关于6410的定时器中断,高手,版主进来救命啊!
4070|7
 楼主| wsshopping 发表于 2012-10-5 19:35 | 显示全部楼层 |阅读模式
跑6410的裸机已经几天了,现在被中断这只拦路虎给截下来了,主要是没有搞懂启动码的问题,现在我贴上我的源程序,希望大家来帮帮忙呐。。。。不甚感激,各位大神们,你们的一句话就能拯救一个中国好青年啊。。这是我的main.c
#define rGPMCON (*(volatile unsigned *)0x7F008820)
#define rGPMDAT (*(volatile unsigned *)0x7f008824)
#define rGPMPUD (*(volatile unsigned *)0x7f008828)
#define rGPFCON (*(volatile unsigned *)(0x7F0080A0))
#define rGPFDAT (*(volatile unsigned *)(0x7F0080A4))
#define rGPFPUD (*(volatile unsigned *)(0x7F0080A8))
#define rGPNCON (*(volatile unsigned *)(0x7F008830))
#define rGPNDAT (*(volatile unsigned *)(0x7F008834))
#define rGPNPUD (*(volatile unsigned *)(0x7F008838))
#define PCLK 66000000  //for S3C6410 66MHZ
#define HCLK 133000000 //for S3C6410 133MHZ
#define rTCFG0 (*(volatile unsigned *)(0x7F006000))
#define rTCFG1 (*(volatile unsigned *)(0x7F006004))
#define rTCON (*(volatile unsigned *)(0x7F006008))
#define rTCNTB0 (*(volatile unsigned *)(0x7F00600C))
#define rTCMPB0 (*(volatile unsigned *)(0x7F006010))
#define rTCNTO0 (*(volatile unsigned *)(0x7F006014))
#define rTCNTB1 (*(volatile unsigned *)(0x7F006018))
#define rTCMPB1 (*(volatile unsigned *)(0x7F00601c))
#define rTCNTO1 (*(volatile unsigned *)(0x7F006020))
#define rTCNTB2 (*(volatile unsigned *)(0x7F006024))
#define rTCNTO2 (*(volatile unsigned *)(0x7F00602c))
#define rTCNTB3 (*(volatile unsigned *)(0x7F006030))
#define rTCNTO3 (*(volatile unsigned *)(0x7F006038))
#define rTCNTB4 (*(volatile unsigned *)(0x7F00603c))
#define rTCNTO4 (*(volatile unsigned *)(0x7F006040))
#define rTINT_CSTAT (*(volatile unsigned *)(0x7F006044))
#define rVIC0INTENABLE (*(volatile unsigned *)(0x71200010))
#define rVIC1INTENABLE (*(volatile unsigned *)(0x71300010))
#define rVIC0VECTADDR  ((volatile unsigned *)(0x71200100))
void IRQ_Exception(void);
void GPIO_Init(void)
// 初始化LED的IO配置
rGPMCON = 0x11111;
rGPMPUD = 0x0;
rGPMDAT = 0x1F;
// 初始化蜂鸣器IO配置
rGPFCON = rGPFCON & (~(0x1 << (31)));
rGPFCON = rGPFCON | (0x1 << (2*15));
rGPFPUD = rGPFPUD & (~(0x3 << (2*15))) ;
rGPFDAT = rGPFDAT & 0x7FFF;
void timer_init(void)
rTINT_CSTAT |= 1<<0;   //开timer0中断,允许timer0中断发生
rVIC0INTENABLE |= 1<<23;  //开timer0的使能(相当于关掉mask)
rTCFG0 &= ~0xFF;  // 清除预分频因子位
rTCFG0 |= 0x42;   // 设置分频因子(66分频), 定时器时钟频率为1Mhz
rTCFG1 &= ~0x11;  // 设置Divider MUX0为零 1分频
rTCNTB0 = 0x100000;   //设初值(1s)
rTCON |= 1<<1;      //开Manual Update (Update TCNTB0,TCMPB0)设置初值后要更新TCNTB
rTCON |= 1<<3;      //Auto Reload on  自动重装开启
rTCON |= 1<<0;        //timer0 open;
rTCON &= ~(1<<1);   //不再Update TCNTB0,TCMPB0
// 循环延时
void msDelay(int time)
volatile unsigned int i, j;
for(i = 0; i < 2000000; i++)
for (j = 0; j < time; j++);
// 打开控件蜂鸣器的三极管
void BeepOff(void)
rGPFDAT = rGPFDAT  & 0x7fff;
// 关闭控件蜂鸣器的三极管
void BeepOn(void)
