DSP与Simulink设计之CMD文件
2921|2
 楼主| gygp 发表于 2012-12-3 23:22 | 显示全部楼层 |阅读模式
1 概述
基于Matlab的Simulink生成的CMD文件根据系统定制配置,只限于在RAM中运行。
目的:更改CMD文件,程序烧写到FLASH中运行。
2 Simulink生成CMD介绍
生成的CMD文件在RAM中运行,无法烧写到FLASH中运行。
(1)此段CMD文件为Simulink自动生成的文件。
MEMORY
PAGE 0:
BEGINRAM: origin=0x0, length=0x2
RAMM0: origin=0x2, length=0x3fe
RAMH0: origin=0xa000, length=0x2000
OTP: origin=0x3d7800, length=0x800
FLASH: origin=0x3e8000, length=0xfff6
BEGINFLASH: origin=0x3f7ff6, length=0x2
CSM_PWL: origin=0x3f7ff8, length=0x8
BOOTROM: origin=0x3ff000, length=0xfc0
RESET: origin=0x3fffc0, length=0x2
VECTORS: origin=0x3fffc2, length=0x3e
PAGE 1:
RAMM1: origin=0x400, length=0x400
RAML0L1: origin=0x8000, length=0x2000
SECTIONS
.vectors: load = 0x000000000
.text: > RAMH0, PAGE = 0
.switch: > RAMH0, PAGE = 0
.bss: > RAML0L1, PAGE = 1
.ebss: > RAML0L1, PAGE = 1
.far: > RAML0L1, PAGE = 1
.cinit: > RAMH0, PAGE = 0
.pinit: > RAMH0, PAGE = 0
.const: > RAML0L1, PAGE = 1
.econst: > RAML0L1, PAGE = 1
.reset: > RESET, PAGE = 0, TYPE = DSECT
.data: > RAML0L1, PAGE = 1
.cio: > RAML0L1, PAGE = 1
.sysmem: > RAML0L1, PAGE = 1
.esysmem: > RAML0L1, PAGE = 1
.stack: > RAMM1, PAGE = 1
.rtdx_text: > RAMH0, PAGE = 0
.rtdx_data: > RAML0L1, PAGE = 1
IQmath: > RAMH0, PAGE = 0
codestart: > BEGINRAM, PAGE = 0
csmpasswds: > CSM_PWL, PAGE = 0
csm_rsvd: > RAMM0, PAGE = 0
ramfuncs: > RAMH0, PAGE = 0
IQmathTables: > BOOTROM, PAGE = 0, TYPE = NOLOAD
-l
"C:\Program Files\MATLAB\R2009a\toolbox\rtw\targets\ccslink\ccslink\c2000\c280xPeripherals.cmd"
(2)以下为连接路径的CMD文件,c280xPeripherals.cmd。
MEMORY
PAGE 0: /* Program Memory */
PAGE 1 : /* Data Memory */
DEV_EMU : origin = 0x000880, length = 0x000180 /* device emulation registers */
FLASH_REGS : origin = 0x000A80, length = 0x000060 /* FLASH registers */
CSM : origin = 0x000AE0, length = 0x000010 /* code security module registers */
ADC_MIRROR : origin = 0x000B00, length = 0x000010 /* ADC Results register mirror */
CPU_TIMER0 : origin = 0x000C00, length = 0x000008 /* CPU Timer0 registers */
CPU_TIMER1 : origin = 0x000C08, length = 0x000008 /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
CPU_TIMER2 : origin = 0x000C10, length = 0x000008 /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
PIE_CTRL : origin = 0x000CE0, length = 0x000020 /* PIE control registers */
PIE_VECT : origin = 0x000D00, length = 0x000100 /* PIE Vector Table */
ECANA : origin = 0x006000, length = 0x000040 /* eCAN-A control and status registers */
ECANA_LAM : origin = 0x006040, length = 0x000040 /* eCAN-A local acceptance masks */
ECANA_MOTS : origin = 0x006080, length = 0x000040 /* eCAN-A message object time stamps */
ECANA_MOTO : origin = 0x0060C0, length = 0x000040 /* eCAN-A object time-out registers */
ECANA_MBOX : origin = 0x006100, length = 0x000100 /* eCAN-A mailboxes */
ECANB : origin = 0x006200, length = 0x000040 /* eCAN-B control and status registers */
ECANB_LAM : origin = 0x006240, length = 0x000040 /* eCAN-B local acceptance masks */
ECANB_MOTS : origin = 0x006280, length = 0x000040 /* eCAN-B message object time stamps */
ECANB_MOTO : origin = 0x0062C0, length = 0x000040 /* eCAN-B object time-out registers */
ECANB_MBOX : origin = 0x006300, length = 0x000100 /* eCAN-B mailboxes */
EPWM1 : origin = 0x006800, length = 0x000022 /* Enhanced PWM 1 registers */
EPWM2 : origin = 0x006840, length = 0x000022 /* Enhanced PWM 2 registers */
EPWM3 : origin = 0x006880, length = 0x000022 /* Enhanced PWM 3 registers */
EPWM4 : origin = 0x0068C0, length = 0x000022 /* Enhanced PWM 4 registers */
EPWM5 : origin = 0x006900, length = 0x000022 /* Enhanced PWM 5 registers */
EPWM6 : origin = 0x006940, length = 0x000022 /* Enhanced PWM 6 registers */
ECAP1 : origin = 0x006A00, length = 0x000020 /* Enhanced Capture 1 registers */
ECAP2 : origin = 0x006A20, length = 0x000020 /* Enhanced Capture 2 registers */
