请教AT89C51SND1C的BOOTLOADER
3591|7
 楼主| szhgx26 发表于 2007-7-1 10:52 | 显示全部楼层 |阅读模式
近日买了片AT89C51SND1C的IC做MP3 PLAYER,请问刚出厂的芯片是否已经有BOOTLOADER在里面了?还是要用编程器自已再烧进去?
computer00 发表于 2007-7-1 11:10 | 显示全部楼层
出厂时已经固化。
古道热肠 发表于 2007-7-1 11:44 | 显示全部楼层
程序只能用USB下载
   可资料上提到的也支持串口下载,硬是没用串口玩起来,也不知何故?
 楼主| szhgx26 发表于 2007-7-1 14:05 | 显示全部楼层
古道热肠兄,能否描述一下USB ISP的步骤?
本人专门做了块板子SND1C的板子,USB ISP没跑起来,真是急死了.
我用的FLIP 3.2.0,新买的片子.
adminic 发表于 2007-7-1 16:50 | 显示全部楼层
关注中...
先顶起来
 楼主| szhgx26 发表于 2007-7-2 09:42 | 显示全部楼层
各位高手帮忙指点一下啊?
古道热肠 发表于 2007-7-2 09:53 | 显示全部楼层
先按住下载按钮,再给线路板上电
    SND1有个脚是ISP进入的专用管脚,上电时必须拉低,再上电复位时,单片机进入固件下载状态。此时将USB连接线连到电脑上时,电脑发现新硬件,装好驱动程序,再用FLIP软件,先进行联机操作,再进行编程操作。
    不妨把你的电路贴在坛子上,让大家看看。
 楼主| szhgx26 发表于 2007-7-3 09:01 | 显示全部楼层
搞定了,
上ATMEL的FAQ看了一下,找到下面一段:
at Reset, execution in Bootloader, you need to Held the /ISP to GND through a pull-down resistor (2.2kohm) at the falling reset.
This flow is described page 7 of the following document :
http://www.atmel.com/dyn/resources/prod_documents/doc4254.pdf
If you have still problems, could you execute the following sequence :
- first set the ISP condition
- Reset the device
- Connect the USB of your board (with AT89C51SND1C in ISP mode) to the
PC.
- You should observe wizard instructions displayed on your PC due to the detection of a USB component.
Follow the instructions as following :
When the device enumerates for ISP, Windows opens a "New Device
Detected" wizard.
You must, then, choose the driver install in a "specific location".Then
Windows prompts you for the location of the driver.The path which must
be written is : "C:Program FilesATMELFLIP 2.4.Xusb" folder of FLIP
which contains the INF file and the driver.
If you have still problems :
Open the device manager
- Connect the USB board (with AT89C51SND1C in ISP mode) to the PC.
- Could you observe the USB device that just popped up (normally Jungo)
- If not Jungo, select it and uninstall it. This will clean the windows
registries.
- unplug the device from the PC.
- In the directory : WINNTinf (for Windows 2000) or WINDOWSinf (for
Windows XP) search all files containing the following string :
- 89C51SND1
- 89c5132
- and delete them.
then test again as described at the beginning of this message.