rGPFDAT = rGPFDAT | 0x8000;
int i = 0;
// IRQ异常中断
void IRQ_Exception()
i %= 4;
// 打开一个灯,并闭另外一个灯
rGPMDAT = ~(1<<i++);
BeepOn();
msDelay(5);
BeepOff();
// 清除定时器中断状态位
while((rTINT_CSTAT & 0x20)) rTINT_CSTAT |= (1 << 5);
void Main()
GPIO_Init();
timer_init();
while(1);
这是我的init.s
IMPORT main
IMPORT IRQ_Exception
AREA |C$$code|, CODE, READONLY
ENTRY
start
;interrupt vectors
;中断向量表
Reset
LDR     PC, ResetAddr
    LDR     PC, UndefinedAddr
    LDR     PC, SWI_Addr
    LDR     PC, PrefetchAddr
    LDR     PC, DataAbortAddr
    DCD     0xb9205f80
    LDR     PC, IRQAddr
    LDR     PC, FIRQAddr
ResetAddr           DCD     ResetInit
UndefinedAddr       DCD     Undefined
SWI_Addr            DCD     SoftwareInterrupt
PrefetchAddr        DCD     PrefetchAbort
DataAbortAddr       DCD     DataAbort
                    DCD     0
IRQAddr             DCD     IRQHandler
FIRQAddr            DCD     FIRQHandler
;未定义指令
Undefined
B       Undefined
;软中断
SoftwareInterrupt
        B       SoftwareInterrupt
;取指令中止
PrefetchAbort
        B       PrefetchAbort
;取数据中止
DataAbort
        B       DataAbort
IRQHandler
        STMFD SP!,{r0-r3,r12,lr}           ;保存现场
        ldr lr, =int_return                ;设置中断异常处理程序返回地址到下面的位置
        B  IRQ_Exception                   ;直接进入到中断函数处理
int_return
        LDMFD SP!,{r0-r3,r12,lr}           ;恢复现场
        SUBS PC,LR,#4                      ;返回进入中断前的代码
FIRQHandler
STMFD sp!,{r0-r12,lr}
B      FIRQHandler
LDMFD sp!, {r0-r12,lr}
SUBS  pc, lr,#4
;禁止中断
DISABLE_IRQ
MRS R0, CPSR
ORR R0, R0, #0x80
MSR CPSR_c, R0
MOV PC, LR
;允许中断
ENABLE_IRQ
MRS R0, CPSR         ;将CPSR保存至R0寄存器中
BIC R0, R0, #0x80    ;R0 = R0 & ~0x80,清除中断位
MSR CPSR_c, R0       ;将R0写回CPSR状态寄存器
MOV PC, LR           ;返回到调用代码
ResetInit
LDR R14, =0x50100000 ;初始化一下栈指针
BL       ENABLE_IRQ  ;打开中断允许位
B       main
     ;跳入MAIN程序
END
现在我的问题是:
谁能告诉我他这个启动码是按照什么流程来写,大概给我一些注释就行(首先是什么,然后是什么,接着是什么,最后是什么)
 楼主| wsshopping 发表于 2012-10-5 19:36 | 显示全部楼层
主要问题在init.s这个问题上
阿南 发表于 2012-10-6 11:39 | 显示全部楼层
首先是一段各中断(或称异常)的入口,然后在0x0处转到起始处关看门狗、中断等,初始化内存控制器、各异常模式下的堆栈等,安装各中断向量表,再复制镜像代码到内存区运行等。。。
三星的所有处理器的启动代码基本相同,所以详细情况你可以参考《ARM Linux入门与实践》一书的关于S3C2410的启动代码。
 楼主| wsshopping 发表于 2012-10-6 16:23 | 显示全部楼层
3# 阿南 谢谢南哥,在问你一下,我简单的想实现6410定时器的中断,是用这上面的汇编代码还是应该用这个啊mrc p15,0,r0,c1,c0,0
orr r0,r0,#(1<<24)
mcr p15,0,r0,c1,c0,0
阿南 发表于 2012-10-6 16:35 | 显示全部楼层
定时器中断,首先要初始化定时器寄存器及中断相关的寄存器,使用上面的汇编和那段代码都还不够。
p15是协处理器
评分
参与人数 1威望 +1 收起 理由
wsshopping + 1
查看全部评分
 楼主| wsshopping 发表于 2012-10-6 19:50 | 显示全部楼层
5# 阿南 噢,受益良多啊,还有一个就是我上面发的那个程序,用JLINK调试的时候就是进不了定时器中断,真心不晓得为什么,我把我的调试信息贴上,帮忙看看,谢谢啦,我都是按顺序来的!
 楼主| wsshopping 发表于 2012-10-6 19:52 | 显示全部楼层
在线等你回复了,程序里面的代码都是上面贴出来了的
阿南 发表于 2012-10-7 08:31 | 显示全部楼层
把你调试时设置为混合模式,可以看到反汇编及代码实践的地址数据。
在0x18处设置一个断点,然后跟踪进去看是否是中断向量表没有安装好。
