中文应用笔记
1740|4
Go_PSoC|  楼主 | 2012-9-22 21:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主题Resource Type相关类别客户评级更新时间
AN75320 - Getting Started with PSoC® 1 Updated
The PSoC® 1 family combines the benefits of an ASIC with the convenience of an off-the-shelf device, but without the limitation of a fixed implementation.This application note describes the capabilities of PSoC 1 devices and the PSoC Designer™ development environment used to configure and program those devices.Included is an introductory project to help you develop PSoC 1 applications.
http://china.cypress.com/?rID=58639
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, CY8C23x33,CY8C28xxx, CY8C20x34,CY8C27x43, CY8C20xx6A,CY8C21x34, CY8C21x23,CY8C24x94, PSoC® 1, CY8C29x66
尚未评级
12 年 09 月 20 日
AN44168 - PSoC® 1 Device Programming using External Microcontroller (HSSP)
AN44168 describes the practical implementation of PSoC 1 programming procedure (source code provided in C language).It acts as a good starting point for developers wanting to create their own PSoC 1 programming solution.
http://china.cypress.com/?rID=2906
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x34,CY8C21x23, CY8C24x94,CY8C29x66
尚未评级
12 年 09 月 07 日
AN60486 - PSoC® 1 M8C ImageCraft C Code Optimization
AN60486 describes the basic guidelines of optimizing code for the PSoC1 M8C CPU using the ImageCraft compiler with PSoC Designer™.
http://china.cypress.com/?rID=45644
应用手册CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x23, PSoC® 1,CY8C29x66
(5/5) 2 个用户
12 年 09 月 07 日
AN50987 - Getting Started with I2C in PSoC® 1
AN50987 discusses the I2C protocol, and how the PSoC 1 device handles I2C communications.
http://china.cypress.com/?rID=34486
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C20x34, CY8C27x43,CY8C20xx6A, CY8C21x34,CY8C21x23, CY8C24x94, PSoC® 1,CY8C29x66
(4.8/5) 4 个用户
12 年 09 月 07 日
AN73212 - Debugging with PSoC® 1
AN73212 introduces the elements of the PSoC® 1 debugger system and explains how to configure and use them effectively
http://china.cypress.com/?rID=57555
应用手册PSoC® 1
尚未评级
12 年 09 月 07 日
AN74170 - PSoC® 1 Analog Structure and Configuration with PSoC Designer™
AN74170 explains the analog structure of standard PSoC® 1 devices and how the global analog parameters affect many of the analog user modules.
http://china.cypress.com/?rID=59181
应用手册PSoC Designer, PSoC® 1
尚未评级
12 年 08 月 26 日
AN65974 - Designing with the EZ-USB® FX3 Slave FIFO Interface
AN65974 describes the Synchronous Slave FIFO interface of EZ-USB® FX3.The hardware interface and configuration settings for the FLAGs are described in detail along with examples.References to the GPIF II Designer are included wherever necessary in order to make the Slave FIFO interface easy to design with.
http://china.cypress.com/?rID=51581
应用手册EZ-USB FX3™
(5/5) 1 个用户
12 年 08 月 17 日
AN4053 - Streaming Data Through Isochronous or Bulk Endpoints on EZ-USB® FX2™ and EZ-USB FX2LP™
Discusses streaming data via isochronous/bulk endpoints using the CY7C68013 EZ-USB FX2.
http://china.cypress.com/?rID=12967
应用手册EZ-USB AT2LP™, EZ-USB FX2LP™,USB Hi-Speed Peripherals
(5/5) 1 个用户
12 年 07 月 24 日
AN2397 - CapSense® Data Viewing Tools
AN2397 teaches you how to monitor data from any Cypress CapSense® controller using either the I2C or UART interface.With the tools described in this application note you can view and log real-time sensor data for CapSense tuning and debugging.
http://china.cypress.com/?rID=2784
应用手册Touch Sensing, CY8C20x34,CY8C21x34, CY8C24x94,CapSense® Controllers,SmartSense™, CapSense Plus
尚未评级
12 年 06 月
u880| | 2012-9-24 21:22 | 只看该作者
多谢版住,辛苦了
huigoushang| | 2012-9-24 21:35 | 只看该作者
一直都在为大家着想
G21372| | 2012-9-24 21:44 | 只看该作者
真的很感谢,哪天如果我成psoc高手了,肯定不会忘了楼主