ECAP3 : origin = 0x006A40, length = 0x000020 /* Enhanced Capture 3 registers */
ECAP4 : origin = 0x006A60, length = 0x000020 /* Enhanced Capture 4 registers */
EQEP1 : origin = 0x006B00, length = 0x000040 /* Enhanced QEP 1 registers */
EQEP2 : origin = 0x006B40, length = 0x000040 /* Enhanced QEP 2 registers */
GPIOCTRL : origin = 0x006F80, length = 0x000040 /* GPIO control registers */
GPIODAT : origin = 0x006FC0, length = 0x000020 /* GPIO data registers */
GPIOINT : origin = 0x006FE0, length = 0x000020 /* GPIO interrupt/LPM registers */
SYSTEM : origin = 0x007010, length = 0x000020 /* System control registers */
SPIA : origin = 0x007040, length = 0x000010 /* SPI-A registers */
SCIA : origin = 0x007050, length = 0x000010 /* SCI-A registers */
XINTRUPT : origin = 0x007070, length = 0x000010 /* external interrupt registers */
ADC : origin = 0x007100, length = 0x000020 /* ADC registers */
SPIB : origin = 0x007740, length = 0x000010 /* SPI-B registers */
SCIB : origin = 0x007750, length = 0x000010 /* SCI-B registers */
SPIC : origin = 0x007760, length = 0x000010 /* SPI-C registers */
SPID : origin = 0x007780, length = 0x000010 /* SPI-D registers */
I2CA : origin = 0x007900, length = 0x000040 /* I2C-A registers */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations. */
SECTIONS
/*** Peripheral Frame 0 Register Structures ***/
DevEmuRegsFile : > DEV_EMU, PAGE = 1
FlashRegsFile : > FLASH_REGS, PAGE = 1
CsmRegsFile : > CSM, PAGE = 1
AdcMirrorFile : > ADC_MIRROR, PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1
CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1
CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1
PieCtrlRegsFile : > PIE_CTRL, PAGE = 1
/*** Peripheral Frame 1 Register Structures ***/
SysCtrlRegsFile : > SYSTEM, PAGE = 1
SpiaRegsFile : > SPIA, PAGE = 1
SciaRegsFile : > SCIA, PAGE = 1
XIntruptRegsFile : > XINTRUPT, PAGE = 1
AdcRegsFile : > ADC, PAGE = 1
SpibRegsFile : > SPIB, PAGE = 1
ScibRegsFile : > SCIB, PAGE = 1
SpicRegsFile : > SPIC, PAGE = 1
SpidRegsFile : > SPID, PAGE = 1
I2caRegsFile : > I2CA, PAGE = 1
/*** Peripheral Frame 2 Register Structures ***/
ECanaRegsFile : > ECANA, PAGE = 1
ECanaLAMRegsFile : > ECANA_LAM PAGE = 1
ECanaMboxesFile : > ECANA_MBOX PAGE = 1
ECanaMOTSRegsFile : > ECANA_MOTS PAGE = 1
ECanaMOTORegsFile : > ECANA_MOTO PAGE = 1
ECanbRegsFile : > ECANB, PAGE = 1
ECanbLAMRegsFile : > ECANB_LAM PAGE = 1
ECanbMboxesFile : > ECANB_MBOX PAGE = 1
ECanbMOTSRegsFile : > ECANB_MOTS PAGE = 1
ECanbMOTORegsFile : > ECANB_MOTO PAGE = 1
EPwm1RegsFile : > EPWM1 PAGE = 1
EPwm2RegsFile : > EPWM2 PAGE = 1
EPwm3RegsFile : > EPWM3 PAGE = 1
EPwm4RegsFile : > EPWM4 PAGE = 1
EPwm5RegsFile : > EPWM5 PAGE = 1
EPwm6RegsFile : > EPWM6 PAGE = 1
ECap1RegsFile : > ECAP1 PAGE = 1
ECap2RegsFile : > ECAP2 PAGE = 1
ECap3RegsFile : > ECAP3 PAGE = 1
ECap4RegsFile : > ECAP4 PAGE = 1
EQep1RegsFile : > EQEP1 PAGE = 1
EQep2RegsFile : > EQEP2 PAGE = 1
GpioCtrlRegsFile : > GPIOCTRL PAGE = 1
GpioDataRegsFile : > GPIODAT PAGE = 1
GpioIntRegsFile : > GPIOINT PAGE = 1
/*** Code Security Module Register Structures ***/
CsmPwlFile : > CSM_PWL, PAGE = 1
3 解决方案
从Simlink生成的CMD文件入手,更改配置,烧写到FLASH。
只需更改前导部分CMD文件afe_dsp.cmd,更改如下:
MEMORY
PAGE 0:
PAGE 1:
SECTIONS
.text: > FLASH, PAGE = 0
.switch: > FLASH, PAGE = 0
.cinit: > FLASH, PAGE = 0
.pinit: >FLASH, PAGE = 0
.econst: > FLASH, PAGE = 0
.rtdx_text: >FLASH, PAGE = 0
IQmath: > FLASH, PAGE = 0
codestart: > BEGINFLASH, PAGE = 0
ramfuncs: > FLASH, PAGE = 0
-l "C:\Program Files\MATLAB\R2009a\toolbox\rtw\targets\ccslink\ccslink\c2000\c280xPeripherals.cmd"
更改部分:
(1)RAMH0改为 FLASH
(2) .econst: > RAML0L1, PAGE = 1改为 .econst: > FLASH, PAGE = 0
4 结论
完成Simulink生成的CMD文件的配置更改,满足了应用要求。
还可以通过Simulink进行配置,双击板子,在Sections中配置。
臻至水 发表于 2015-11-13 15:04 | 显示全部楼层
请问,在simulink的section中怎么设置?
gyg123 发表于 2015-11-22 22:01 | 显示全部楼层
有没这方面的书籍
