51单片机开发板,现将板子原理图,程序,实物照片献上,欢
3007|14
 楼主| lkdd0071415 发表于 2012-12-12 20:45 | 显示全部楼层 |阅读模式
程序中包含了一个LCD欢迎界面,一个舵机程序(用1602显示舵机转角,键盘控制角度),一个数码管测试程序,欢迎共同学习。Q178898365,程序和视频太大,无法上传,有想要的Q我吧,程序我尽量在下面贴出,视频是Altium Designer 10做的板子3D电影,有需要的联系我,我发邮箱。
 楼主| lkdd0071415 发表于 2012-12-12 20:47 | 显示全部楼层
#include "task.h"
#include <REGX52.H>
#include "lcd.h"
#include "system.h"
#include <stdio.h>
sbit key0=P3^2;
sbit key1=P3^3;
sbit ic_dex2=P2^5;
sbit ic_dex0=P2^7;
sbit ic_dex1=P2^6;
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code table[]={"welcome.."};
uchar code table1[]={"WK--01"};
uchar code table2[]={"QQ 178898365 "};
uchar code state[]={"MY SERVO TEST .."};
uchar code prompt[]={"Angle"};
uchar disp_dat[3]={0};
void led_task(void)
        unsigned char i;
        for(i=0;i<8;i++)
                P0=~(0X01<<i);
                Delay_MS(500);
void Dis_ic(void)
        ic_dex0=1;
        ic_dex1=1;
        ic_dex2=1;
        P0=0XFF;
        ic_dex0=0;
        ic_dex1=0;
        ic_dex2=0;
void Servo_task(void)
        float angle=90;
        Dis_ic();
   LCD_Init();             //初始化
        LCD_Write_String(0,0,state);
        LCD_Write_String(0,1,prompt);
        while(1)
        Servo(angle);
        sprintf(disp_dat,"%f",angle);    //字符串格式化命令
        LCD_Write_String(7,2,disp_dat);
                if(key0==0)
                        Delay_MS(10);
                        if(key0==0)
                                angle+=10;
                                while(!key0);
                if(key1==0)
                        Delay_MS(10);
                        if(key1==0)
                                angle-=10;
                                while(!key1);
void Welcome_task(void)
        unsigned i;
        Dis_ic();
                LCD_Init();
        for(i=16;i>3;i--)
                LCD_Clear();
                LCD_Write_String(i,0,table);
                Delay_MS(500);
        Delay_MS(1000);
        LCD_Clear();
        LCD_Write_String(5,0,table1);
        LCD_Write_String(2,1,table2);
        while(1)
                LCD_Clear();
                Delay_MS(500);
                LCD_Clear();
        //        LCD_Write_String(1,1,table2);
                Delay_MS(500);
uchar keyscan(void)                        //键盘扫描
        uchar temp,num;
        P1=0xfe;
        temp=P1;
        temp=temp&0xf0;
                if(temp!=0xf0)
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P1;
                        switch(temp)
                                case 0xee:num=1;
                                break;
                                case 0xde:num=2;
                                break;
                                case 0xbe:num=3;
                                break;
                                case 0x7e:num=4;
                                break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfd;
        temp=P1;
        temp=temp&0xf0;
                if(temp!=0xf0)
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P1;
                        switch(temp)
                                case 0xed:num=5;
                                break;
                                case 0xdd:num=6;
                                break;
                                case 0xbd:num=7;
                                break;
                                case 0x7d:num=8;
                                break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfb;
        temp=P1;
        temp=temp&0xf0;
                if(temp!=0xf0)
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P1;
                        switch(temp)
                                case 0xeb:num=1;
                                break;
                                case 0xdb:num=2;
                                break;
                                case 0xbb:num=3;
                                break;
                                case 0x7b:num=4;
