pic24f16ka102编译出错
3373|1
 楼主| zzjjhh 发表于 2012-8-22 16:37 | 显示全部楼层 |阅读模式
IDE用的是MPLab X 1.30,编译器是XC16 1.0
rtcc。c是抄例程的运行过没错,加到我的project里就出现下面的编译错误
CLEAN SUCCESSFUL (total time: 51ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Microchip Solutions/workspace/gogo.X'
make  -f nbproject/Makefile-default.mk dist/default/production/gogo.X.production.hex
make[2]: Entering directory `C:/Microchip Solutions/workspace/gogo.X'
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe"   uart.c  -o build/default/production/uart.o  -c -mcpu=24F16KA102  -MMD -MF "build/default/production/uart.o.d"        -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe"   main.c  -o build/default/production/main.o  -c -mcpu=24F16KA102  -MMD -MF "build/default/production/main.o.d"        -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe"   I2C.c  -o build/default/production/I2C.o  -c -mcpu=24F16KA102  -MMD -MF "build/default/production/I2C.o.d"        -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe"   rtcc.c  -o build/default/production/rtcc.o  -c -mcpu=24F16KA102  -MMD -MF "build/default/production/rtcc.o.d"        -g -omf=elf -mlarge-code -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.00\bin\xc16-gcc.exe"   -o dist/default/production/gogo.X.production.elf  build/default/production/uart.o build/default/production/main.o build/default/production/I2C.o build/default/production/rtcc.o      -mcpu=24F16KA102        -omf=elf -Wl,--defsym=__MPLAB_BUILD=1,,--script=p24F16KA102.gld,--stack=16,--check-sections,--data-init,--pack-data,--handles,--isr,--no-gc-sections,--fill-upper=0,--stackguard=16,--no-force-link,--smart-io,--report-mem
Program Memory  [Origin = 0x200, Length = 0x29fe]
section                    address   length (PC units)   length (bytes) (dec)
.text                        0x200                0xe6           0x159  (345)
.const                       0x2e6                0x7e            0xbd  (189)
.text                        0x364               0xa80           0xfc0  (4032)
.dinit                       0xde4                0x1a            0x27  (39)
                     Total program memory used (bytes):         0x11fd  (4605) 28%
Data Memory  [Origin = 0x800, Length = 0x600]
section                    address      alignment gaps    total length  (dec)
.ndata                       0x800                   0            0x10  (16)
.nbss                        0x810                   0            0x10  (16)
build/default/production/rtcc.o(.text+0x8c): In function `.LSM26':
: undefined reference to `_rtcc'
build/default/production/rtcc.o(.text+0x92): In function `.LSM27':
build/default/production/rtcc.o(.text+0x98): In function `.LSM28':
build/default/production/rtcc.o(.text+0x9e): In function `.LSM29':
build/default/production/rtcc.o(.text+0xb6): In function `.LSM34':
build/default/production/rtcc.o(.text+0xbc): more undefined references to `_rtcc' follow
                        Total data memory used (bytes):           0x20  (32) 2%
Dynamic Memory Usage
region                     address                      maximum length  (dec)
heap                             0                                   0  (0)
stack                        0x820                               0x5e0  (1504)
                        Maximum dynamic memory (bytes):          0x5e0  (1504)
make[2]: *** [dist/default/production/gogo.X.production.hex] Error 255
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
make[2]: Leaving directory `C:/Microchip Solutions/workspace/gogo.X'
make[1]: Leaving directory `C:/Microchip Solutions/workspace/gogo.X'
BUILD FAILED (exit value 2, total time: 4s)
 楼主| zzjjhh 发表于 2012-8-22 16:38 | 显示全部楼层
咋回事啊
