2、编写do文
1 #Creat a work lib 2 vlib work 3 4 #Map the work lib to current lib 5 vmap work work 6 7 #Compile the source files 8 vlog F:/work/dcm/src/dcm.v 9 vlog F:/work/dcm/src/dcm_tb.v10 vlog F:/work/dcm/src/my_dcm.v11 vlog F:/work/dcm/src/glbl.v12 #start simulator13 14 vsim -L xilinxcorelib_ver -L secureip -L simprims_ver -L unisims_ver -novopt work.dcm_tb work.glbl 15 16 #add wave17 18 add wave /*19 20 21 22 23 24 25 26 27 run -all
第14行是编译xilinx中的几个库,在最后需要加上work.glbl。
3、然后运行modelsim仿真
(1):建立工程
(2):在命令窗口输入:do dcm.do
仿真结果如下:
