in linker section .init
__memory 00000100 defined in command file section .bss
__stack 000007ff defined in command file
__startmem 00000100 defined in command file section .bss
*** not used ***
__stext 00008083 defined in D:\Program Files\CXSTM8\Lib\crtsi0.sm8 section .text
used in Debug\stm8_interrupt_vector.o
__vectab 00008000 defined in Debug\stm8_interrupt_vector.o section .const
_exit 000080cc defined in D:\Program Files\CXSTM8\Lib\crtsi0.sm8 section .text
_main 000080da defined in Debug\main.o section .text
c_x 00000000 defined in (D:\Program Files\CXSTM8\Lib\libm0.sm8)xreg.o section .ubsct
c_y 00000003 defined in (D:\Program Files\CXSTM8\Lib\libm0.sm8)yreg.o section .ubsct
f_ADC1_IRQHandler 0000810d defined in Debug\stm8s_it.o section .text
f_AWU_IRQHandler 000080fc defined in Debug\stm8s_it.o section .text
f_CLK_IRQHandler 000080fd defined in Debug\stm8s_it.o section .text
f_EEPROM_EEC_IRQHandler 0000810f defined in Debug\stm8s_it.o section .text
f_EXTI_PORTA_IRQHandler 000080fe defined in Debug\stm8s_it.o section .text
f_EXTI_PORTB_IRQHandler 000080ff defined in Debug\stm8s_it.o section .text
f_EXTI_PORTC_IRQHandler 00008100 defined in Debug\stm8s_it.o section .text
f_EXTI_PORTD_IRQHandler 00008101 defined in Debug\stm8s_it.o section .text
f_EXTI_PORTE_IRQHandler 00008102 defined in Debug\stm8s_it.o section .text
f_I2C_IRQHandler 0000810a defined in Debug\stm8s_it.o section .text
f_NonHandledInterrupt 000080f9 defined in Debug\stm8s_it.o section .text
f_SPI_IRQHandler 00008103 defined in Debug\stm8s_it.o section .text
f_TIM1_CAP_COM_IRQHandler 00008105 defined in Debug\stm8s_it.o section .text
f_TIM1_UPD_OVF_TRG_BRK_IRQHandler 00008104 defined in Debug\stm8s_it.o section .text
f_TIM2_CAP_COM_IRQHandler 00008107 defined in Debug\stm8s_it.o section .text
f_TIM2_UPD_OVF_BRK_IRQHandler 00008106 defined in Debug\stm8s_it.o section .text
f_TIM3_CAP_COM_IRQHandler 00008109 defined in Debug\stm8s_it.o section .text
f_TIM3_UPD_OVF_BRK_IRQHandler 00008108 defined in Debug\stm8s_it.o section .text
f_TIM4_UPD_OVF_IRQHandler 0000810e defined in Debug\stm8s_it.o section .text
f_TLI_IRQHandler 000080fb defined in Debug\stm8s_it.o section .text
f_TRAP_IRQHandler 000080fa defined in Debug\stm8s_it.o section .text
f_UART2_RX_IRQHandler 0000810c defined in Debug\stm8s_it.o section .text
f_UART2_TX_IRQHandler 0000810b defined in Debug\stm8s_it.o section .text
