STM32F107串口中断问题!!
2854|0
 楼主| shijieqiji 发表于 2012-9-21 16:58 | 显示全部楼层 |阅读模式
为什么在串口中断发送接受的一包数据很不问题,有时数据变短有时还有乱码?中断代码如下:
void USART1_IRQHandler(void)       //
  uint8_t Data,i,RxBuffer[256],length;
        if (USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET)//注意!不能使用if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)来判断
                                USART_ClearFlag(USART1, USART_FLAG_ORE);
        USART_ReceiveData(USART1);
//          RxBuffer[length++]= USART_ReceiveData(USART1);
   Data = USART_ReceiveData(USART1);
         USART_ClearITPendingBit(USART1, USART_IT_RXNE);
                USART_SendData(USART1, Data);
          while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
串口软件显示:
[2012:09:21:12:21:05][发送]66 00 C8 00 00 C8 6A 00 F9
[2012:09:21:12:21:05][接收]66 00 C8 00 00 C8 6A 00 F9
[2012:09:21:12:21:06][发送]66 00 C8 00 00 C8 6A 00 F9
[2012:09:21:12:21:06][接收]66 00 C8 20 00 C8 6A 44 F9
[2012:09:21:12:21:06][接收]01 C8 00 00 C8 6A 00 F9
而且我想取一包数据中有效的位时,当加入  RxBuffer[length++]= USART_ReceiveData(USART1);这样的语句时,程序运行时已进入中断就死掉了。
请高手来给菜鸟详细讲解一下!
