5310单片机中最新日历时间调试分享
3391|3
 楼主| comeon201208 发表于 2012-10-16 16:13 | 显示全部楼层 |阅读模式
下边给各位分享的是我利用MSP430F5310单片机实现的关于自带日历时间输出和调整的程序,分享给大家了。。
** 版权:   杭州利尔达科技有限公司
** 文件名: LSD-TEST430F5529-RTC.c
** 版本:  IAR 4.21
** 工作环境:
** 作者:
** 生成日期:
** 功能:     RTC实时时钟
                 MSP430F5529
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |          P8.0   |--> LED5
//            |          P1.0   |--> LED3
** 相关文件:  LSD-TEST430F5529 V1.0
** 修改日志
**相关说明:
#include "msp430f5310.h"
#define uchar unsigned char
#define uint unsigned int
typedef struct  {
  uint year ;       //
  uchar month;        //
  uchar day;     //
  uchar week;
  uchar hour;  //
  uchar min;     //
  uchar second;
  uchar flag;
      } time;
time RTC;
uchar temp,temp1,data1,receive_buffer[15],receive_flag =0,receive_count=0,count=0;
void Init_Rtc(void);
void Init_Clk(void);
void Init_System(void);
void UartConfig(void);
void main(void)
    WDTCTL = WDTPW + WDTHOLD;                    // 关看门狗
    PMAPPWD = 0x02D52;                        // Enable Write-access to modify port mapping registers
    P4MAP7 = PM_MCLK;
    PMAPPWD = 0;                              // Disable Write-Access to modify port mapping registers
    Init_System();                               // 系统初始化
    __bis_SR_register(GIE);
   // for(uchar i=0;i<200;i++)                  //UART1 test
   //   while (!(UCA1IFG&UCTXIFG));
    //     UCA1TXBUF = 0xAA;
   //      _NOP();
    while(1)
      if(RTC.flag ==0x01)
        RTC.flag =0;
        temp =RTC.year>>8;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
        temp =RTC.year;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
        temp =0x2D;
         UCA1TXBUF = temp;
        temp =RTC.month;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
         temp =0x2D;
         UCA1TXBUF = temp;
        temp =RTC.day;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
         temp =0x20;
         UCA1TXBUF = temp;
        // temp =RTC.week;
        //while (!(UCA1IFG&UCTXIFG));
        // UCA1TXBUF = temp;
         temp =RTC.hour;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
         temp =0x3A;
         UCA1TXBUF = temp;
         temp =RTC.min;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
         temp =0x3A;
         UCA1TXBUF = temp;
         temp =RTC.second;
        temp1 =temp;
        temp =temp>>4;
        temp +=48;
         UCA1TXBUF = temp;
         temp =temp1&0x0f;
         temp +=48;
         UCA1TXBUF = temp;
        temp =0x20;
         UCA1TXBUF = temp;
        _NOP();
      if((receive_flag &0x04)==0x04)
        receive_flag =0;
        RTCCTL01 = RTCBCD +  RTCHOLD + RTCMODE + RTCTEV_0 ;
        RTCPS0CTL =   RT0PSHOLD ;                 //配置两个计数器分频
        RTCPS1CTL  =  RT1PSHOLD ;
        RTCSEC =  receive_buffer[10];                           //初始化秒
        RTCMIN =  receive_buffer[9] ;                          //初始化分钟
        RTCHOUR = receive_buffer[8];                            //初始化小时
        RTCDOW = receive_buffer[7] ;
        RTCDAY =  receive_buffer[6];                       //日期初始化
        RTCMON =  receive_buffer[5];                      //初始化月份
        RTCYEAR = 0x2000+receive_buffer[4];                     //初始化年份
        RTCAMINHR = 0X2200 + BIT7;            //闹钟小时和分钟设置
        RTCADOWDAY = 0X2402;                  //闹钟星期和日期设置
        RTCCTL01 &= ~RTCHOLD;                 //打开RTC模块
        RTCPS0CTL &= ~RT0PSHOLD;              //打开RTCPS0CTL
        RTCPS1CTL &= ~RT1PSHOLD;              //打开RTCPS1CTL
        RTCCTL0 |= RTCAIE + RTCRDYIE;         //打开安全访问使能 ,闹钟使能
     // __bis_SR_register(LPM3_bits);  //// 进入低功耗3
/************************ RTC中断*****************************/
#pragma vector=RTC_VECTOR
__interrupt void basic_timer(void)
    switch(RTCIV)
    case 2 : P1OUT ^= BIT1;
            RTC.year=RTCYEAR;
            RTC.month= RTCMON;
            RTC.day=RTCDAY;
            RTC.week=RTCDOW;
            RTC.hour= RTCHOUR;
