F5310单片机的ADC采集实例讨论
3299|6
 楼主| shenmulzb1985 发表于 2012-9-7 11:44 | 显示全部楼层 |阅读模式
下边为TI官方ADC数据采集实例之一,为通过A11采集一电源电压AVCC
//  MSP430F530x Demo - ADC10, Sample A11, Lo_Batt, Clear P1.0 if AVcc < 2.3V
//  Description: A single sample is made on A11 (AVcc/2) with reference to
//  internal 1.5V Vref. Software sets ADC10SC to start sample and conversion
//  - ADC10SC automatically cleared at EOC. ADC10 internal oscillator times
//  sample (16x) and conversion. ADC10BUSY flag is polled for EOC. If A11
//  (AVcc/2) < 0311h (1.15V) indicating AVcc is less 2.3V, P1.0 reset indicating
//  a lo_Batt condition, else set.
//  ACLK = n/a, MCLK = SMCLK = default DCO ~1.2MHz, ADC10CLK = ADC10OSC
//                MSP430F530x
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |A11 (AVcc/2) P1.0|-->LED
//   B. Nisarga
//   Texas Instruments Inc.
//   Dec 2010
//   Built with CCSv4.2 and IAR Embedded Workbench Version: 4.21
#include <msp430f5310.h>
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  // Configure ADC10 - Pulse sample mode; ADC10SC trigger
  ADC10CTL0 = ADC10SHT_2 + ADC10ON;         // 16 ADC10CLKs; ADC ON
  ADC10CTL1 = ADC10SHP + ADC10CONSEQ_0;     // s/w trig, single ch/conv
  ADC10CTL2 = ADC10RES;                     // 10-bit conversion results
  ADC10MCTL0 = ADC10SREF_1 + ADC10INCH_11;  // AVcc/2
  // Configure internal reference
  while(REFCTL0 & REFGENBUSY);              // If ref generator busy, WAIT
  REFCTL0 |= REFVSEL_0+REFON;               // Select internal ref = 1.5V
                                            // Internal Reference ON
  __delay_cycles(75);                       // Delay (~75us) for Ref to settle
  P1DIR |= BIT0;                            // Set P1.0 to output direction
  P1OUT &= ~BIT0;                           // Clear P1.0
  while(1)
    ADC10CTL0 |= ADC10ENC + ADC10SC;        // Sampling and conversion start
    while (ADC10CTL1 & ADC10BUSY);          // ADC10BUSY?
    __no_operation();                       // For debug only
    if (ADC10MEM0 < 0x311)                  // is ADC10MEM = A11 > 1.15V?
      P1OUT &= ~BIT0;                       // Clear P1.0 LED off
    else
      P1OUT |= BIT0;                         // Set P1.0 LED on
现在我有几个疑问的请大家半忙解答下的啊:
(1)该采集电压信号的采集速率是多少?具体些的啊
(2)该ADC采集的时钟源是多少?
(3)我若想用A0 A1 A3 A5依次采集4路信号,该怎样配置相应的寄存器?具体些的啊
谢谢!
happybird21 发表于 2012-9-7 16:41 | 显示全部楼层
信号采集的速率不是有公式直接可以计算的吗,其他我也不清楚啦
firstblood 发表于 2012-9-7 18:03 | 显示全部楼层
楼主问这么具体的,我一时还真不能给你解答的,不过我下去查查资料的,在给你回答吧
wjzx111056 发表于 2012-9-7 21:39 | 显示全部楼层
__no_operation();  // For debug only。这个程序里面我认为是这句语句决定了采样的速率,但是我现在还不知道这个函数做什么的,如果能算出这个程序的执行时间,那么就能知道采样的速率了,我用的是MSP430F147,我是用定时器来决定采样的速率的。
figo20042005 发表于 2012-9-7 23:31 | 显示全部楼层
你去看DATASHEET吧,里面关于ADC的有详细寄存器说明的
springspring 发表于 2012-9-14 20:52 | 显示全部楼层
看一些例子应该就会的
looope 发表于 2012-9-30 22:35 | 显示全部楼层
多看看例子和手册吧