                                break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xf7;
        temp=P1;
        temp=temp&0xf0;
                if(temp!=0xf0)
                temp=P1;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P1;
                        switch(temp)
                                case 0xe7:num=5;
                                break;
                                case 0xd7:num=6;
                                break;
                                case 0xb7:num=7;
                                break;
                                case 0x77:num=8;
                                break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
return num;
void Key_task(void)
                                uchar i;
                while(1)
                        i=keyscan();
                        ic_dex1=1;
                        ic_dex0=0;
                        P0=0xff;
                        ic_dex0=1;
                        ic_dex1=0;
                        P0=tab[i];
#include <REGX52.H>
#include "system.h"
sbit servo=P3^7;
void Delay_MS(uint ms)
        uint t0,t1;
        for(t0=ms;t0>0;t0--)
                for(t1=115;t1>0;t1--);
void Delay_US(uint us)
        while(us--);
void Servo(uint ang)
                int time;
                if((ang>=0)&&(ang<=180))
                time=ang+70;
                servo=1;
                Delay_US(time);
                servo=0;
                Delay_US(2000);
 楼主| lkdd0071415 发表于 2012-12-12 20:48 | 显示全部楼层
#include "lcd.h"
#include <REGX52.H>
#include "system.h"
sbit RS=P2^2;
sbit RIW=P2^3;
sbit E=P2^4;
void Write_Com(uchar com)
   uint i=200;
   RS=1;
   RIW=1;
   RS=0;
   RIW=0;
   E=0;
   E=1;
   P0=com;
   while(i--);
   E=0;
//---------------------1602写指令时序结束---------------------------------------------------
//---------------------1602写数据时序开始--------------------------------------------------
void Write_Dat(uchar dat)
    uint i=200;
    RS=0;
    RIW=1;
    RS=1;
    RIW=0;
    E=0;
    E=1;
    P0=dat;
    while(i--);
    E=0;
//---------------------1602写数据时序结束------------------------------------------------
void LCD_Init(void)            //1602初始化程序
    Write_Com(0x01);             //清屏
    Write_Com(0x06);             //设置输入方式  AC自动加1,显示不发生移位
    Write_Com(0x0c);             //显示开关控制 开显示 开光标 闪烁
    Write_Com(0x38);             //功能设置 双行显示 5*8点阵   八位数据
  void LCD_Clear(void)
        Write_Com(0x01);
        Delay_MS(5);
  void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
  if (y == 0)
         Write_Com(0x80 + x);     //表示第一行
  else
          Write_Com(0xC0 + x);      //表示第二行
  while (*s)
        Write_Dat( *s);
  s ++;
#include <reg51.h>
#include "lcd.h"
#include "system.h"
#include "task.h"
#define uchar unsigned char
#define uint  unsigned int
/******取消程序前面注释便可正常运行任务********/
/*****  作者  王凯       QQ  178898365 ********/
void main()
                for(;;)
                //        Welcome_task();
                                Servo_task();
                //        Key_task();
 楼主| lkdd0071415 发表于 2012-12-12 20:56 | 显示全部楼层
没人顶自己顶一个,跪求人气
1638574407 发表于 2012-12-12 20:57 | 显示全部楼层
wddzyjcx0755 发表于 2012-12-13 00:24 | 显示全部楼层
开发板可以用洞洞板自己焊接一块吗?可以手把手教务一些单片机的学习知识吗?
 楼主| lkdd0071415 发表于 2012-12-13 10:52 | 显示全部楼层
开发板可以用洞洞板自己焊接一块吗?可以手把手教务一些单片机的学习知识吗? ...
没问题啊,欢迎联系
zmxzb 发表于 2012-12-14 10:28 | 显示全部楼层
wddzyjcx0755 发表于 2012-12-18 22:36 | 显示全部楼层
没问题啊,欢迎联系
感谢你的支持,就留个企鹅号:769787308,这样可以远程,可以语音交流。
wddzyjcx0755 发表于 2012-12-18 22:37 | 显示全部楼层
没问题啊,欢迎联系
dong_abc 发表于 2012-12-18 23:12 | 显示全部楼层
楼主敲了一些程序值得鼓励,赞一个。
不过还是说句实话,楼主这些程序除了放在电脑你占空间,还真没有什么用处。
michaellh 发表于 2012-12-19 17:19 | 显示全部楼层
顶!学习了!
 楼主| lkdd0071415 发表于 2012-12-20 14:27 | 显示全部楼层
楼主敲了一些程序值得鼓励,赞一个。
不过还是说句实话,楼主这些程序除了放在电脑你占空间,还真没有什么 ...
听样子你好像是一个牛B青年,不管什么东西学会以后你从高处俯瞰,都那么回事,我写这个也是本着给别人作参考的态度,难道我非得写的非常晦涩难懂才会说,哇,这程序写的太牛B了,有意思吗。至于本人,51单片机很早前就掌握了,也接触过很多其它的微处理器,写过关于UCOSII 和UC GUI方面的程序,有挺难懂,不知你发这样的评论是何态度,装B还是装B呢
你当我装B就行了。  发表于 2012-12-20 21:11
