最近更新的应用笔记
2330|18
Go_PSoC|  楼主 | 2012-11-28 12:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TitleResource TypeRelated CategoriesCustomer RatingUpdated
AN48303 - CapSense® Express™ - Migrating from Firmware Rev 0x15 to Rev 0x1B Updated
AN48303 discusses the compatibility issues that you should consider before migrating from CapSense® Express™ firmware revision 0x15 to 0x1B.
http://www.cypress.com/?rID=17624
Application NotesCY8C201xxx, CapSense® Controllers, SmartSense™
(5/5) by 1 user
11/23/12
AN44517 - Design Recommendation for Battery Backed SRAMs Using Cypress MoBL® SRAMs Updated
http://www.cypress.com/?rID=12710
Application NotesAsync Micropower (MoBL™) SRAMs
(5/5) by 1 user
11/23/12
AN81623 - PSoC® 3 and PSoC 5 Digital Design Best Practices Updated
AN81623 gives a brief introduction to digital hardware design theory and then describes the powerful and highly flexible digital subsystem in PSoC 3 and PSoC 5. It describes best practices for digital design using PSoC Creator, and shows how to use static timing analysis (STA) report files.
http://www.cypress.com/?rID=67774
Application NotesPSoC® 5, PSoC® 3
Not yet rated
11/23/12
AN73212 - Debugging with PSoC® 1 Updated
AN73212 introduces the elements of the PSoC® 1 debugger system and explains how to configure and use them effectively
http://www.cypress.com/?rID=57555
Application NotesCY8C22xxx/CY8C21x45,CY8C24x23A, CY8C23x33,CY8C28xxx, CY8C20x34,CY8C27x43, CY8C20xx6A,CY8C21x34, CY8C21x23,CY8C24x94, PSoC® 1, CY8C29x66
Not yet rated
11/21/12
AN73617 - PSoC® Designer Boot Process, From Reset to Main Updated
AN73617 describes the PSoC® Designer initialization process of PSoC 1, from the release of reset to the start of C code execution in main. The application note includes instructions on how to modify the interrupt vector table to execute custom interrupt service routines.
http://www.cypress.com/?rID=58522
Application NotesCY8C22xxx/CY8C21x45,CY8C24x23A, CY8C23x33,CY8C28xxx, CY8C20x34,CY8C27x43, CY8C20xx6A,CY8C21x34, CY8C21x23,CY8C24x94, CY8C29x66
(5/5) by 1 user
11/21/12
AN2361 - PSoC® 1 USB-Powered Battery Charger for NiCd/NiMH Batteries Updated
AN2361 describes a USB-powered battery charger for NiCd/NiMH batteries that permits rapid recharging.
http://www.cypress.com/?rID=2865
Application NotesCY8C24x23A, CY8C28xxx,CY8C27x43, CY8C24x94,CY8C29x66
(4/5) by 1 user
11/20/12
AN50987 - Getting Started with I2C in PSoC® 1 Updated
AN50987 discusses the I2C protocol, and how the PSoC 1 device handles I2C communications.
http://www.cypress.com/?rID=34486
Application NotesCY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C20x34, CY8C27x43,CY8C20xx6A, CY8C21x34,CY8C21x23, CY8C24x94, PSoC® 1,CY8C29x66
(4.8/5) by 4 users
11/20/12
AN60486 - PSoC® 1 M8C ImageCraft C Code Optimization Updated
AN60486 describes the basic guidelines of optimizing code for the PSoC1 M8C CPU using the ImageCraft compiler with PSoC Designer™.
http://www.cypress.com/?rID=45644
Application NotesCY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x23, PSoC® 1,CY8C29x66
(5/5) by 2 users
11/20/12
AN74170 - PSoC® 1 Analog Structure and Configuration with PSoC Designer™ Updated
AN74170 explains the analog structure of standard PSoC® 1 devices and how the global analog parameters affect many of the analog user modules.
http://www.cypress.com/?rID=59181
(5/5) by 1 user
11/20/12
AN44168 - PSoC® 1 Device Programming using External Microcontroller (HSSP) Updated
AN44168 describes the practical implementation of PSoC 1 programming procedure (source code provided in C language). It acts as a good starting point for developers wanting to create their own PSoC 1 programming solution.
http://www.cypress.com/?rID=2906
Application NotesCY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x34,CY8C21x23, CY8C24x94,CY8C29x66
Not yet rated
11/20/12
AN70486 - EZ-USB® FX2LP™ Host Application in VC++ 2008 Using Suite USB Library (CyUSB.dll) Updated
Cypress’s FX2LP is one of the most popular programmable high-speed USB controllers in the industry. Cypress provides SuiteUSB for creating windows applications using Microsoft Visual Studio. This application note demonstrates how to build a host application on Microsoft Visual C++ platform, using the Cypress SuiteUSB C# library, CyUSB.dll, to perform USB BULK IN and OUT transfers with FX2LP and the associated project is tested with FX2LP Development kit.
http://www.cypress.com/?rID=53167
Application NotesEZ-USB FX2LP™
Not yet rated
11/20/1
waitingf| | 2012-11-28 13:50 | 只看该作者
多谢楼主分享
someonewho| | 2012-11-28 14:06 | 只看该作者
更新了不少呀
justbybing| | 2012-11-28 14:30 | 只看该作者
都很不错
specialfrin| | 2012-11-28 14:41 | 只看该作者
很有用的资料
someontime| | 2012-11-28 14:55 | 只看该作者
多多益善:lol
haidixibahe| | 2012-11-28 15:03 | 只看该作者
学习学习
chao11yue| | 2012-11-29 10:34 | 只看该作者
多谢楼主提醒
engtafanzhuan| | 2012-11-29 10:48 | 只看该作者
这些应用笔记都很棒
xichengmadia| | 2012-11-29 10:56 | 只看该作者
来看看
beiwaroad| | 2012-11-29 13:09 | 只看该作者
up 顶一个
taihezhibanh| | 2012-11-29 13:39 | 只看该作者
看看usb方面的
heibaiyinjiag| | 2012-11-29 13:52 | 只看该作者
学习一下
sishangcine| | 2012-11-29 18:23 | 只看该作者
都很有用的说
meishizhaoshi| | 2012-11-29 18:54 | 只看该作者
很不错呦
wangjinlili| | 2012-11-29 18:57 | 只看该作者
一眨眼有这么多了
teabottle| | 2012-11-29 19:00 | 只看该作者
先大概看一下
jinpaidianzi| | 2012-11-29 19:04 | 只看该作者
看一看
