[应用相关] 为什么我用ISP一直连接不上呢?
5211|7
 楼主| huangfeng33 发表于 2012-9-25 22:12 | 显示全部楼层 |阅读模式
为什么我用ISP一直连接不上呢?STM32F103RBT8,BOOT0和1的电平也没问题。真是奇怪呀!哪位帮忙想想,可能是什么原因
行不改名 发表于 2012-9-25 22:23 | 显示全部楼层
可能的原因太多了...上图
airwill 发表于 2012-9-26 07:06 | 显示全部楼层
如果实在找不到原因了, 再告诉你一招: 摘自 AN2606
● The peripheral RX pins not used in this bootloader have to be kept at a known (low or high) level, and should not be left floating during the detection phase as described below:
– If USART1 is used to connect to the bootloader, the USART2_RX (PA15) pin has to be kept at a high or low level and must not be left floating during the detection phase.
– If USART2 is used to connect to the bootloader, the USART1_RX (PA10) pin has to be kept at a high or low level and must not be left floating during the detection phase.
● The peripheral to be used has to be connected through an RS232 serial interface (example, ST3232 RS232 transceiver) which must be:
– directly connected to the USART1_RX (PA10) and USART1_TX (PA9) pins when USART1 is used
– directly connected to the USART2_RX (PA15) and USART2_TX (PA14) pins when USART2 is used.
拿起书本 发表于 2012-9-27 21:48 | 显示全部楼层
检查串口是否正确? 检查单片机是否已经损坏?……
dfsa 发表于 2012-9-28 00:13 | 显示全部楼层
信息给多一点,才好帮你分析
火箭球迷 发表于 2012-9-28 00:19 | 显示全部楼层
上个电路图看下
yybj 发表于 2012-9-28 00:28 | 显示全部楼层
3楼的招式很管用,如果能写成中文,看着估计会方便点
figo20042005 发表于 2012-9-28 10:08 | 显示全部楼层
LZ试试3L的效果何如
