DS1302显示在1602上,显示的确实十六进制的。请问怎么转码?
3903|17
 楼主| 肖恩till 发表于 2012-12-15 20:52 | 显示全部楼层 |阅读模式
ui, TE, RS, ST, ck
程序:#include <reg51.h>
#include <intrins.h>
typedef unsigned char uint8;
typedef unsigned int  uint16;
sbit SCK = P3^5;
sbit SDA = P3^4;
sbit RST = P1^7;
sbit RS  = P1^0;
sbit RW  = P1^1;
sbit EN  = P1^5;
sbit BUSY= P0^7;
#define DS1302_W_ADDR 0x80
#define DS1302_R_ADDR 0x81
uint8 time[7]={00,1,11,14,12,16,12};
void delay(uint16 n)
            while(n--);
/*写一个字节*/
void w_ds1302_byte(uint8 dat)
     uint8 i;
         SCK = 0;
         for(i=0;i<8;i++)
              SDA = dat & 0x01;
                  SCK =1;
                  dat>>=1;
                  SCK =0;
/*读一个字节*/
uint8 r_ds1302_byte()
     uint8 i,dat =0;
         SCK =0;
         for(i=0;i<8;i++)
              dat>>=1;
              if(SDA)
                       dat |=0x80;
                  SCK =1;
                  SCK =0;
         return dat;
void reset_ds1302()
         RST =0;
         SCK =0;
         RST =1;
void clear_ds1302_WP()
     reset_ds1302();
         RST =1;
         w_ds1302_byte(0x8e);
         w_ds1302_byte(0);
         SDA =0;
         RST =0;
void set_ds1302_WP()
     reset_ds1302();
         RST =1;
         w_ds1302_byte(0x80);
         SDA =0;
         RST =0;
/*写入DS1302*/
void w_ds1302(uint8 addr,uint8 dat)
     reset_ds1302();
         RST =1;
         w_ds1302_byte(addr);
         w_ds1302_byte(dat);
         SDA =0;
         RST =0;
/*读出DS1302*/
uint8 r_ds1302(uint8 addr)
     uint8 temp;
     reset_ds1302();
         RST =1;
         temp=r_ds1302_byte();
         SDA =0;
         RST =0;
         return temp;
/*设定时钟数据*/
void set_time(uint8 *timedata)
     uint8 i,tmp;
         for(i=0;i<7;i++)           //BCD
             tmp =timedata[i]/10;
                 timedata[i]=timedata[i]%10;
                 timedata[i]=timedata[i]+tmp*16;
         clear_ds1302_WP();
         tmp=DS1302_W_ADDR;
         for(i=0;i<7;i++)
             w_ds1302(tmp,timedata[i]);
                 tmp +=2;
         set_ds1302_WP();
/*读时钟数据*/
void  read_time(uint8 *timedata)
     uint8 i,tmp;
         tmp =DS1302_R_ADDR;
         for(i=0;i<7;i++)
             timedata[i] = r_ds1302(tmp);
                 tmp +=2;
void wait()
     P0 =0xff;
         do
              RS =0;
                  RW =1;
                  EN =0;
                  EN =1;
         }while(BUSY == 1);
         EN =0;
void w_dat(uint8 dat)
     wait();
         RS = 1;
         RW = 0;
         EN = 0;
         P0 = dat;
         EN = 1;
