中文应用笔记
3965|8
Go_PSoC|  楼主 | 2012-11-8 23:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Go_PSoC|  楼主 | 2012-11-8 23:23 | 只看该作者
主题Resource Type相关类别客户评级更新时间
AN75320 - Getting Started with PSoC® 1 Updated
The PSoC® 1 family combines the benefits of an ASIC with the convenience of an off-the-shelf device, but without the limitation of a fixed implementation.This application note describes the capabilities of PSoC 1 devices and the PSoC Designer™ development environment used to configure and program those devices.Included is an introductory project to help you develop PSoC 1 applications.
http://china.cypress.com/?rID=58639
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, CY8C23x33,CY8C28xxx, CY8C20x34,CY8C27x43, CY8C20xx6A,CY8C21x34, CY8C21x23,CY8C24x94, PSoC® 1, CY8C29x66
尚未评级
12 年 11 月 08 日
AN74170 - PSoC® 1 Analog Structure and Configuration with PSoC Designer™Updated
AN74170 explains the analog structure of standard PSoC® 1 devices and how the global analog parameters affect many of the analog user modules.
http://china.cypress.com/?rID=59181
尚未评级
12 年 11 月 07 日
AN2397 - CapSense® Data Viewing Tools Updated
AN2397 teaches you how to monitor data from any Cypress CapSense® controller using either the I2C or UART interface.With the tools described in this application note you can view and log real-time sensor data for CapSense tuning and debugging.
http://china.cypress.com/?rID=2784
应用手册CY8C20xx7/S, Touch Sensing,CY8C20x34, CY8C21x34,CY8C24x94, CapSense® Controllers, SmartSense™,CapSense Plus
尚未评级
12 年 11 月 07 日
AN73212 - Debugging with PSoC® 1 Updated
AN73212 introduces the elements of the PSoC® 1 debugger system and explains how to configure and use them effectively
http://china.cypress.com/?rID=57555
尚未评级
12 年 11 月 05 日
AN66806 - Getting Started with EZ-USB® FX2LP™ GPIF
The GPIF is a programmable parallel interface that provides a glue-less interface between the EZ-USB® FX2LP™ and an external peripheral.
http://china.cypress.com/?rID=12937
应用手册USB 高速外设
(4.7/5) 3 个用户
12 年 10 月 16 日
AN65974 - Designing with the EZ-USB® FX3 Slave FIFO Interface
AN65974 describes the Synchronous Slave FIFO interface of EZ-USB® FX3™.
http://china.cypress.com/?rID=51581
应用手册EZ-USB FX3™
(4.3/5) 4 个用户
12 年 09 月 26 日
AN44168 - PSoC® 1 Device Programming using External Microcontroller (HSSP)
AN44168 describes the practical implementation of PSoC 1 programming procedure (source code provided in C language).It acts as a good starting point for developers wanting to create their own PSoC 1 programming solution.
http://china.cypress.com/?rID=2906
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x34,CY8C21x23, CY8C24x94,CY8C29x66
尚未评级
12 年 09 月 07 日
AN60486 - PSoC® 1 M8C ImageCraft C Code Optimization
AN60486 describes the basic guidelines of optimizing code for the PSoC1 M8C CPU using the ImageCraft compiler with PSoC Designer™.
http://china.cypress.com/?rID=45644
应用手册CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x23, PSoC® 1,CY8C29x66
(5/5) 2 个用户
12 年 09 月 07 日
AN50987 - Getting Started with I2C in PSoC® 1
AN50987 discusses the I2C protocol, and how the PSoC 1 device handles I2C communications.
http://china.cypress.com/?rID=34486
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C20x34, CY8C27x43,CY8C20xx6A, CY8C21x34,CY8C21x23, CY8C24x94, PSoC® 1,CY8C29x66
(4.8/5) 4 个用户
12 年 09 月 07 日
AN4053 - Streaming Data Through Isochronous or Bulk Endpoints on EZ-USB® FX2™ and EZ-USB FX2LP™
Discusses streaming data via isochronous/bulk endpoints using the CY7C68013 EZ-USB FX2.
http://china.cypress.com/?rID=12967
应用手册EZ-USB AT2LP™, EZ-USB FX2LP™,USB Hi-Speed Peripherals
(5/5) 1 个用户
12 年 07 月 24
acer4736| | 2012-11-11 16:23 | 只看该作者
这么多,支持一下
jinpaidianzi| | 2012-11-11 16:42 | 只看该作者
多谢分享
teabottle| | 2012-11-11 16:46 | 只看该作者
支持
wangjinlili| | 2012-11-11 16:53 | 只看该作者
下来学习一下
meishizhaoshi| | 2012-11-11 16:59 | 只看该作者
去看看
shibalihuandao| | 2012-11-11 17:05 | 只看该作者
进去选一些看看
sishangcine| | 2012-11-11 17:07 | 只看该作者
多谢分享
