求解MSP430单片机5系列的DCO配置程序
7375|4
 楼主| vivilzb1985 发表于 2012-8-3 16:20 | 显示全部楼层 |阅读模式
现在在做MSP430F5310单片机的程序,我从MSP430F249移植过来的程序,第一下在DCO上就给卡住了,5系列的DCO配置跟2系列的又不一样了,查看了pdf资料的,全英文的,看的一知半解的,现在求解有用过5系列单片机的高手先给个DCO配置的代码(配置成8MHz的吧)参考下,请加上注释的啊,谢谢!
yanxinboy 发表于 2012-8-4 07:03 | 显示全部楼层
看头文件不就完了
peter_zheng 发表于 2012-8-12 08:03 | 显示全部楼层
在F5xxx里其时钟叫UCS,不同于DCO的配置。
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* *  Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
* *  Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in the
*    documentation and/or other materials provided with the distribution.
* *  Neither the name of Texas Instruments Incorporated nor the names of
*    its contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
*                       MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
//   MSP430F530x Demo - Software Toggle P1.1 with 12MHz DCO
//   Description: Toggle P1.1 by xor'ing P1.1 inside of a software loop.
//   ACLK is rought out on pin P1.0, SMCLK is brought out on P2.2, and MCLK
//   is brought out on pin P4.7.
//   ACLK = REFO = 32kHz, MCLK = SMCLK = 12MHz
//                 MSP430F530x
//          | |             P1.0|-->ACLK
//          --|RST          P4.7|-->MCLK
//            |             P2.2|-->SMCLK
//            |             P1.1|-->Port Pin
//   K. Chen
//   Texas Instruments Inc.
//   Ver 2.00 - May 2012
//   Built with CCS Version: 5.2 and IAR Embedded Workbench Version: 5.40.3
#include <msp430.h>
void SetVcoreUp (unsigned int level);
void main(void)
  volatile unsigned int i;
  WDTCTL = WDTPW|WDTHOLD;                   // Stop WDT
  PMAPPWD = 0x02D52;                        // Enable Write-access to modify port mapping registers
  P4MAP7 = PM_MCLK;
  PMAPPWD = 0;                              // Disable Write-Access to modify port mapping registers
  P1DIR |= BIT1;                            // P1.1 output
  P1DIR |= BIT0;                            // ACLK set out to pins
  P1SEL |= BIT0;
  P2DIR |= BIT2;                            // SMCLK set out to pins
  P2SEL |= BIT2;
  P4SEL |= BIT7;
  P4DIR |= BIT7;                            // MCLK set out to pins
  UCSCTL3 |= SELREF_2;                      // Set DCO FLL reference = REFO
  UCSCTL4 |= SELA_2;                        // Set ACLK = REFO
  // Increase Vcore setting to level1 to support fsystem=12MHz
  // NOTE: Change core voltage one level at a time..
  SetVcoreUp (0x01);
  // Initialize DCO to 12MHz
  __bis_SR_register(SCG0);                  // Disable the FLL control loop
  UCSCTL0 = 0x0000;                         // Set lowest possible DCOx, MODx
  UCSCTL1 = DCORSEL_5;                      // Select DCO range 24MHz operation
  UCSCTL2 = FLLD_1 | 374;                   // Set DCO Multiplier for 12MHz
                                            // (N + 1) * FLLRef = Fdco
                                            // (374 + 1) * 32768 = 12MHz
                                            // Set FLL Div = fDCOCLK/2
  __bic_SR_register(SCG0);                  // Enable the FLL control loop
  // Worst-case settling time for the DCO when the DCO range bits have been
  // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
  // UG for optimization.
  // 32 x 32 x 12 MHz / 32,768 Hz = 375000 = MCLK cycles for DCO to settle
  __delay_cycles(375000);
  // Loop until XT1,XT2 & DCO fault flag is cleared
  do
    UCSCTL7 &= ~(XT2OFFG | XT1LFOFFG | DCOFFG);
                                            // Clear XT2,XT1,DCO fault flags
    SFRIFG1 &= ~OFIFG;                      // Clear fault flags
  }while (SFRIFG1&OFIFG);                   // Test oscillator fault flag
  while(1)
    P1OUT ^= BIT1;                          // Toggle P1.1
    __delay_cycles(600000);                 // Delay
  // Open PMM registers for write
  PMMCTL0_H = PMMPW_H;
  // Set SVS/SVM high side new level
  SVSMHCTL = SVSHE | SVSHRVL0 * level | SVMHE | SVSMHRRL0 * level;
  // Set SVM low side to new level
  SVSMLCTL = SVSLE | SVMLE | SVSMLRRL0 * level;
  // Wait till SVM is settled
  while ((PMMIFG & SVSMLDLYIFG) == 0);
  // Clear already set flags
  PMMIFG &= ~(SVMLVLRIFG | SVMLIFG);
  // Set VCore to new level
  PMMCTL0_L = PMMCOREV0 * level;
  // Wait till new level reached
  if ((PMMIFG & SVMLIFG))
    while ((PMMIFG & SVMLVLRIFG) == 0);
  // Set SVS/SVM low side to new level
  SVSMLCTL = SVSLE | SVSLRVL0 * level | SVMLE | SVSMLRRL0 * level;
  // Lock PMM registers for write access
  PMMCTL0_H = 0x00;
 楼主| vivilzb1985 发表于 2012-8-27 18:11 | 显示全部楼层
谢谢楼上的鼎力相助,不过全英文的我还得消化一段时间的啊
 楼主| vivilzb1985 发表于 2012-9-18 13:44 | 显示全部楼层
这个是关于倍频的配置,还是有些难度的啊,不过我先结贴了,大家继续啊
个人签名:后来乍到,前辈们多多包涵了啊。。
88
