‘高端’电流检测的必要性?
2051|3
 楼主| rollez 发表于 2012-9-7 23:45 | 显示全部楼层 |阅读模式
The LMP8645 is the right choice in the applications which re-
quires high side current sense, such as High Brightness LED
for automotive where the LED's cathode has to be connected
to the case (ground) of the car
. In this case the classical low
side current sense with a shunt resistor connected between
the LED's cathode and the case doesn't guarantee the ground
connection.
请问这种场合下LED负极为什么须要接地?
为什么高端电流检测是必要的?
yewuyi 发表于 2012-9-8 09:41 | 显示全部楼层
不知道你从哪里弄出来一句话?
呵呵,大家盲人摸象可给不了正确答案啊
 楼主| rollez 发表于 2012-9-8 10:29 | 显示全部楼层
从LMP8645的datasheet上节录的,这段话是说LMP8645的应用场合的。
不亦心 发表于 2012-9-8 10:29 | 显示全部楼层
这个LZ应该发到汽车电子上,问问为什么汽车系统中灯要这么接,
LZ问的问题和这颗IC没有半点关系。。。
