TI 官网MSP430历程居然有错误。求围观!!!
2383|6
 楼主| roarghy 发表于 2012-12-17 09:09 | 显示全部楼层 |阅读模式
在等到首次发送中断前,系统应该在_BIS_SR(LPM3_bits + GIE); 执行完后进入低功耗了。倘若此时有数据接受中断并响应了,那么这样一来数据接受中断和发送中断就交替相应了,可是这两个中断都会对变量RXTXData进行操作,这样一来就出错了。不知道是我想错了,还是程序真的有问题。
这是TI例程。如下
//  MSP430F14x Demo - Timer_A, Ultra-Low Pwr(超低功耗) UART 2400 Echo, 32kHz ACLK
//  Description: Use Timer_A CCR1 hardware output modes and CCR0 SCCI data latch
//  to implement UART function @ 2400 baud. Software does not directly read and
//  write to RX and TX pins, instead proper use of output modes and SCCI data
//  latch are demonstrated. Use of these hardware features eliminates ISR
//  latency effects as hardware insures that output and input bit latching and
//  timing are perfectly synchronised with Timer_A regardless of other
//  software activity. In the Mainloop the UART function readies the UART to
//  receive one character and waits in LPM3 with all activity interrupt driven.
//  After a character has been received, the UART receive function forces exit
//  from LPM3 in the Mainloop which echo's back the received character.
//  ACLK = TACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO
//  //* An external watch crystal is required on XIN XOUT for ACLK *//
//               MSP430F14x
//        /|\|              XIN|-
//         | |                 | 32kHz
//         --|RST          XOUT|-
//           |         TXD/P2.3|-------->
//           |                 | 2400 8N1
//           |   CCI0B/RXD/P2.2|<--------
#define RXD       0x04                      // RXD on P2.2
#define TXD       0x08                      // TXD on P2.3
//   Conditions for 2400 Baud SW UART, ACLK = 32768
#define Bitime_5  0x06                      // ~ 0.5 bit length + small adjustment
#define Bitime    0x0E                      // 427us bit length ~ 2341 baud
unsigned int RXTXData;
unsigned char BitCnt;
void TX_Byte (void);
void RX_Ready (void);
//  R. B. Elliott / H. Grewal
//  Texas Instruments Inc.
//  November 2007
//  Built with IAR Embedded Workbench Version: 3.42A
#include  <msp430x14x.h>
void main (void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  CCTL1 = OUT;                              // TXD Idle as Mark
  TACTL = TASSEL_1 + MC_2;                  // ACLK, continuous mode
  P2SEL = TXD + RXD;                        // *******
  P2DIR = TXD;                              //
// Mainloop
  for (;;)
  RX_Ready();                               // UART ready to RX one Byte
  _BIS_SR(LPM3_bits + GIE);                 // Enter LPM3 w/ interr until char RXed
  TX_Byte();                                // TX Back RXed Byte Received
// Function Transmits Character from RXTXData Buffer
void TX_Byte (void)
  BitCnt = 0xA;                             // Load Bit counter, 8data + ST/SP
  while (CCR1 != TAR)                       // Prevent async capture
    CCR1 = TAR;                             // Current state of TA counter
  CCR1 += Bitime;                           // Some time till first bit
  RXTXData |= 0x100;                        // Add mark stop bit to RXTXData
  RXTXData = RXTXData << 1;                 // Add space start bit
  CCTL1 =  CCIS0 + OUTMOD0 + CCIE;          // TXD = mark = idle
  while ( CCTL1 & CCIE );                   // Wait for TX completion
// Function Readies UART to Receive Character into RXTXData Buffer
  BitCnt = 0x8;                             // Load Bit counter
  CCTL0 = SCS + OUTMOD0 + CM1 + CAP + CCIE + CCIS_1;   // Sync, Neg Edge, Cap
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  CCR0 += Bitime;                           // Add Offset to CCR0
    if( CCTL0 & CAP )                       // Capture mode = start bit edge
    CCTL0 &= ~ CAP;                         // Switch from capture to compare mode
    CCR0 += Bitime_5;
    else
    RXTXData = RXTXData >> 1;
      if (CCTL0 & SCCI)                     // Get bit waiting in receive latch
      RXTXData |= 0x80;
      BitCnt --;                            // All bits RXed?
      if ( BitCnt == 0)
//>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      CCTL0 &= ~ CCIE;                      // All bits RXed, disable interrupt
      _BIC_SR_IRQ(LPM3_bits);               // Clear LPM3 bits from 0(SR)
// Timer_A3 Interrupt Vector (TAIV) handler
#pragma vector=TIMERA1_VECTOR
__interrupt void Timer_A1(void)
  switch( TAIV )
    case  2:                                //(TACCTL1 CCIFG中断标志 这里是"发送"标志)
      _NOP();
        CCR1 += Bitime;                     // Add Offset to CCR0
// TX
  if (CCTL1 & CCIS0)                        // TX on CCI0B?
    if ( BitCnt == 0){
    CCTL1 &= ~ CCIE;                        // All bits TXed, disable interrupt
    else
      CCTL1 |=  OUTMOD2;                    // TX Space
      if (RXTXData & 0x01)
      CCTL1 &= ~ OUTMOD2;                   // TX Mark
      BitCnt --;
      break;                                // CCR1 not used
    case  4:                                  //(TACCTL2 CCIFG中断标志)
               break;                        // CCR2 not used
    case 10:                                //(TAIFG中断标志)
               P1OUT ^= 0x01;                // overflow
              break;
 楼主| roarghy 发表于 2012-12-17 09:10 | 显示全部楼层
希望各位给分析分析~~~~~~~
 楼主| roarghy 发表于 2012-12-17 13:19 | 显示全部楼层
我搞懂了!不好意思打扰大家了!这是一个半双工通信!我才疏学浅 。
chenyu988 发表于 2012-12-18 12:31 | 显示全部楼层
我搞懂了!不好意思打扰大家了!这是一个半双工通信!我才疏学浅 。 ...
默认某一时刻只能进入一个中断 除非你中断嵌套
shenmu2012 发表于 2012-12-18 14:25 | 显示全部楼层
楼主这用的是模拟UART的吧。。查下定时器中断的吧
 楼主| roarghy 发表于 2012-12-18 17:03 | 显示全部楼层
发完帖子之后,又看了一边程序。懂了~
你说得对