            RTC.min=RTCMIN;
            RTC.second=RTCSEC;
            RTC.flag =0x01;
            break;             //RTCRDYIFG
    case 4 : break;
    case 6 : break;             //RTCAIFG P8OUT |= BIT0;
    case 8 : break;
    case 10 : break;
函数(模块)名称:void Init_System(void)
功能:  该程序系统初始化
本函数(模块)调用的函数(模块)清单:
调用本函数(模块)的函数(模块)清单:
输入参数:   void
输出参数:    void
函数返回值说明 :void
使用的资源
其它说明:
    Init_Clk();                                 //调用时钟函数
    Init_Rtc();                                 //RTC 初始化
    UartConfig();
    P1DIR |= BIT1;                              //P1.0为输出
    P1OUT &= ~BIT1;
  //  P8DIR |= BIT0;                              //P7.7为输出
  //  P8OUT &= ~BIT0;
函数(模块)名称:void Init_Rtc(void)
功能:  RTC初始化
本函数(模块)调用的函数(模块)清单:
调用本函数(模块)的函数(模块)清单:
输入参数:   void
输出参数:    void
函数返回值说明 :void
使用的资源
其它说明:
void Init_Rtc(void)
{                                             // BCD码日历格式输出
    RTCSEC =  0x54;                           //初始化秒
    RTCMIN =  0X59 ;                          //初始化分钟
    RTCHOUR = 0X10;                            //初始化小时
    RTCDOW = 0X01 ;
    RTCDAY =  0x15;                       //日期初始化
    RTCMON =  0X10 ;                      //初始化月份
    RTCYEAR = 0x2012;                     //初始化年份
函数(模块)名称:void Init_Clk(void)
功能: 时钟初始化
本函数(模块)调用的函数(模块)清单:
调用本函数(模块)的函数(模块)清单:
输入参数:   void
输出参数:    void
函数返回值说明 :void
使用的资源
其它说明:
void Init_Clk(void)
    P1DIR |= BIT0;                            // MCLK set out to pins
    P1SEL |= BIT0;
    //P5SEL = BIT3 + BIT2;                   //启动XT2
     P5SEL = BIT4 + BIT5;                   //启动XT1
   // UCSCTL6 &= ~XT2OFF;                       // Enable XT2
    UCSCTL6 &= ~XT1OFF;                       // Enable XT2
    UCSCTL1 = DCORSEL_2;                   //DCO 范围配置
    UCSCTL3 |= SELREF_2;                      // FLLref = REFO
                                            // Since LFXT1 is not used,
                                            // sourcing FLL with LFXT1 can cause
                                            // XT1OFFG flag to set
    UCSCTL4 |= SELA_2;                        // ACLK=REFO,SMCLK=DCO,MCLK=DCO
    while (SFRIFG1 & OFIFG)                //等待时钟系统正常工作
        __delay_cycles(100000);
        UCSCTL7 &= ~( XT1LFOFFG + DCOFFG);
        SFRIFG1 &= ~OFIFG;
    UCSCTL4 = SELM_3 + SELA_0 + SELS_4;    //设置时钟源
  P4SEL = 0x30;                            // P4.4,4,5 USCI_A0 option select
  P4DIR |=BIT4;
  UCA1CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA1CTL1 |= UCSSEL__ACLK;                     // SMCLK//ACLK
  UCA1BR0 = 3;                              // 32768Hz 9600 (see User's Guide)
  UCA1BR1 = 0;                              // 32768Hz 9600
  UCA1MCTL = UCBRS_3 + UCBRF_0;            // Modln UCBRSx=0, UCBRFx=0,
                                            // over sampling
  UCA1CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UCA1IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
#pragma vector=USCI_A1_VECTOR
__interrupt void USCI_A1_ISR(void)
  switch(__even_in_range(UCA1IV,4))
  case 0:break;                             // Vector 0 - no interrupt
  case 2:                                   // Vector 2 - RXIFG
    data1=UCA1RXBUF;
    if(data1 ==0xA4)
      receive_flag =0x01;                   //
      receive_buffer[receive_count ++]=data1;
    else if(receive_flag ==0x01)
      receive_flag =0x02;
      count =data1+4;
    else if(receive_flag ==0x02)
      if(receive_count<count)
        if(receive_count ==count)
          if(receive_buffer[3]==0xFF)
            receive_flag |=0x04;
          receive_count =0;
      else
        receive_flag =0;
        receive_count =0;
    break;
  case 4:break;                             // Vector 4 - TXIFG
  default: break;
gaoyang9992006 发表于 2012-10-21 10:24 | 显示全部楼层
这么好的帖子为啥没有人顶呢,这么无良:lol
hawksabre 发表于 2012-10-21 11:54 | 显示全部楼层
呵呵   这个例程没用到  呵呵   顶一个   希望楼主能够多多分享   谢谢
gygp 发表于 2012-10-21 22:58 | 显示全部楼层
很复杂,楼主给讲解一下最好了!