         EN = 0;
void w_cmd(uint8 dat)
     wait();
         RS = 0;
         RW = 0;
         EN = 0;
         P0 = dat;
         EN = 1;
         EN = 0;
void Init_LCD1602(void)
        w_cmd(0x38);  // 16*2显示,5*7点阵,8位数据接口
        w_cmd(0x0C);  // 显示器开、光标开、光标允许闪烁
        w_cmd(0x06);  // 文字不动,光标自动右移
        w_cmd(0x01);  // 清屏
main()
     set_time(&time);
         Init_LCD1602();
         while(1)
              read_time(&time);
             w_cmd(0x80);w_dat(time[6]+'0');
                 w_cmd(0x82);w_dat('-');
                 w_cmd(0x83);w_dat(time[4]+'0');
                 w_cmd(0x85);w_dat('-');
                 w_cmd(0x86);w_dat(time[3]+'0');
                 w_cmd(0xc0);w_dat(time[2]+'0');
                 w_cmd(0xc2);w_dat(':');
                 w_cmd(0xc3);w_dat(time[1]+'0');
                 w_cmd(0xc5);w_dat(':');
                 w_cmd(0xc6);w_dat(time[0]+'0');
                 delay(10000);
出来的结果列如:
B-B-D
A:B:E
cjmqgsx 发表于 2012-12-15 22:09 | 显示全部楼层
解不了
Juwaylee 发表于 2012-12-15 22:56 | 显示全部楼层
写进去是BCD,读出来也是BCD。写的时候转换了,读出来怎么不转换一下
 楼主| 肖恩till 发表于 2012-12-16 11:04 | 显示全部楼层
想在read_time(&time);之后转换的,可是一直都没试对,郁闷
Juwaylee 发表于 2012-12-16 15:23 | 显示全部楼层
还有个位十位要分别显示,一个萝卜坑是装不了两个萝卜滴
ningling_21 发表于 2012-12-16 15:40 | 显示全部楼层
十位:time[4]>>4
个位:time[4]&0x0f
 楼主| 肖恩till 发表于 2012-12-16 21:13 | 显示全部楼层
楼上是这个意思么?
while(1)
             read_time(&time);
                 for(i=0;i<7;i++)
                     tmp = time[i]&0x0f;
                         time[i]>>=4;
                         time[i] &= 0x0f;
                         time[i] =time[i]*10+tmp;
可是还是不行那?
 楼主| 肖恩till 发表于 2012-12-16 21:14 | 显示全部楼层
那怎么办。能具体不?我是一个小菜鸟
东北小辉辉 发表于 2012-12-16 23:57 | 显示全部楼层
uchar BCD_Decimal(uchar bcd)//BCD 码转十进制函数,输入 BCD,返回十进制
    uchar Decimal;
    Decimal=bcd>>4;
    return(Decimal=Decimal*10+(bcd&=0x0f));
楼主我送你一个小函数,怎么样
coody 发表于 2012-12-17 10:15 | 显示全部楼层
DS1302是BCD码,这个要注意
 楼主| 肖恩till 发表于 2012-12-17 12:27 | 显示全部楼层
    uchar Decimal;
你这个和我上面那个一样哪,出来的不是字母而是一些符号。。。有没有人写过类似的,我参考一下
DS1302是BCD码,这个要注意
嗯 知道
elec921 发表于 2012-12-17 12:37 | 显示全部楼层
高4位移到右边
低4位直接取
东北小辉辉 发表于 2012-12-17 12:47 | 显示全部楼层
你这个和我上面那个一样哪,出来的不是字母而是一些符号。。。有没有人写过类似的,我参考一下 ...
我用的就是这个,显示很正常啊,怎么了?
Juwaylee 发表于 2012-12-17 15:53 | 显示全部楼层
比如秒,你要这么显示
w_cmd(..);w_dat(time[0]/10+'0');
w_cmd(..);w_dat(time[0]%10+'0');
 楼主| 肖恩till 发表于 2012-12-17 18:42 | 显示全部楼层
比如秒,你要这么显示
按照你说的,可以了,谢谢:handshake
谢谢楼上各位啦
Juwaylee 发表于 2012-12-17 18:50 | 显示全部楼层
按照你说的,可以了,谢谢
谢谢楼上各位啦
继续努力哈
 楼主| 肖恩till 发表于 2012-12-17 19:01 | 显示全部楼层
继续努力哈
呵呵
个人签名:一步一步,踩到顶点O(∩_∩)O~
