ISE MAP错误 PLACE:1136
4686|1
zhuxinyu2008|  楼主 | 2012-12-13 17:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
se, AC, ce, TI, TE
ERROR:Place:1136 - This design contains a global buffer instance,
   <memc3_infrastructure_inst/U_BUFG_CLK0>, driving the net, <c3_clk0>, that is
   driving the following (first 30) non-clock source pins.
   < PIN: U_ila_pro_0/U0/I_TQ0.G_TW[0].U_TQ.D; >
   This is not a recommended design practice in Spartan-6 due to limitations in
   the global routing that may cause excessive delay, skew or unroutable
   situations.  It is recommended to only use a BUFG resource to drive clock
   loads. If you wish to override this recommendation, you may use the
   CLOCK_DEDICATED_ROUTE constraint (given below) in the .ucf file to demote
   this message to a WARNING and allow your design to continue.
   < PIN "memc3_infrastructure_inst/U_BUFG_CLK0.O" CLOCK_DEDICATED_ROUTE =
   FALSE; >
添加逻辑分析仪MAP出现以上错误,要怎么解决才好  有知道的吗  这个问题纠结了好久
GoldSunMonkey| | 2012-12-14 22:29 | 只看该作者
我觉得 引出来看的信号分配的有问题。
