在DFU中读取用户字节出错。请大神。。
1914|0
 楼主| goldenkey1981 发表于 2012-10-18 19:10 | 显示全部楼层 |阅读模式
TI, ic, IO, ST, se
u16 TMP_UP;
int main(void)
  TMP_UP=0;
  TMP_UP=OPT_ReadUserData();
  //  DFU_Button_Config();
  /* Check if the Key push-button on STM3210x-EVAL Board is pressed */
  //if (DFU_Button_Read() != 0x00)
  if (TMP_UP & 0x0004)   //如果标志位为1
/* Test if user code is programmed starting from address 0x8003000 */
    if (((*(__IO uint32_t*)ApplicationAddress) & 0x2FFE0000 ) == 0x20000000)
    { /* Jump to user application */
      JumpAddress = *(__IO uint32_t*) (ApplicationAddress + 4);
      Jump_To_Application = (pFunction) JumpAddress;
      /* Initialize user application's Stack Pointer */
      __set_MSP(*(__IO uint32_t*) ApplicationAddress);
      Jump_To_Application();
  } /* Otherwise enters DFU mode to allow user to program his application */
  /* Enter DFU mode */
  DeviceState = STATE_dfuERROR;
  DeviceStatus[0] = STATUS_ERRFIRMWARE;
  DeviceStatus[4] = DeviceState;
  Set_System();
  Set_USBClock();
  USB_Init();
  /* Main loop */
  while (1)
以上代码在最前面读到用户字节总是出错是什么原因了。请大神指点呀
